Need help picking parts of a new PC 1200$usd budget
heyflass
2 (0.33/day)
Budget (including currency): 1200$ usd but can go a little bit higher
Country: USA
Games, programs or workloads that it will be used for: Valorant Rust Overwatch - have a seperate pc that can do workloads
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):
I'm very confident i can get everything retail so don't worry about that.No peripherals needed. I have a pc that's for workloads so this pc is just for gaming. 1200 is the budget but can go a little higher
Country: USA
the monitor its with is 144hz and 1080p
198 (2.18/day)
Processor AMD Ryzen 5900X (PBO enabled, no other OC) + Alphacool waterblock
Motherboard ASUS ROG Strix B550-I Gaming
Cooling custom loop: 360mm XSPC & 360mm Alphacool radiators & Noctua NF-F12 fans; NF-S12 chassis fans
Memory 32GB Corsair Vengeance DDR4-3600 (no aRGB)
Video Card(s) ASUS TUF Gaming GeForce RTX 3080 OC 10GB + Alphacool waterblock
Storage two m.2 SSDs, 2GB SATA SSD, 8GB SATA SSD
Display(s) LG OLED55C1PUB 4K@120Hz TV
Case Lian-Li O11D Mini
Audio Device(s) onboard Realtek chip
Power Supply SilverStone SX800 SFX-L
Mouse Glorious D Minus
Keyboard Keychron C1 tenkeyless (Gateron Reds)
VR HMD Menlo Park, CA dogchow (Oculus Rift S)
Software Redmond, WA dogchow (Windows 10 Pro, $7 from Keysoff)
Benchmark Scores My system matches standard results. I use benchmarks to set fan curves; I don't care about scores.
Read this thread:
paying special attention to comment #6 by ThrashZone and comment #10 by HD64G concerning prioritizing GPU acquisition.
Buy your GPU first since it is the most difficult part to acquire then come back and ask about how to spend the remainder of your budget.
You should also specify if you have extra parts laying around (and which ones).
Best of luck.
132 (5.74/day)
Retail at MSRP? Or something close to that ? If yes then I agree, get gpu first , otherwise you’ll have to go prebuilt , crazy that prebuilts are becoming the better option nowadays.
462 (1.97/day)
Alaska USA
You can DL the free version of Windows 10 from the MS site.
https://www.newegg.com/black-fractal-design-focus-g-atx-mid-tower/p/N82E16811352069
Fractal Design Focus G Black ATX Mid Tower Computer Case $49.99
Exhaust fan for that case.
ARCTIC P12 PWM - 120mm Case Fan $7.99
https://www.newegg.com/super-flower-leadex-iii-sf-550f14hg-550w/p/1HU-024C-00008
Super Flower Leadex III 550W 80+ Gold Modular Power Supply $69.99
https://www.newegg.com/p/N82E16813157978
ASRock B560M PRO4 $99.99
https://www.pcnation.com/web/detail...6-core-2-90-ghz-processor-oem-cm8070104290716
Intel Core i5-10400F $144.35
https://www.amazon.com/DEEPCOOL-GAMMAXX-400-Blue-Compatible/dp/B00JQ2YDCY/
DEEPCOOL GAMMAXX 400 CPU Air Cooler $24.99
https://www.amazon.com/dp/B07T637L7T
TEAMGROUP T-Force Vulcan Z DDR4 3200MHz 16GB (2x8GB) CL16 $67.99
Team Group CX2 2.5" 1TB SATA III 3D NAND Internal SSD $77.99
EVGA GeForce RTX 3060 XC Gaming 12GB $749.99
Total: $1293
https://www.asrock.com/mb/Intel/B560M Pro4/index.asp
https://www.fractal-design.com/products/cases/focus/focus-g/black/
heyflass
2 (0.33/day)
EVGA GeForce RTX 2070 Super FTW3 Ultra+ OC $616.90
Total: $1160
Hey, thanks for helping me. I think i can get everything at retail and i was wondering if you could make a new build or incorporate some of the stuff from this build into it but with retail price guidelines. Like price a rtx3060ti and 399$.
462 (1.97/day)
Alaska USA
GPU
https://www.bestbuy.com/site/nvidia...-card-steel-and-black/6439402.p?skuId=6439402
PSU
https://www.newegg.com/super-flower-leadex-iii-bronze-sf-650r14he-650w/p/1HU-024C-00017
Better cpu cooler
Faster SSD.
Better case (use that Arctic 120mm fan I posted up above for an exhaust fan).
https://www.newegg.com/black-phanteks-eclipse-p400a-atx-mid-tower/p/N82E16811854085
Better board w/better VRM's which allows you to run that cpu with the power limits turned off in the bios.
https://www.newegg.com/p/N82E16813144396
https://www.msi.com/Motherboard/MAG-B560M-BAZOOKA
AsRock
TPU addict
17,309 (3.33/day)
UK\USA
Processor 2500k \ AMD 3900X+NH-D15
Motherboard ASRock Z68 \ ASRock AM4 X570 Pro 4
Memory Samsung low profile 2x8GB \ Patriot 2x16GB PVS432G320C6K
Video Card(s) eVga GTX1060 SSC \ XFX R9 390X
Storage 2xIntel 80Gb (SATA2) Crucial MX500 \ Samsung 860 1TB +Samsung Evo 250GB+500GB Sabrent 1TB Rocket
Case HTPC400 \ Thermaltake Armor case ( VE2000BWS ), With Zalman fan controller ( wattage usage ).
Audio Device(s) Yamaha RX-A820 \ Yamaha CX-830+Yamaha MX-630 Infinity RS4000\Paradigm P Studio 20, Blue Yeti
Power Supply Seasonic Focus 650w \ Seasonic 750w MKII
Keyboard Logitech K120 \ ROCCAT MK Pro ( modded amber leds )
Total: $1160
2070 Usually ships within 5 months.
462 (1.97/day)
Alaska USA
And if you really want to go the extra mile than this cpu which is going for $30 cheaper atm than the 5600x.
https://www.ebay.com/itm/203371799302
Review of that cpu w/benchmarks.
