- Oct 6, 2009
- 2,820 (0.53/day)
- Midwest USA
System Name | My Gaming System |
Processor | Intel i7 4770k @ 4.4 Ghz |
Motherboard | Asus Maximus VI Impact (ITX) |
Cooling | Custom Full System Water cooling Loop |
Memory | G.Skill 1866 Mhz Sniper 8 Gb |
Video Card(s) | EVGA GTX 780 ti SC |
Storage | Samsung SSD EVO 120GB - Samsung SSD EVO 500GB |
Display(s) | ASUS W246H - 24" - widescreen TFT active matrix LCD |
Case | Bitfenix Prodigy |
Power Supply | Corsair AX760 Modular PSU |
Software | Windows 8.1 Home Primeum |
ya delta fans are amazing but if i got those it would cost more then the cooler itself lol and arent they really thick? that may cause an issie
but i was thinking about these fans:
COOLER MASTER R4-L2R-20CR-GP 120mm Red LED Case Fa...
i know they arent the best fans out their but will they do the job if u put them in push pull?
the reason y i want red led fans is cause my case is all black and already came with some red led fans
also i see u have your 750 oc at 3.8, what do ur temps run at and what are ur settings at to get that overclock
Actually I have a i7 860 @ 3.6 right now (I will be going allot further I just got it though so I am waiting till I get my other video card back from RMA.)
But anyway.... I had my i5 750 @ 3.8 also had it @ 4.0 and the max I had it was @ 4.25
The temps with the CM Hyper 212+ were as follows...(All done 20 Runs LinX 93% RAM)
@ 3.8 W/1.286 vcore & 1.19 VTT = MAX OVERALL 61c
@ 4.0 w/1.365 Vcore & 1.20 VTT = MAX OVERALL 65c
@ 4.25 w/ 1.40 Vcore & 1.225 VTT = MAX OVERALL 71C
@ 3.8 Each core = 66c/59c/60c/61c
@ 4.0 Each core = 69c/61c/63c/64c
@ 4.25 Each core = 73c/69c/71c/72c
Of course those temps of each core varied by a degree or two at max load. These stability tests were done with a CM Hyper 212+ and the Delta fans. When I was using the CM Excalibur fans the temps were a little higher. But only by a Degree or two.
Plus in all fairness I own a very well ventilated case. So I am sure others with that cooler will have different results that are directly tied to their specific setup.
Not bad though huh?
Oh and if I ran Prime95 The temps were lower after 8 to 12 hours of testing. So I did not even bother to list them.
I know I was blessed with a very good clocking i5 too.
But none the less... those are very good temps if you ask me The CM hyper 212+ kept my i5 750 @ temps under Intel's max Thermals. So I was happy. Of course I also got the feeling that If I went higher... the CM Hyper 212+ would have started to get worse. It felt like I was reaching it's limits at 4.25 Ghz. But since this guy is only planning on doing a very mild overclock. It should be fine for him.
