Linux/XBMC Live - Frame Pauses
Noobsack
20 (0.00/day)
Processor Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Motherboard Manufacturer: Dell Inc Model: 0R849J Chipset Vendor: Intel Chipset Model: x58
Cooling Fans
Memory 4x1gb Elpida DDR3
Video Card(s) ATI Radeon HD 4850 512m
Storage Seagate 500g ST3500418AS
Display(s) Dell E248WFP 1920x1200
Software Win 7
about 3 or 4 times a movie, the video will pause, sound continues for about 5 seconds, then pauses, then another 5 seconds later everything will do a "fast forward" bit and catch up to where it was. I was thinking this was a video card problem since I'm running a BIOSTAR 9400GT 1024MB DDR-2 DX10.0 GRAPHICS CARD CSVN9402THG1 Link to nvidia video card post where i was suggested to post here
Anyways, I'm running XBMC Live off a 8gig thumb drive.
It's difficult to get specs since My buddy built it and i don't exactly know what is in it, I suppose I could tear it open and write down all the numbers on the stickers. wasn't sure if this is common and someone had a simple answer.
EVGA 132-YW-E178-A1 LGA 775 NVIDIA nForce 780i SLI FTW ATX Intel Motherboard
Brand EVGA
Model 132-YW-E178-A1
Supported CPU
CPU Socket Type LGA 775
CPU Type Core 2 Quad / Core 2 Extreme / Core 2 Duo
FSB 1333/1066MHz
Chipsets
North Bridge NVIDIA nForce 780i SLI
Memory
Number of Memory Slots 4×240pin
Memory Standard DDR2 1066 Up to 1200MHz SLI-Ready Memory with EPP
Maximum Memory Supported 8GB
Channel Supported Dual Channel
Intel Core 2 Quad Q9300 Yorkfield 2.5GHz 6MB L2 Cache LGA 775 95W Quad-Core Processor BX80580Q9300
Brand Intel
Series Core 2 Quad
Model BX80580Q9300
Core Yorkfield
Multi-Core Quad-Core
Name Core 2 Quad Q9300
Operating Frequency 2.5GHz
FSB 1333MHz
L2 Cache 6MB
Manufacturing Tech 45 nm
Voltage 0.85V – 1.3625V
Thermal Design Power 95W
RAM
Mushkin 2x2GB 5-4-4-12
OCZ 2x1GB Dual CH 5-5-5-10
BIOSTAR 9400GT 1024MB 550Eclk 667Mhz DX10.0 DDR-2 DVI HDTV SLI PCI-E x 16X (HDMI ONBOARD)
Product Features
- NVIDIA GF9400GT GPU
- 1024MB DDR2
- Native HDMI output support
- PCI Express 2.0 x16 bus interface
- Support NVIDIA PuroVideo HD Technology
- Complete DirectX support, including DirectX 10 and lower
Product Specifications
ENGINE CLOCK 550MHz
MEMORY CLOCK 667MHz
MEMORY SIZE 512MB
MEMORY TYPE DDR2
MEMORY BUS 128-bit
STREAM PROCESSORS 16
INTERFACE Support PCI-E 2.0 x16
RAMDACs 400MHz
MAX RESOLUTION 2560 X 1600
specs are more than enough. you are running xbmc off an 8 gig thumb drive. start there.
Really... hrmm I was told the flash drive would work fine. Damn. Lol.
Hrmmm, well i'm using all the sataports. Hrmm IDE for the lose! Lol
Would the flash drive really be what is effecting the system? And if so why?
Flash drives have a lower transfer rate and higher read times than hard disks due to the lower bandwidth offered by USB, I believe it's something like that anyway. IDE shouldn't have an issue running this though.
