Need help diagnosing the cause of this problem:
183 (0.05/day)
Likes
33
Whitestone, NY
System Name H.O.P.E
Processor Intel Core 2 Duo E8600 @ 4.5 GHz
Motherboard ASUS Rampage Extreme
Cooling Swiftech GTZ
Memory Micron D9GTS (Mushkin) @ 1800 7-6-7-20
Video Card(s) Sapphire Radeon HD4870x2 Watercooled
Storage Velociraptor 150GB/ WD 1 TB
Display(s) Hanns·G 28" Widescreen LCD
Case Mountain Mods Ascension
Audio Device(s) Supreme FX II
Power Supply 1000W Modular Power Supply
Software Windows Vista Ultimate x64
#1
Preface:
My system was running stable for awhile, and while playing the Sims 3 just shut off. After turning it back on I used default BIOS settings to try and figure out what happened. After loading the OS it took about 3 minutes and it shut off again. After a few more tries it got to the point where the power would "flicker" (See video below).
Question:
Could you guys help me figure out what the cause of this issue is? And how I should go about fixing it.
Extra Info:
I tried turning it on with a different cpu (E8600), then tried without RAM, without a HDD, and no Video Card and nothing changed.
Video:
http://www.youtube.com/watch?v=yJ9ssWhEBDI
Note- Video was taken after computer was "turned on", each time the lights come on it starts up and shuts off.
Specs (if they help):
Asus Rampage Extreme
Intel E8500
Mushkin 996601 RAM
WD Raptor X
Watercooled
3,175 (0.65/day)
Likes
898
System Name TheReactor
Processor i7 6700k @ 4.95ghz - delid
Motherboard ASUS Maximus VIII Genie z170
Cooling EK EVO NIckle/Pump, 2xBlackIce GTX 240's
Memory 32GB G.Skill 3200Mhz Cas 14
Video Card(s) MSI GTX 980ti Gaming 6G
Storage Samsung 960 EVO 500GB
Display(s) HP ZR30W - 2560X1600
Case Corsiar 550
Audio Device(s) on board
Power Supply Antec Quattro 1000W
Keyboard Corsair Gaming k70
Check for leaks?
Try a different Powersupply.
183 (0.05/day)
Likes
33
Whitestone, NY
System Name H.O.P.E
#3
I checked for leaks.
Unfortunately I don't have an extra powersupply to test. But the one I'm using is brand new.
mordant80
98 (0.03/day)
Likes
19
West Virginia
Processor AMD Phenom II X6 1090T @ 4GHZ
Motherboard ASRock 890FX DELUXE3
Cooling Swiftech Custom Water Setup
Memory Patriot Viper II 4GB (2 x 2GB) DDR3 1600 (PV234G1600LLK) @ 1667 7-7-7-20
Video Card(s) HIS Reference HD5870 core:1000 mem:1250 / EVGA 9800GTX for PhysX core:792 mem:1152 shaders:1998
Storage WD Black 1TB / Seagate 1TB
Display(s) Acer 23inch 1920x1080
Case LIAN LI PC-P50WB Black Aluminum ATX Mid Tower
Power Supply Rosewill Xtreme Series RX950-S-B 950W
Software Windows 7 X64
Benchmark Scores 3DMark Vantage:P22970 SuperPI 1M:17.382
#4
I'm going with motherboard on this one... though it could easily be the power supply. These are pretty much the only two things left you haven't removed or swapped right? Leak could do it too. Always good to try removing the cmos battery, unplug the power and all that jazz.
555 (0.14/day)
Likes
104
Indiana
System Name Evil Dragon
Processor AMD FX-8320 Vishera @4.7ghz
Motherboard Asus 970 pro gaming Aura
Cooling Corsair Hydro Series H100i V2(fully Lapped). 4 40mm NB/VRM fans. 6 Thermaltake Riing 12 Series fans
Memory 2X8gig GeIL EVO Veloce Series DDR3 1600 @9.9.9.26
Video Card(s) Powercolor Red Devil RX 480 (1400/2100)
Storage PNY XLR8 480gig SSD. Patriot Pyro SE 60gig SSD.
Display(s) ASUS VP228H LED
Case Thermaltake Core V31
Audio Device(s) Onboard Realtek ALC1150 W/Creative Sound Blaster Cinema 2
Power Supply EVGA 850 BQ 110
Keyboard Roccat Isku FX
Definitely a power problem somewhere....
I would does as Zen says. And most definitely try another PS.
If not. I would venture a guess that the power circuits on the MoBo may have went south...
42,800 (9.77/day)
Likes
18,715
Processor i7 8700K
Motherboard Asus Maximus Hero X WiFi
Cooling Water
Memory 16GB G.Skill 3200Mhz CL14
Video Card(s) GTX 1080
Storage SSD's
Display(s) Nixeus EDG27
Case Thermaltake Core X5
Audio Device(s) Soundblaster Zx
Power Supply Corsair H1000i
Mouse Zowie EC1-B
#6
I had the same problem a week ago after I unplugged my rig for the night. I'd start it up and would have the same "flickering" lights. I have no idea why this happened. I reset the CMOS, redid my bios config and haven't had the issue since. Another member (can't recall who) had the same problem too. We are all using Asus Rampage boards. :ohwell:
555 (0.14/day)
Likes
104
Indiana
Sounds like a issue is popping up on Rampages..... :twitch:
183 (0.05/day)
Likes
33
Whitestone, NY
System Name H.O.P.E
#8
I'm going to try to borrow a power supply sometime today to try.
As for now, I'll remove the CMOS, shut power and wait a little then try again.
Just a note, this is my second Rampage Extreme and this one is only a month old. It's ridiculous that anyone should have these problems on a (at the time) >$300 board. </rant>
1,190 (0.36/day)
Likes
276
Latvia
System Name Personal \\ Work - HP EliteBook 840 G3
Processor i7-4790K \\ i7-6500U
Motherboard MSI Z97 Gaming 7
Cooling Noctua DH-15
Memory Corsair Vengeance Pro 32GB 2400 MHz \\ 16GB DDR4-2133
Video Card(s) ASUS RoG Strix 1070 Ti\\ Intel 520 HD
Storage Samsung 850 Pro 512GB, WD Black 2 TB \\ Samsung 256GB SSD
Display(s) BenQ XL2411Z \\ FullHD + 2x HP ZR2440w external screens via docking station
Audio Device(s) Realtek ALC1150 with Logitech Z323
Power Supply Corsair AX860i
Got something similar yesterday on my 3,5 months old PC. It started to lock up every half min after booting up, then it started to stop OS loading, then it started to stop showing bios... did everything i could (cleaning, cable rechecking, cmos reset, checking ram ( didnt beep that i dont have it xD), hdd , gpu... useless). guess mobo said goodbye, it already was acting strange sometimes in the first month of life...
Now i have to think how to get to capital to change it xD Sitting on my old athlon xp pc now...
183 (0.05/day)
Likes
33
Whitestone, NY
System Name H.O.P.E
#10
Hey. after taking out the CMOS battery, and unplugging the powersupply, and a few hour wait it turned on!
Then as I was looking in the case to make sure everything is okay I see a water droplet fall from the video card and hit a black chip on the motherboard, and though I lunged to pull the power, it shorted, and the computer shut off (Just my luck).
Anyway, after that I dried it off with paper towels, fixed the tubing problem (Tube slowly was slipping off), and blow dried it to be certain I did everything I tried before and it worked!
Not only that but I got a few hours of the Sims 3 in too. I guess I'll never know if water is what caused the original problem, but if not I'm sure something will go wrong down the line :p
I just want to say thanks to all of you for helping me out! It really was a day-maker.
~Evangeline
