Is there any possible air cooler for reference VEGA 56 ?
User !
19 (0.07/day)
Likes
3
#1
Hello Guys!
I've been pushing my vega 56 to its default clock 1750mhz (I've flashed it with 64 LC bios) but I am bogged down by its high temperature.Though I have cleaned the cooler and spread on the core,hbm with MX-2, I still get the hbm beyond 75c and core beyond 70c. Since the 64 LC bios has a strict Temp Limit , I only push my card at 1600-1620mhz with 1.1-1.15v and 1150mhz on memory . The FSE griphics score is 11300-11500 . But if I get a good cooler I think I can break 12000 or so. Now I have an Arctic III cooler but it dosen't fit to my card. So is there a way to use ACIII on my card or any Air cooler available on market?
Thanks in advance.
User !
19 (0.07/day)
Likes
3
#3
Raijintek Morpheus II or Morpheus Vega(which they say exists...but where you can get one is a mystery).
EDIT: Looks like the Morpheus Vega is a thing...you can actually buy. But seems to only be available in Europe(Overclockers UK, Caseking, etc.).
It looks great! But I can't find it in the PRC. Vega 64 LC cooler is available for around $75 . Considering vega 56 only costs me $240 and I can get a gtx 1080 for $340 , I will try using my own two 50w 12cm fans to help transfer the heat.
2,074 (0.55/day)
Likes
386
System Name Budget AMD System
Processor Threadripper 1900X @ 4.025Ghz (100x40.25 @ 1.325V)
Motherboard Gigabyte X399 Aorus Gaming 7
Cooling EKWB X399 Monoblock
Memory 4x8GB GSkill TridentZ RGB 14-14-14-34 CR1 @ 2933
Video Card(s) XFX Radeon RX Vega₆⁴ Liquid @ 1,800Mhz Core, 1100 HBM2
Storage 1x ADATA SX8200 NVMe, 1x Segate 2.5" FireCuda 2TB SATA, 1x 500GB HGST SATA
Display(s) Vizio 22" 1080p 60hz TV (Samsung Panel)
Case Corsair 570X
Power Supply Seasonic X Series 850W KM3
Well, You'd be hard pressed to find an air cooler that can keep the Vega64 cool at 1700+Mhz.
Wait... you can order the LC cooler where you are? :-\
User !
19 (0.07/day)
Likes
3
#5
In China , XianYu is a popular APP among PC enthusiasts.It just like ebay, you can buy plenty of rare staff from it.
2,074 (0.55/day)
Likes
386
Case Corsair 570X
Wow. Wonder if I can just contact XFX and see if they have any of the factory AIO's they'd sell me then. lol. (Looking to keep this card going even after I retire it)
24,996 (5.88/day)
Likes
8,382
#7
Thats the only hsf available.
There are complete cover Waterblocks from alphacool as well
User !
19 (0.07/day)
Likes
3
#8
Now I decide to get a gpu water block only for core , but 64mm x 64mm block seems doesn't exist ? Can I use a cpu water bolck to cool the gpu ?
2,436 (1.64/day)
Likes
2,098
On The Highway To Hell \m/
#9
Well...he's talking about a Vega 56. But I digress. I can tell you from personal experience with one, that the Morpheus II is definitely up to the task. While mine won't do 1700+MHz in most cases, even when it does the Morpheus II typically keeps things at(or, more often than not, well below) 60°C with the fans blowing full tilt. And I'm not even using the "best" fans for the job(ARCTIC BioniX F120). Temps for gaming and graphics benchmarks with clocks @ ~1670/1160 are never more than 53°C(if letting the fans run 100%). The only time I've seen it get up to 60°C was during a ~16 minute GPUPI 32B run with the core @ 1713MHz.
EDIT: I should probably mention I'm using Conductonaut with it too. Which I'm sure makes a HUGE difference. ;)
