- Jan 30, 2013
- 70 (0.02/day)
Processor | i5-6600k (4.2 GHz) |
Motherboard | Asus Z170-P D3 |
Memory | Crucial 16GB DDR3L 1600MHz |
Video Card(s) | GTX 970 |
Storage | Samsung 850 Pro |
Display(s) | Philips 272G5DYEB + Samsung LED HDTV |
Case | Cooler Master HAF 912 |
Power Supply | Corsair 700W |
Software | Windows 8.1 64 Bit |
I thought the issue was my CPU fan and have been toying around with the Q-Fan controls in my BIOS with no luck, but I decided to put my ear to the case just now and it seems the noisy fan I've been hearing is actually coming from my power supply. It only gets noisy when I start to run a game, when I'm browsing or on the desktop it's pretty silent. I opened it up and felt it, it's very cool even while noisy. My system has been running very stable without issues, I have a slight 4.2ghz overclock going.
Is this something I should be concerned about? It's not a fantastic power supply from all the things I've read, it's 2-3 years old. Should I look into replacing it sooner than later? Also, my case has ventilation to aim the power supply's fan downward, it sits on a wooden desk and has about 1cm of standoff space, is that fine or should I look into turning it around and having the fan blow into the case?
Edit: This is the exact one I ordered, it'll be 3 years old in July.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171054
Edit 2: If I need to replace it, I don't have much in the way of spare monies at the moment. Will this one suffice as a budget PSU?
http://www.amazon.com/dp/B00EON40CS/?tag=tec06d-20
