Kingston SSD A400 Screeching Sound Noise Issue
GameplaysFan
7 (0.50/day)
i had a noise issue with a new kingston SSD, i did a fix for it, it works perfectly and it isnt a problem for the temperature in the SSD, i did the test many days.
as you can see in this video, the alternative solution worked for me
Fluidz
4 (0.02/day)
This if the noise my ssd makes, as u can see it is quite annoying -
I just want to say thanks for the idea. I was looking at buying an enclosure to put the ssd in, but tried your idea, I wrapped my mx500 ssd in electrical tape, followed by paper towels (lots of it), then another layer of electrical tape, making sure to cover the whole ssd. Temps are fine, average 40c, it worked a treat!
Thanks.
OneMoar
There is Always Moar
7,981 (2.07/day)
Rochester area
System Name RPC MK2
Processor Intel Core i5 9600K@ 4.8Ghz 1.32V
Motherboard Asrock z390 phantom gaming 4
Cooling Enermax ets-t50
Memory CMK16GX4M2B3000C15 16GB DDR4-3000
Video Card(s) EVGA GeForce RTX 2060 XC ULTRA GAMING
Storage 512GB Intel 545s ssd 500GB ADATA SU800 ssd 1TB WD blue
Display(s) Cheap VA panel
Case Phanteks P300
Power Supply HX 750i
Mouse M65 Pro RGB
Keyboard K70 RGB
Software Windows 10 +startisback
yea if your ssd is making ANY Noise its very likely defective and should be returned or replaced
this is NOT normal or acceptable I have never heard of an ssd having coil whine because they don't have have coils ....
732 (0.95/day)
Processor X5690 ES
Motherboard Asus Rampage III Formula
Cooling Thermalright Le Grand Macho RT, TY143
Memory 10Gb G.Skill mix
Video Card(s) EVGA GTX 980 Classified 3988 @ 1495/2001
Storage Intel 545S
Display(s) Hisense 55"
Case Fractal Design Meshify C TG, White
Audio Device(s) Asus Xonar Essence ST
Power Supply CM Silent Pro M2 850
Mouse Zowie EC2 Evo
Keyboard Logitech G15
Software Yes
I had an old Revo Drive that did that.. it is no longer with us.. Also had a Crucial M4 256 that didn't do that, but still died. Guess who this guy doesn't buy from anymore lol.
GameplaysFan
7 (0.50/day)
im agree with you, but im in quarentine, i cant move, then i had to do this haha
