- May 3, 2013
- 32 (0.01/day)
System Name | Rubnitron |
Processor | i5 4670k @ 4.3 GHz |
Motherboard | MSI Z87 G45 |
Cooling | Corsair H100i |
Memory | Corsair Vengeance 2x4Gb @ 2133Mhz |
Video Card(s) | MSI 770 2Gb OC Gaming |
Storage | Samsung EVO 250Gb , OCZ Vertex 128 Gb , Toshiba 2Tb HDD |
Display(s) | Asus VG248qe |
Case | NZXT Phantom 410 |
Audio Device(s) | Onboard |
Power Supply | Corsair TX 650m |
Software | Windows 8.1 x62 |
Benchmark Scores | 7480 3DMark Firestrike |
Hello,
I'm planning on getting a new 24inch 60Hz monitor, mainly for 1080p gaming.Budget is around 200€, 250€ max if it's really worth the extra money.
So I need some help with what specs should I look for, LED or IPS panel (although most monitors i can find around my budget are LED), will DVI-D \ HDMI ports will provide better image quality than a standard DVI port? And as for the response time should i look for 2ms?
If its any help, my GPU is an MSI 770 gaming.I'm leaning towards some ASUS\BenQ monitors, like BENQ GL2450HM or ASUS VE247H because they seem like better brands but I don't mind other brands as well.
If you can suggest any monitors around my budget, or some general guidelines on what should i look for, that would be great
