PEGASUS
- Feb 27, 2022
- 3 (0.00/day)
I think my MB (in an older computer) is faulty. It has an ASUS M4A78-VM MB within AMD3 CPU and 1 x 2GB DDR2 RAM stick. The PC used to work perfectly OK except the CPU fan was a bit noisy when cold starting but soon quietened down. The issues I am having are as follows;
1. Clock will not retain settings when turned off (even with power supply still ON. I replaced the CMOS battery but that made no difference. I swapped the RAM between slots and that too made no difference.
2. On POST I get the ASUS screen then beeps (2 or 3 very quick ones) and an error message on the screen telling me to press F1 for setup or F2 to use default settings. That I know how to handle, but...
3. On the monitor it says I have 1 x USB Keyboard and 1 x USB mouse (correct), but it won't initialise them and the PS2 port also does not work/is not initialised.
Since I have no keyboard or mouse working I can't do anything.
Suggestions - anything worth trying or simply get a new MB? The problem there is finding one that will take the AM3 CPU and DDR 2 RAM as everything now is DDR4.
This is only a spare computer I use for copying old video tapes for later conversion on my main PC.
One other thing - OS is Windows 7 Home (GENUINE) which before it decided to not boot up, kept telling me my copy was not genuine. Any ideas why that would happen?
I am reasonably knowledgeable about computers but I have not encountered this problem before. Help appreciated.
