I've had nothing but trouble with Asus T100, how to return?
2,076 (0.36/day)
System Name Omen
Processor i7-4710HQ
Cooling Dual fan/heatpipe
Memory 16GB
Video Card(s) 4GB GTX 860M
Storage 256GB PCIE SSD/256GB PNY UHS-1 SD Card
Display(s) 15.6' 1080P
Case Aluminium
Power Supply Brick
Software Win 10
Basically I bought it first the dock touchpad didn't work, the replacement for that was in store and worked fine. A week later the hinge became loose and It didn't hold the tablet in place, the dock doesn't sit even on a table either. It took 6 weeks for just the dock to be replaced, all they replaced was the hinge. Now I just noticed I have a dead pixel and I'm just fed up with this product. I love it as its really a great product, but the fact that so many problems have plagued my experience with it make me want to return it because I'm paying for a product that is kind of faulty. I can either go to store or go the main repairer and try to get a refund or atleast the $600 I paid for it in instore credit. Is this going to be possible to do? I live in Australia by the way. I just think that having so many problems with this product isn't right, and dead pixels are the largest annoyance known to man. It has been almost 3 months since I've bought it and only been able to use it properly for about a month of that time.
I should have went for the surface pro 2 in the first place, which will be my next purchase if I can get a refund for this.
I would think asking the retailer would get you more answers than asking here.
If that doesn't work, contact Asus support.
Im not sure if you can return for a refund, Here in the UK they allow you to send it back within 2 weeks if youre not 100% satisfied with the product. Youre still within shop warranty so id take it there and ask what options are available, hopefully they will refund out of good will if not replace the unit with a fresh one off the shelf.
