need help with overclocking ryzen 5 3600
flipflop
3 (0.01/day)
I just got the chip a few days ago, and I used AMD ryzen master to overclock it manually. 4.425 gigahertz on all cores. voltage 1.2375 .
I ran Cinebench 4025 points and single core 516. The temperatures never really got above 70 c during cinebench.
My question is if I'm not going above 70 c and my voltage is low is there still a chance my CPU will have degradation from the overclocking. 1.2375 doesn't seem like it's too high of a voltage but I'm no expert any advice would be gratefully appreciated thank you.
1,268 (0.49/day)
Grunn
System Name Indis the Fair
Processor R5 3600 (PBO 150/130/130, 73c temp limit, FCLK/UCLK 1866)
Motherboard Asus Prime X470 Pro
Cooling Heatkiller VI Pro, VPP755 V.3, XT45 240mm, 2xA12x25, Arctic P14 case fans
Memory G.Skill Ripjaws V 2x16GB 4000 16-19-19 (b-die@3733 14-15/9-13-26-36 1.45v)
Video Card(s) EVGA 2080 Super Hybrid (A12x25 fan)
Storage 860EVO 500GB, 660p 1TB, WD Blue 3D 1TB, Sandisk Ultra 3D 2TB
Display(s) BenQ XL2430T, Dell P2417H
Case Phanteks Enthoo Pro M
Audio Device(s) DT770 Pro, Topping A50, Focusrite Scarlett 2i2, Røde VXLR+, Modmic 5
Power Supply Seasonic 860w Platinum
Mouse Razer Viper Mini, Razer Gigantus
Keyboard GMMK Fullsize v2 (Gateron Browns)
Software Win10 x64/Win7 x64/Ubuntu
Depends on LLC.
You need to keep in mind that manual voltage on Matisse disables on die LDOs and power gating which means that the maximum voltage you can sustain is lower.
flipflop
3 (0.01/day)
Im runing a ryzen 3600 with Tomahawk mag b550 MB and 16 GB 3600 speed memory. Not sure what My LLC is set to. I need to do more reading about this stuff, i dont even know what LLC is realy.
I was wrong about my temps it never gos past 63C when doing cinebench not 70c.
decided to lower my frequencie from 4.425 down to 4.4 and my volts from 1.2375 to 1.225 . I really don't want to damage the processor so I'm hoping the low voltage will improve my chances.
I get the feeling from reading there's two schools of thought on static over clocks for the ryzen 3, some say it's okay other say don't do it.
My ryzen chip is new and I imagine the silicone is it better quality, so maybe it can withstand overclocking more so than the newer chips.
Plus low thermals and low voltage I've gotten pretty decent scores on cinebench so I know it's functioning well.
1,159 (0.27/day)
Austria, Europe
System Name Bang4Buck
Processor AMD Ryzen 9 3900x
Motherboard MSI PRESTIGE x570 CREATION
Cooling EKWB Phoenix 360 Push/Pull
Memory 32Gb 4400Mhz Patriot Viper Steel(Samsung B-die) @ 3800Mhz 16-16-16-32-48-1T @ 1.38v
Video Card(s) EVGA GeForce GTX 1080 Ti SC2 Gaming, watercooled with EKWB
Storage Adata SX8200Pro 512Gb/2x Crucial P1 1Tb/Samsung 840 EVO/6Tb Raid -HGST Enterprise/IronWolf 8Tb/
Display(s) Samsung UE49KS8002 4K HDR TV (US - 9 series)
Case Fractal Design Define R6 Black Usb-C
Audio Device(s) HDMI out to Denon X4400H reciever, 2x Dali Zensor 7, Dali Zensor Vokal, 2x Dali Zensor 1, Yamaha Sub
Power Supply Seasonic Prime Ultra 750W
Mouse Logitech G305 Lightspeed
Keyboard Logitech K520
Benchmark Scores http://www.3dmark.com/spy/10026304
At 1.2375v you are fine. The chip still downclocks and lowers voltage when not under load, so you should have no negative impact. Have fun with your chip and don't worry about it.
194 (0.26/day)
System Name Violet
Processor AMD Ryzen 5800X
Motherboard ASRock x570 Phantom Gaming X
Cooling Be quiet! Dark Rock Pro 4
Memory G.Skill Flare x 32GB 3400Mhz
Video Card(s) Sapphire RX 5700 XT Nitro+
Storage Western Digital WD Black SN750 1TB
Display(s) 3440x1440
Case Lian Li LANCOOL II MESH Performance
Mouse Razer NAGA TRINITY
Keyboard Corsair K95 RGB
Software Windows 10 64bit
Max v-core is 1.35v, so your fine with that voltage.
flipflop
3 (0.01/day)
cool so I can push the clocks more as long as i dont go over 1.35v? i had up to 4.5
