laptop is power throttling for no reason
Mcdip
6 (0.01/day)
Ive got a hp laptop with an i71165g7 and for some reason it throttles down to 18 watts after being under load for no reason without the temperature being too high
it keeps saying its pl1 limited and ive tried changing it to no avail pls help
unclewebb
6,886 (1.21/day)
The 1165G7 is a low power CPU. It is designed to power limit throttle at 15W. If your computer throttles long term at 18W, that is better than average. HP likes to use an embedded controller (EC) to enforce low power limits. In ThrottleStop you can try setting the PL1 power limit to 25W and you can try checking the MMIO Lock box in the TPL window but this might not make any difference if the EC power limits are set lower by HP.
Some ThrottleStop screenshots are a great way to communicate a problem.
Mcdip
6 (0.01/day)
my current settings
dont really understand that because i had a different laptop that was also hp but had no problem taking 45 watts sustained
same cpu too so im just annoyed right now
unclewebb
6,886 (1.21/day)
Check the MMIO Lock box. Do not check Sync MMIO.
Do not check the PP0 Power Limit box. Push OK and fully reboot your computer so the CPU can reset itself.
Different engineers work on different laptops. It is nice when they leave a high power limit like 45W but there is no guarantee that every HP laptop with that same CPU will have the same power limits. Consumers need to do lots of testing immediately and return laptops that they are not happy with.
The cooling does not look great so even with unlocked power limits, 45W looks out of reach.
Mcdip
6 (0.01/day)
Alright is that all i need to change?
The cooling can be supplemented as i have a cooling pad
I reached 95 at 39 watts for a time
And 49 to 50 is idle now due to the cooling pad but even so its just not stable
Another thing is wattage goes higher but clock speed drops .
Its very interesting to me
Mussels
Freshwater Moderator
58,335 (8.33/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
my current settings
Because these CPU's have optional conditions
Personally, I hate this crap and still run a 4th gen laptop because of this stuff. (Also because on the CPU side, performance has barely improved over the years)
Intel Core i71165G7 Processor 12M Cache up to 4.70 GHz with IPU Product Specifications
12W TDP (1.2GHz) with an optional "up-to" 28W (2.8GHz) *if* the manufacturer chooses it
With intels methods of measuring TDP, you can boost above those numbers - but PL1 and PL2 are time limited, so they wont stay there forever
Intel does it so that one product can suit more types of laptops, but they also don't seem to care if manufacturers fail to advertise if the CPU is running in the lower or higher TDP mode, which can obviously lead to false impressions for expected performance of the device.
Edit: Thermal throttle at 100C, but the laptop may throttle before that (Or another component may limit it, like VRM's or the power brick)
Mcdip
6 (0.01/day)
Yeah its hp because the other laptop was a zbook but this is a pavillion its so wildly different
Its infuriating
Mussels
58,335 (8.33/day)
Oystralia
Its infuriating
I went from a quad core i5 to a dual core i7, and swore to never fall for that crap again
Then my brother did the same with a GPU that was the same model, yet had about half the performance since it was a cut down model with the same name
Then i got an AMD crossfire laptop, only to find they'd renamed the GPU series and broke crossfire... and that the onboard was faster than the dedicated card anyway.
Long story short: Yes. Laptops are a nightmare, so I guess always buy from somewhere you can return if possible.
Do you have access to any undervolting controls? Every single W you save off the CPU, will add more MHz
Be it from the CPU, the IGP, memory/controller... I have no idea what BIOS settings you have access to, or what throttlestop settings you can use - Unclewebb is the expert on those
Mcdip
6 (0.01/day)
Sadly with tigerlale voltage regulation is locked at least for now
Tigerlake* and the bios doesnt really have anything i can change so its a no go there aswell
Mussels
58,335 (8.33/day)
Oystralia
Damn, so no IGP underclocking or anything available?
Unclewebb may have ideas, i'm out of my league with this one
Mcdip
6 (0.01/day)
Yep ive done all i cpuld as well i just see no way of getting any decent performance outta this thing so imma just have to live with
