Inconsistent POSTing on PC ( already replaced multiple parts)
286 (0.70/day)
System Name SYSTEM
Processor RYZEN 7 5700X
Motherboard TUF B550M GAMING PLUS
Cooling AG620 CPU COOLER
Memory 16GB RAM DUAL CHANNEL 3200MHZ STOCK
Video Card(s) RTX 4070 GIGABYTE 12GB WINDFORCE
Storage 1TB HDD 256GB SSD
Display(s) LG ULTRAGEAR 144HZ
Case AIGO DARK FLASH
Audio Device(s) MOTHERBOARD AUDIO
Power Supply XPG ADATA PYLON 650W
Mouse REDRAGON COBRA M711 V2
Software WINDOWS 11
Hello
I´ve been asked in a post a while , thought my GPU was bad
But already replaced mobo , gpu and psu as well yet i have a random white vga light that prevents the PC from posting randomly
Replaced my sata ssd for a m2 one and still the same white light preventing post
at this point i´m 100% sure it isn´t the gpu the root problem
What else could cause this ? i´m pretty sure the hardware is 100% functional but sometimes it refuses to post
I have a bluetooth dongle ( orico ) , could it have gone bad and cause this randomly?
the usb devices connected to my pc are : bluetooth dongle , logitech mouse g305 ( with the usb dongle connected to the extender supplied by logitech ) , redragon keyboard and a hs65 surround corsair headset
my pc is connected to a line filter (quality one) and my monitor is a lg ultragear 24 inches 144hz ( i use a 90 degrees adapter to connect the display port cable )
i have a tv connected to the pc as well with a hdmi cable
i don´t know what else could cause this , what can i try to solve it ?
thanks
at this point i think i only have to replace the dp and hdmi cables maybe?
13,236 (1.97/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
But does it try? That is, when you press the power button, does the computer always start to boot, then intermittently fail to pass POST? Or does it some times do absolutely nothing when you press the power button?
If you have more than 1 stick of RAM, take one out and see what happens. Then swap sticks to hopefully through a process of elimination see which one, if one, is bad.
If all RAM sticks appear good, then if me, I would take everything out of the case and assemble the computer on a large, unfinished wooden bread/cutting board and see what happens. While everything is out, verify you don't have an extra standoff in the case and there is only a standoff where there is a corresponding motherboard mounting hole.
If it works consistently outside the case, and there are no extra standoffs, then your power switch may be the problem. If your case has a reset button, you can swap the wires from the reset button and attach them to the motherboard where the power switch wires went. Then use the Reset button as your power button from now on.
286 (0.70/day)
System Name SYSTEM
Software WINDOWS 11
it always turns on with the fans working etc
I´ve tested all 4 sticks with memtest86 and they all pass
my motherboard first checks cpu , ram , vga then boot
all of them pass but sometimes it gets stuck in the vga light
it doesn´t mean the vga is bad but it can´t proceed further to the boot light and get to windows
but i mean yes , it always gets power
i don´t know what else can be , i suspect the Bluetooth dongle maybe
it is not something to do with monitor being on first then powering the PC as it boots fine without any display connected to it as well ( just tested )
13,236 (1.97/day)
Nebraska, USA
Mouse Logitech M190
Software-based RAM diagnostic tools are good but none are 100% conclusive. If they report any errors, even one, the RAM is bad. But on rare occasion they will report no problems, yet the RAM still fails in use, and/or when paired with other RAM. So, swapping in all new RAM is often the best test. But of course, not everyone has a bunch of spare RAM laying around. This is why I suggested running with just a single RAM stick to see if it fails. Repeat process with remaining sticks, hopefully identifying the bad stick through a process of elimination. Just be sure to unplug the computer from the wall and touch bare metal of the case interior BEFORE reaching for the RAM to discharge any destructive static in your body.
Note to conclusively test your RAM, you need to use sophisticated and very expensive test equipment, like this $2,495 Memory Tester (and that's for the cheap model)! So it is usually easier (and cheaper!) to swap in known good RAM and see what happens.
There's still the question of standoffs. And I am assuming you have triple checked to ensure all power and data cables are security connected.
286 (0.70/day)
System Name SYSTEM
Software WINDOWS 11
Hmm i see
Yes i just checked everything and they are all seated fine
I just thought it the motherboard would be stuck at dram or cpu lights if ram is bad?
Thanks
13,236 (1.97/day)
Nebraska, USA
Mouse Logitech M190
You already replaced the motherboard. While certainly possible, it is unlikely two motherboards would fail with the same symptoms. LED indicators only provide clues and they are not always right.
286 (0.70/day)
System Name SYSTEM
Software WINDOWS 11
hmm true
i don´t know what else i can try ( gpu was replaced as well )
i doubt there is a issue with the hardware
i don´t have any instability when it boots , do you think it could still be ram ?
the only things i didn´t replace : cpu and ram sticks
i suspect the dongle or maybe the 90 degrees dp adapter? or my cables bad maybe?
78 (0.20/day)
System Name Home workhorse-gaming
Processor Intel 13600KF @ 5400/4300
Motherboard Asus ROG Strix Z790A Gaming WiFi
Cooling Arctic Freezer 2 rev.7 360mm
Memory 2x16 Kingston Fury Renegade Silver RGB DDR6400@XMP settings - 32-39-39-80
Video Card(s) Palit GamePro 3080Ti with Alphacool Eiswolf 2 360 mm
Storage NVME, WD 550 Blue 1 TB (gen.3), Samsung 980 1 TB (gen.3), Kingston KC3000 2 TB (gen.4)
Display(s) Samsung Odyssey G5 LS27AG500NUXEN (IPS, flat), @120Hz, 10 bit color (165Hz@8 bit)
Case Corsair 5000D Airflow, 4xArctic Bionix P120
Audio Device(s) Creative Sound BlasterX AE5 Plus, Creative P580 boxes, Sennheiser HD569
Power Supply Seasonic Focus GX 850W Gold
Mouse Razer Basilisk V3 Chroma
Keyboard Asus TUF Gaming K3
VR HMD none
Software W11 pro
Benchmark Scores https://hwbot.org/xtu2/analyze/5404795?recalculate=true
As crazy as it would sound, detach that HDD and see what's happening without it. Been there, done that, no joking.
286 (0.70/day)
System Name SYSTEM
Software WINDOWS 11
the m2 is new , do you think even a new drive could cause it?
ir_cow
4,499 (0.76/day)
USA
Stuck on the vga light points to a GPU problem. Have you forgotten to plug the power cables in?
78 (0.20/day)
VR HMD none
Software W11 pro
Yep. Did you cloned the old one, or did you do a fresh install?
665 (1.15/day)
Processor Ryzen 5700x
Motherboard Gigabyte Auros Elite AX V2
Cooling Thermalright Peerless Assassin SE White
Memory TeamGroup T-Force Delta RGB 32GB 3600Mhz
Video Card(s) PowerColor Red Dragon Rx 6800
Storage Fanxiang S660 1TB, Fanxiang S500 Pro 1TB, BraveEagle 240GB SSD, 2TB Seagate HDD
Case Corsair 4000D White
Power Supply Corsair RM750x SHIFT
Unplug any extra drives apart from c: any USB peripherals apart from KB/Mouse, use your monitor only so unplug the TV/secondary display and swap out the cable for the monitor if you have a spare
286 (0.70/day)
System Name SYSTEM
Software WINDOWS 11
this thing only happens randomly tbh
i´ve properly attached the 2 cables ( it is a splitter 2x8 , 4070 super)
when the pc boots there is 0 instability
this white vga light already happened in 2 different mobos , drives and gpus
the only thing i did not replace was the cpu and rams
the cpu hasn´t any bent pin as well
fresh install
i know it may sound but maybe my headset is causing it ? it is one from corsair
i also have that bluetooth dongle mentioned as well
this happens like once in a month , pc fails to post
crazy*
665 (1.15/day)
fresh install
crazy*
it should 2x6+2 cables, what do you mean you use a splitter? use both cables not 1 split into 2
665 (1.15/day)
fresh install
crazy*
I was having some weird issues a week or 2 back that led me to reinstall Windows twice within hours, turns out my USB printer was causing it as I had used it a week before and just left it plugged in which I don't usually do, rarely use it so only plug it in when I need it and then it gets turned off and unplugged though I guess I just left it this time, was fine until a week later when I was getting weird problems and after going through hours of head scratching and banging when I removed the printer cable the issues went away, so it is possible, USB can be problematic sometimes and is usually the last thing you think of, could be the motherboard header, cable, device or some weird power issues but I certainly wouldn't rule it out
ir_cow
4,499 (0.76/day)
USA
Debugs lights rarely lie. It's failing to post at VGA step. Try a different slot?
As @Marcus L said, disconnect all unnecessary cables
286 (0.70/day)
System Name SYSTEM
Software WINDOWS 11
Makes me think some OCP is kicking in.
not really as i´ve changed the PSU as well
it is properly connected i assure
yes it is 2x6+2 ( connected both in the nvidia adapter , atx 5.0)
78 (0.20/day)
VR HMD none
Software W11 pro
Hm, I'm betting on PSU. Possibly damaging more in the process.
286 (0.70/day)
System Name SYSTEM
Software WINDOWS 11
i doubt it is the same problem again
i had a 4070 eagle then i swapped for a 4070 super with a new psu and motherboard as well
i can´t be facing the same problem
the same white vga light happened in 2 mobos , 2 psus and 2 gpus , almost sure there isn´t a hardware issue
there is a high chance my bluetooth dongle could be the root maybe but i´m not sure
can my line filter or the 90 degrees display adapter be causing this ?
ir_cow
4,499 (0.76/day)
USA
Probably not directly related to VGA than, but that's where it stops of two 80% different systems. So you have the CPU left and all the stuff plugged into that could be the culprit.
Something silly like a OCP trip from a Daisy-chain and something is shorting.
286 (0.70/day)
System Name SYSTEM
Software WINDOWS 11
do you think it could be the CPU , RAM where all the motherboard lights have a consistently pass ?
my motherboard is cpu , dram , vga and boot ( the boot process )
so the light would be stuck at either dram or cpu maybe?
665 (1.15/day)
You said it was a splitter cable so I took from that you meant a single PCI-E cable with 2 x6+2
remove anything unneccesary, usb peripherals, 2nd monitor, HDD's, heck even try single stick of RAM in different slots and alternate them, lots of variables, failing that, breadboard the system (take it out of the case and plug in just the most basic things to get it to boot/post) when did the problem start, is this a new build so you had the issues from the outset or they randomly started?
Unplug anything not neccesary for the system to successfully post and boot, so yes, that includes all of those and the other things I mentioned, this is what you should have done before spending what seems like a quite large amount of $ just replacing things that might have been perfectly working
286 (0.70/day)
System Name SYSTEM
Software WINDOWS 11
just randomly started , i swapped some components but still persisted
the only things that remained : cpu , ram , bluetooth dongle , redragon keyboard , logitech mouse
can my display port or hdmi cable cause it ?
i know bill mentioned that software that tests ram are not 100% accurate but it doesn´t get stuck at the ram light , passes the memtest86 and no instability whatsoever when the pc boots
ir_cow
4,499 (0.76/day)
USA
You said randomly, so what does it do on the vga led? Ie, does it ever boot?
What are you doing to resolve it?
What were you doing before it happens?
