OrbitzXT
- Mar 22, 2007
- 1,969 (0.32/day)
- New York City
System Name | AX-01 |
Processor | Intel Core i5-2500K @3.7 GHz |
Motherboard | ASRock Z68 Extreme3 Gen3 |
Cooling | Zalman 9700 |
Memory | Kingston HyperX T1 Series 8GB DDR3 1600 MHZ |
Video Card(s) | GTX 590 |
Storage | Intel X25-M |
Display(s) | 42" Samsung LED HDTV |
Case | Antec Twelve Hundred |
Audio Device(s) | HT | OMEGA STRIKER 7.1 |
Power Supply | Kingwin 1000W |
Software | Windows 7 64-Bit |
The last 3 or 4 days I've had very unstable internet. It always works, but there are period of times when I get disconnected from whatever I'm doing. Its very frustrating because I make my living from online poker, and I keep getting disconnected from tables and losing money because of it. I have Road Runner in NYC, I called them but they were their usual unhelpful selves (Is your mouse plugged in, etc). I've had problems in the past where the lines outside my house had a weak signal, and they had to send someone here to boost my signal which helped.
I was looking at this diagnostic page, http://192.168.100.1/diagnostics_page.asp
and it says the following...
Cable Signal Details
Forward Path:
Signal Acquired at 687.000 MHz
SNR: 36.5 dB
Received Signal Strength: -4.8 dBmV
Modulation: 256 QAM
Return Path:
Connection: Acquired
Frequency: 23.0 MHz
Power Level: 48.0 dBmV
Channel ID: 2
Modulation: 16 QAM
Does anyone who knows what these numbers mean can tell me if I have a weak signal again or if my problem is something else? When my internet works, it works fine, but very often I get disconnected for 30-40 seconds and reconnect.
Forward Path:
SNR: 36.5 dB
Modulation: 256 QAM
Return Path:
Frequency: 23.0 MHz
Channel ID: 2
Modulation: 16 QAM
