ae86trueno
- Aug 18, 2008
- 26 (0.00/day)
- Auckland, New Zealand
Processor | Intel i7 920 1366 Bloomfield |
Motherboard | Asus P6T |
Cooling | CoolerMaster V6GT |
Memory | 6GB G.Skill F3-12800CL8 DDR3 |
Video Card(s) | Sapphire ATI HD5850 1GB DDR5 |
Storage | WDC 500GB |
Display(s) | Samsung SyncMaster 305T Plus |
Case | Generic Case |
Audio Device(s) | Onboard |
Power Supply | Corsair HX850W |
Hi guys,
I just stuffed up my USB flash drive.
What happened I was cleaning my PC, removing cables etc.. and for some reason I inserted the cable for USB infront of the case inverted (the cable for the pin USB 5 & 6 was inverted.. I taped all 8 pin together to help putting it back easier but when I plugged it back I made mistake by inserting it upside down.. so kinda like USB 5 pinned to 6 and 6 to 5 and the order reversed - data+ data- +)
I only noticed after I plugged my USB flash drive and now the flash drive cannot be detected.. its like nothing at all when it plugged in.. I'm sure it was shorted.. anyone had this before and if there is any chance to recover the data?
Thanks for help... I know the chance is next to none..
