Need help finding monitor.
Discussion in 'General Hardware' started by Saidrex, Aug 5, 2014.
  1. Saidrex
    Saidrex
    Oct 30, 2010
    165 (0.07/day)
    34
    Latvia
    Hello. Could you recommend any good monitors with native resolution 1920x1080, up to 5ms response time. Price range around 150$. Primary use is for gaming. Or at least say which manufacturers I should avoid or which ones to keep eye out when looking for one.
    So far my choice is Benq GW2320 23" IPS/16:9/1920x1080/250cdm2/5ms/H-178,V-178/20M:1/VGA,DVI-D/Tilt,Vesa/Glossy Black/Flicker-Free, maybe someone can find something better.
  2. yogurt_21
    yogurt_21
    Feb 18, 2006
    5,048 (1.21/day)
    1,126
    AZ
    That's a solid screen, not sure you're going to be able to find better for the price. I've been super impressed with my Benq VA panel. For all the nightmare stories surrounding VA I wasn't expecting much out of it. I have to say it may not be an IPS, but image quality is superior to a TN panel it also has no issues with ghosting during gaming or color bleed, or temperature blackout (ie cheap VA's if in the sun will begin to overheat and blackout a portion of the screen) or terrible color quality when viewed from an angle. It's been solid. I highly recomend Benq's panels I'm sure an actual IPS would be even better.
    10 Year Member at TPU
  3. Saidrex
    Saidrex
    Oct 30, 2010
    165 (0.07/day)
    34
    Latvia
    Got LG 23MP65HQ-P. Sorry to bother :D. Please mark as solved and lock. Thank you.
  4. BiggieShady
    BiggieShady
    Feb 8, 2012
    2,532 (1.27/day)
    1,811
    Zagreb, Croatia
    I'm using that screen at work (programming, not graphic design). From that perspective it's a nice monitor, good choice!
  5. Saidrex
    Saidrex
    Oct 30, 2010
    165 (0.07/day)
    34
    Latvia
    yeah, consulted specialist and he recommended it, told me to add little extra and get good monitor than skimp on few $ and get some sh*t :laugh:
