Need Help Diagnosing Upload Issue
365 (0.08/day)
Auburn Hills, MI
System Name Dell G3
Processor Intel i5-8300HQ
Memory 8 GB DDR4 @ 2666 mhz
Video Card(s) NVIDIA GTX 1060 MAx-Q
Storage 1 GB Evo 960 + 256 GB M.2 SSD
I recently bought a new laptop, all in all I've been pretty happy with it, except that I think its wireless card may be faulty. I'm hoping it's not the case and that it's a software related issue that I can somehow fix, but nothing I've tried has seemed to work.
On most websites, it works perfectly fine. On some sites however it intermittently fails to reach the site. Also when I go to speedtest.net I get the following:
When I run the desktop app as it suggests however I get:
If that was the only oddity I'd think nothing of it, but there are some sites that intermittently load on this laptop but load 100% of the time on other machines on the same network.
Also if I try and stream on twitch on this laptop, it works flawlessly if using an ethernet connection, but doesn't work at all if attempting to do it over wifi.
27,490 (6.12/day)
Change the router channel
newtekie1
Semi-Retired Folder
26,484 (5.21/day)
Indiana, USA
Processor Intel Core i7 8700K@4.8GHz(Quick and dirty)
Motherboard AsRock Z370 Taichi
Cooling Corsair H110i GTX w/ Noctua NF-A14 Fans
Memory 32GB Corsair DDR4-3000
Video Card(s) ASUS Strix GTX 1080Ti
Storage 500GB Crucial MX500 + 3TB with 500GB MX500 SSD Cache
Display(s) QNIX QX2710 1440p@120Hz
Case Fractal Design Define S
Are these other machines also wireless or are the wired?
What router do you have?
Are you connecting on the 2.4GHz band or the 5.0GHz band? Have you tried switching to see if the problem gets better/worse?
If you run an extended PING test pinging your router, what are the results?
565 (1.58/day)
Zadar, Croatia
System Name SloMo
Processor G4560
Motherboard MSi H110-PRO-D
Cooling LC-CC-95 @ Arctic Cooling fan
Memory 2X Crucial DDR4 2400 4GB
Video Card(s) Integrated HD 610
Storage WD 500 GB + Seagate 500 GB + Toshiba 3 TB
Display(s) Lenovo D221
Audio Device(s) Manhattan Flex BT Headphones, Encore P-801 stereo speakers
Power Supply Corsair CX450M
Mouse microsoft office mouse
Keyboard Modecom mc-800m
Benchmark Scores gorstak @ hwbot.org
well it clearly states firewall is blocking your traffic. Outbound traffic is usually allowed in windows firewall, unless you have some third party app, like internet security or something?
365 (0.08/day)
Auburn Hills, MI
System Name Dell G3
The other machines are also connecting wirelessly.
I also swapped out the modem and router I was using for another one to be sure it wasn't related to the router. It was initially a older single-band 802.11n router, but it is now connecting via a 5 GHz 802.11ac connection.
It's also definitely not actually firewall related, as I have no firewall turned on at all. Laptop came with Mcaffee, which I quickly uninstalled. I had replaced it with bitdefender, but I uninstalled that as well to be sure it wasn't causing the issue. Windows Firewall is also deactivated.
I'll check the article 95Viper linked to see if anything in it helps.
565 (1.58/day)
Zadar, Croatia
System Name SloMo
Processor G4560
Have you also tried right clicking the network icon and then running troubleshooting?
Also, do you have anything else wireless related running? Like bluetooth? Maybe a simple factory reset of router would solve the issue...
Also, if all else fails, uninstalling the network device in device manager and then refreshing might also help...
933 (0.27/day)
Essex, England
System Name Dialysis Machine
Processor Ryzen 3900X OC 4350Mhz @ 1.25v
Motherboard Asus ROG Crosshair VIII Formula
Cooling Custom EKWB for CPU, VRM's & Dual GPU's with 2x 480mm Rads
Memory Gskill TridentZ 3600 Mhz C17
Video Card(s) Sapphire Vega64 Nitro+ x2 Crossfire
Storage Samsung 970 Evo Plus 2TB x 2 Raid0 & WD Black 4TB x2 Raid0
Display(s) MSI MPG27QC
Case Corsair 1000D
Audio Device(s) onboard 7.1 HD Audio
Power Supply Seasonic PRIME Ultra 1300w PSU
Mouse Logitech G300s
Keyboard Logitech G19s
Software Windows 10 64Bit
Might be an obvious suggestion, but have you ran wireshark to see what is happening to the packets?
newtekie1
Semi-Retired Folder
26,484 (5.21/day)
Indiana, USA
It clearly says "could". Do you know what that word means?
Find what model wireless card you have and then find the latest drivers from the wireless chipset's manufacturer. Don't use the drivers on the laptop's manufactuer page, those are rarely up to date.
9,203 (3.59/day)
Massachusetts
Processor i5 8600k
Motherboard Asrock Z370 Extreme 4
Cooling Corsair H-110i GTX
Memory 2x 4Gb Crucial Sport LT
Video Card(s) MSI GTX 980 Gaming
Storage Samsung 850 evo 250Gb
Display(s) Dell Ultra Sharp Widescreen 24" 1200P
Case Fractal Design Meshify-C
Power Supply Seasonic Focus+ 750 Gold
Mouse Logitech G502 spectrum
If it works on some websites, and then not on others it's not a physical issue ,its either the website or something else.
You can get a wireless adapter for like eight bucks (if you don't have one already laying around) and plug it into USB port and just test to see if it's your computer or the website...or just plug an ethernet canle in.
Use testmy.net and check your upload speed. Be sure to choose a server that's appropriate
933 (0.27/day)
Essex, England
Case Corsair 1000D
Surely wireshark is going to tell him where the packets are dropping....
365 (0.08/day)
Auburn Hills, MI
System Name Dell G3
I went into recovery settings and selected reset this pc. It worked properly immediately afterwards. Once it synched dropbox though it immediately began erroring out on the upload test again. Even after deleting dropbox's synched files locally it continued doing so. I reset it a second time, and it's currently working properly once again, but not sure if it will continue doing so as all I had actually installed the second time when it started acting up again was Discord and Chrome.
The wireless card on this particular laptop is Intel Wireless 9462.
EDIT: It's doing it once again.
The internet works flawlessly when using ethernet. The upload test doesn't fail, and the laptop can stream gameplay to twitch without a hitch. The issues with its connection are only when on wifi.
As for https://testmy.net/upload I can't even access that site when on wifi.
It seems since rebooting when updating the wireless card's driver that speedtest's upload has stopped failing again and is giving proper results again.
testmy.net however gives this:
I haven't tried Wireshark, but can do so.
It also just started failing to load one of the problem sites again.
https://www.pathofexile.com
That failed to load, I then spammed the refresh button and it eventually loaded successfully.
testmy.net/upload just did the same thing actually, spammed refresh and it eventually did load successfully.
I just took the laptop back and exchanged it for another. Pretty sure it was hardware related as even when resetting it to a fresh install of Windows it continued having the issue. Replacement laptop seems to have no such issues thus far.
