- Feb 6, 2021
- 2,643 (2.25/day)
- Germany
System Name | Sunk Cost Fallacy |
Motherboard | ASRock B650E Steel Legend Wifi |
Cooling | Arctic Liquid Freezer II 360 Rev. 7 |
Memory | 2x16GB G.Skill Trident Z5 NEO 6000 CL30 |
Video Card(s) | Sapphire Nitro+ RX 7900 XTX Vapor-X |
Storage | WD Black SN850X 1TB + 2x 2TB, 2x 4TB Crucial MX500, 4TB Samsung 870 Evo. |
Display(s) | Alienware AW2723DF, LG 27GR93U, LG 27GN950-B |
Case | Lian Li O11 Air Mini |
Audio Device(s) | Bose Companion Series 2 III, Sennheiser GSP600 and HD599 SE - Creative Soundblaster X4 |
Power Supply | bequiet! Dark Power Pro 12 1500w Titanium |
Mouse | Logitech GPRO X Superlight & G502 X |
Keyboard | Corsair K65 RGB Mini, Razer Black Widow V3 TKL |
VR HMD | Oculus Rift S |
after my NZXT H710 suffered from the good ol' NZXT Torque (literally every screwhole is worn out by fastening them with a industrial drill)
i bought a Meshify S2 on a sale for 120€
i love the case so far and i have noctua industrials 3000RPM (i want to run them at low RPM)
the problem is:
The integrated Fan Hub doubles the PWM Input and fails to deliver any proper signal at below 40% PWM speed (for all Fans. Corsair ML120 Pro, ML 140 Pro, NH D15 Fans, NZXT 120mm Aer Fans and the Noctua industrials)
even a single fan into the Hub on a PWM connector results in at least double the speed that i can set in the bios.
Plugging the same fan in the same PWM header on the motherboard results in exactly what i want. 25% PWM, 25% of the max fan speed.
any ideas? i populated every single fan header instead of comfortably using the fan hub.
the problem is:
