Most power-hungry PCI-Express Video Card with NO power connectors?
Discussion in 'Graphics Cards' started by DanishDevil, Jun 30, 2009.
  1. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,241 (2.31/day)
    2,166
    Granite Bay, CA
    I'm trying to use a video card that will suck the power out of the motherboard, possibly limiting its max OC. I'm just trying to get an idea of what card that would be for the future.
    10 Year Member at TPU
  2. cdawall
    cdawall where the hell are my stars
    Jul 23, 2006
    26,459 (6.39/day)
    7,467
    Houston
    9800gt
  3. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,241 (2.31/day)
    2,166
    Granite Bay, CA
    Linkies please :) And if they're disco'd, some average used prices?
  4. cdawall
    Jul 23, 2006
    26,459 (6.39/day)
    7,467
    Houston
  5. IINexusII
    IINexusII
    Apr 11, 2009
    921 (0.29/day)
    186
    London, UK
    4670 from ati. the performance is almost the same as the 3850 which i have. the 9800gt would be faster though
    DanishDevil says thanks.
  6. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,241 (2.31/day)
    2,166
    Granite Bay, CA
    Is there one that isn't "energy efficient?" That makes me think it would put less strain on the board.
    Anything higher from the red camp that can go PCI-E power-less?
  7. cdawall
    Jul 23, 2006
    26,459 (6.39/day)
    7,467
    Houston
    nope and i now second the 4670 after looking at benchmarks
  8. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,241 (2.31/day)
    2,166
    Granite Bay, CA
    4670's cheaper too. Now my next question, anybody want to donate one to me? :p
    Post up some benchies.
  9. btarunr
    34,222 (9.26/day)
    17,493
  10. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,241 (2.31/day)
    2,166
    Granite Bay, CA
    I remember reading that. Definitely could be a good card to use.
  11. BrooksyX
    BrooksyX
    Jan 7, 2008
    3,923 (1.09/day)
    568
    I remember reading that there was a 4830 that run off the pci-e bus. No external power needed. I have never actually seen one for sale though...
  12. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,241 (2.31/day)
    2,166
    Granite Bay, CA
    Yeah I just looked for one and I can't find one ANYWHERE. Just all reviews. It's basically the polar opposite problem that I normally have :p
  13. largon
    largon
    May 6, 2005
    2,786 (0.61/day)
    435
    Tre, Suomi Finland
    An electrical appliance connected to a power supply will always draw the needed amperage. Meaning OC is not limited by absense of an external power plug, because if the card needs 100W or 150W it will draw it from the slot. The only problem is resistance of the motherboard PCIe power plane and the slot, meaning they will get hot, hotter and even hotter when current increases. Eventually the spot where there's highest resistance will heat up to a point the metal will melt and break the circuit.
    So, no, you can't limit the max OC in this way - unless you count burning the motherboard as a limiting factor.
    hat says thanks.
  14. Semi-Lobster
    Semi-Lobster New Member
    Jul 9, 2009
    352 (0.12/day)
    29
    If you're looking for the most powerful videocard that doesn't need a 6pin, then your best bet would be the Abaltron HD 4830 'Green Edition'
    http://www.techpowerup.com/reviews/Albatron/HD_4830_Green/
    The Green edition is actually MORE powerful than the stock 4830 with 800 shading units compared to 640 on the standard 4830.
  15. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,241 (2.31/day)
    2,166
    Granite Bay, CA
    But where can you buy it? It was posted a few posts up :p
  16. vbx New Member
    Mar 29, 2009
    720 (0.23/day)
    60
  17. DanishDevil
    DanishDevil
    Oct 6, 2005
    10,241 (2.31/day)
    2,166
    Granite Bay, CA
    I won't be needing one of these for a while. Thanks for the input guys, and I'll post a WTB when I'm in need of one.
