Intel i7-8750H extreme heat
Grimnir
2 (0.10/day)
Hello!, I use a Dell G7 7588 laptop with an i7-8750H and a GTX 1060 Max-Q that I got back in 2018. Recently when I play games I notice a great decline in the processor's clock rate where it freezes at 800Mhz and like 10Watts TDP making any game unplayable. Additionally, When I run the TS Bench or Cinebench R20 the TDP rises to like 70 Watts and then it throttles at 2900Mhz and 44.5 ~ 45W TDP and limits windows show PL1 and EDP Other in constant red color. Of course, thermals are a major problem for me so I undervolted both the cache and the core to a -125mV but it didn't help much with either the throttling or the thermals. For the record I use ASUS GPU Tweak software because for some reason the GPU thermal throttles at 77 Celsius which didn't happen before. I tried to increase the Turbo Boost Long Power Max to 55 but it didn't work. Is there any solution for this?.
PS: The CPU ran fairly and didn't throttle when I shut down the ASUS GPU Tweak software. But, now I get 99 Celsius constantly on games like No Man's Sky and Remnant: From The Ashes. Also the throttling is still there when using CinebenchR20. Tried to disable the Turbo Boost but the temps are still about 85 ~ 90 and the GPU is like 90 ~ 95. Any solutions?
541 (0.38/day)
System Name The de-ploughminator
Processor I7 8700K @ 5.1Ghz
Motherboard Gigabyte Z370 Gaming 5
Cooling Custom Watercooling
Memory 4x8GB G.Skill Trident Neo 3600mhz 15-15-15-30
Video Card(s) RTX 2080 Ti + Heatkiller IV wb
Storage Plextor 512GB nvme SSD
Display(s) LG 34GN850-B
Case Lian Li 011D Dynamic
Audio Device(s) Creative AE-5
Power Supply Corsair RM1000
Well if you aren't afraid of breaking your laptop then I suggest repaste the CPU with better TIM. Recently I repasted my Triton 500 laptop with 10875H CPU with Thermalright TF-X and it has been very good.
The Thermalright TF-X is best suited for Laptop because it has very high viscosity --> less chance of TIM dripping out when you put the laptop in backpack in the vertical position.
Grimnir
2 (0.10/day)
Unfortunately, I am afraid since I do not have much experience with laptop hardware and truthfully I don't trust anyone in my country to do it for me. I noticed that the laptop throttles even in the lightest of games like Valorant and with Turbo boost disabled. I can play it smoothly for like an hour or so and then get thermal throttling on both GPU and CPU which is really frustrating. Is there any other solution?.
9,795 (4.47/day)
Sunshine Coast
System Name Black Box
Processor Intel i5-9600KF
Motherboard NZXT N7 Z370 Black
Cooling Cooler Master 240 RGB AIO / Stock
Memory Thermaltake Toughram 16GB 4400MHz DDR4 or Gigabyte 16GB 3600MHz DDR4 or Adata 8GB 2133Mhz DDR4
Video Card(s) Asus Dual 1060 6GB
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
Try setting Turbo Ratio Limits to 39 all cores, and decreasing (higher negative offset) Voltage offset for the CPU Core to around -250 and leave Cache as -125
70 (0.42/day)
If I remember correctly the CPU/GPU of Dell G7 15 is soldered to heatpipe, no repaste possible(or necessary), assuming that you are outside warantty period, the only course of action is to use a external laptop cooler, and to clean your vent.
9,795 (4.47/day)
Sunshine Coast
Mouse Yes
Keyboard Of course
WUT no!
The heatpipes and cooling block unscrews from the Motherboard.
