- Apr 29, 2006
- 5,105 (0.73/day)
- Sydney, Australia
System Name | UltraPC |
Processor | E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz) |
Motherboard | ASUS P5Q-e |
Cooling | CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan |
Memory | G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15 |
Video Card(s) | Sapphire HD4850 512mb with ASUS EAH4850 BIOS |
Storage | 2x 500GB Seagate 7200.12 Raid 0 |
Display(s) | Acer AL1912, 19" LCD screen |
Case | Thermaltake Soprano Black ATX case |
Audio Device(s) | Onboard 7.1, Speakers - 5 + Sub + Monitor speakers |
Power Supply | Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails |
Software | Win 7 Pro x64, MSN, CS:Source, etc etc |
I got this Apollo LCD monitor (around 2 years ago), that has recently been having problems, and now is totally dead.
Over the past 3 days or so, the monitor would fade to black as soon as it was turned on. As in, I would turn the screen on, then see the normal picture (of desktop), and from the centre outwards, the screen would fade totally black in about 5 or so seconds. (incuding the RGB/DVI message in the top corner). Around 3 days ago, if i turned it off and on again for 2-3 times, it would work fine, and all would be well for hours.
Its slowly gotten worse over the past couple of days, and now, wont start up properly, no matter how many times i turn it off and on. As soon as i turn it on, the whole centre is black, and within 2-3 seconds, it fades outwards, and the whole screen is black.
Ive tested it on both VGA and DVI, on two different computers, as well as using it as a secondary monitor...no luck at all. Ive even used different power cables, but nothing has helped.
The monitor is a 19" Apollo screen, Model:L191, and "L9DK1" is ticked on the box of it. I dont think they have any branches in Australia, so i dont think i can RMA/repair it, because it wouldnt be worth the $100 or $150 to post it overseas.
Any help is really appreciated!
Pinchy
Pinchy
