Need Help. confused +12v and -12v
jigujigu
18 (0.00/day)
Likes
0
#26
OOOHHH
the shop where i buy this computer, they forget about Thermaltake CPU Cooler.
they put standart cpu cooler (from Intel).
is standart cooler from intel not good enough for intel product (Q6600) ???
can you recommendation what branch and series the good cooler for 25$ (below,.. i am running out of my buget :( :( )
i am using mini tower casing. only have 2 air cooler casing 80mm. (1 unit is zalman product)
thank's
Mussels
Moderprator
46,309 (9.30/day)
Likes
13,857
Australalalalalaia.
System Name Daddy Long Legs
Processor Ryzen R7 1700, 3.9GHz 1.375v
Motherboard MSI X370 Gaming PRO carbon (really nice board, bad vdroop under load w/ an 8 core)
Cooling Corsair H155i Pro (yay for maglev fans!)
Memory 16GB 2133 generic @ 3066 C18
Video Card(s) MSI GTX 1080 Gaming X (BIOS modded to Gaming Z - faster and solved black screen bugs!)
Storage 1TB Intel SSD Pro 6000p (60TB USB3 storage)
Display(s) Samsung 4K 40" HDTV (UA40KU6000WXXY) / 27" Qnix 2K 110Hz
Case Fractal Design R5 White Gold edition + RGB lighting
Audio Device(s) Pioneer VSX-519V + Yamaha YHT-270 + Corsair Void RGB, Blue Yeti mic
Power Supply Corsair HX 750i (Platinum, fan off til 300W)
Mouse Logitech G703 + PowerPlay mousepad
Keyboard Corsair K65 Rapidfire
Software Windows 10 pro x64 (all systems)
Benchmark Scores Laptops: i7-4510U + 840M 2GB (touchscreen) 275GB SSD + 16GB i7-2630QM + GT 540M + 8GB
#27
raising the memory voltage wont cause anything to overheat - if something was overheating, its due to something else.
Please use realtemp and say what your idle and load temperatures are for your CPU.
edit: posts where made while i typed this one.
Intels cooler would be enough, but if they messed up the application of grease (Intel coolers are meant to be installed only once, or you have to replace it) it would explain the problems.
Thermaltake to not make the best CPU coolers, i would avoid them. The current favourites for Q6600 cooling are
* Arctic cooling Freezer 7 pro
*Xigmatek (any model, they are all excellent coolers at great prices)
*Thermalright (anything 92mm or 120mm)
* Scythe ninja/Mini ninja - great coolers, but not cheap
(these are the ones i reccomend as an owner of two Q6600's, i have seen many otherwise good coolers, that only gave good temps on two of a Q6600's four cores - not all coolers work well on intels quad core CPU's)
Another edit: i saw that you mention a mini case. That could also be a reason behind the heating. Please look at the Scythe mini ninja or Zalman coolers - they arent the most cost effective, but they both have models that are small enough to fit in small cases.
jigujigu
18 (0.00/day)
Likes
0
#28
I am not overclocker..and use computer for daily game and work.
is Cooler Master Vortex 752 CPU Cooler enough for me.. cost only $22
see this review..
.. cost $32
i am worry about the size,... doesn't it too big for my case (PowerLogic Futura 330).size : 450(H) x 235(W) x 490(D) mm
btw, my motherboad position is vertical, doesn't it too heavy (520 g) ???
thank's
Jigu
4,834 (1.19/day)
Likes
635
System Name The Cube
Processor Ryzen 5 1600
Motherboard Asus Prime B350M-A/CSM AM4 mATX
Cooling Stock Wraith Spire
Memory 2x8gb Crucial Ballistix Sport LT DDR4-2400
Video Card(s) EVGA GTX 760
Storage 256 GB Samsung Evo 850, 1TB WD Blue
Display(s) ASUS PB278Q 27" 1440p LED
Case Thermaltake Core V21
Power Supply EVGA Supernova 550W
Software Win 10 Education
#29
I wouldn't be worried about case size too much, and you can get any aftermarket cooler you want imo, just get some good thermal grease (as5 or mx2) and apply it properly. The stock heatsink is not great for cooling, but there is no way you should be getting temps like that. I really would try to fix that immidiately. Here are instructions for applying the thermal grease. You can use isopropyl alcohol w/ a q-tip to remove the old thermal grease (make sure you remove all of it). And again, make sure all the pins are firmly in, I imagine that is why its messed up now, they are difficult sometimes. If you lift and it gives way somewhere, its a problem. When its snug, you'll know.:)
jigujigu
18 (0.00/day)
Likes
0
#30
IThe stock heatsink is not great for cooling, but there is no way you should be getting temps like that. I really would try to fix that immidiately.
i alread fix the heatsink,. and test again.. the result is still CPU TOO HOT, and give me same temperatur graph... 68 Celcius.
i need more info .. actualy how Celcius the standart CPU temperatur with standart heatsink ???
right now i am ordering Freeze 7 Pro,
thank's
Jigu
4,834 (1.19/day)
Likes
635
#31
Well the cpu temp is not as important as the core temps, which tend to be higher than the cpu temp. That program realtemp I gave you a link to will give you your core temps, and thats really what we need. I'm guessing if your cpu temp is getting up to 70, your cores are probably getting up to 90 or so, and your cores you don't want higher than 70, and if they get above 80 they start slowing down to prevent damage.
Mussels
Moderprator
46,309 (9.30/day)
Likes
13,857
Australalalalalaia.
#32
using realtemp you want the temps to be below 70c at load.
jigujigu
18 (0.00/day)
Likes
0
#33
The shop only have CoolerMaster Hyper 212 in stock. need 1 week for order Freezer Pro 7.
So i decide to buy coolermaster $29, ( out of my budget :banghead: )
this is the report
CPU-1__________________CPU-2__________________CPU-3__________________CPU-4
___
___
___
the result of vcore,3v,5v and 12v give me same result (see my last graph post).
this is result OCCT & RealTemp. (i only have 3 minutes before the shop close, i leave my computer, they will testing againg tomorror).
Before Start (Idle)________Running (3 minitue)
___
this is result VGA Tester and ATI Catalyst Status
Before Start (idle)________Running (3 minitue)
___
tomorror, i wil post a new graph here.
right now, i need more info :
1. is this good cooler ??
2. is temp. my cpu more cool down ??
3. is my VGA card working good ?
thank's very much
Jigu
4,834 (1.19/day)
Likes
635
#34
Thats solid core temps there. As long as your cores stay under 70, you should be fine. Ideally, w/o any oc, you'll want them to stay under 60C. So yeah, those temps look good. Have you tried playing games? Does it still lag?
jigujigu
18 (0.00/day)
Likes
0
#35
Not yet.. The computer still in shop, they will test again tomorrow...
can i detect memory temperatur ... ???,
should i test the memory too ?? (what program for test the memory except the memtest) ???
the new problem come,.. the fan not fix for casing.. too high.. , the case can't close :banghead:
thank's
Jigu
4,834 (1.19/day)
Likes
635
#36
Memtest86. Oh wait, why don't you wanna use memtest? Aw that sucks about the fan. The artic cooler 7 might be smaller. As I said though, the stock heatsink should be ok if your not ocing. You just have to replace the thermal paste and make sure it is firmly attached.
MKmods
Case Mod Guru
5,697 (1.52/day)
Likes
1,735
Nevada
System Name Crossflow III
Processor AMD 965 (4.04Ghz)
Motherboard Asus Crosshair III
Cooling Air
Memory 4 gigs Mushkin 7-7-7-20@1T
Video Card(s) single 9800GT
Storage Raptor 150's in Raid0
Display(s) LG Flatron 24"
Case Custom
Audio Device(s) AuzenTech X-Raider W/OP637
Power Supply Custom modded Corsair 750HX
Software Win 7 64/Solaris Utility
Benchmark Scores 3DMark06--21963 so far
#37
jigujigu, can you post a picture of the side of your case showing the inside of it?
jigujigu
18 (0.00/day)
Likes
0
#39
Oooohhh... i Need help again now..
i Sold the CoolerMaster Hyper 212 coz not fix to my case.
now i buy sycthe shurreken (I can't find artic cooler 7)
but now the result of temperatur is higher more than CoolerMaster Hyper 212
this is the report
___
___
___
it's ok or not ok ?,
should i use ZM STG1 Super Thermal Grease ???
thank's
4,834 (1.19/day)
Likes
635
#40
That seems relatively ok, core 1 seems to perhaps not be getting enough thermal paste contact. Did you just replace it? And what thermal grease did you use? It needs to settle a bit before your temps drop too much.
Mussels
Moderprator
46,309 (9.30/day)
Likes
13,857
Australalalalalaia.
#41
zalmans thermal grease isnt that great, you should get arctic silver 5, A S ceramique, or arctic cooling's MX2 paste (despite the similar names, the last one is a different brand)
