- Mar 15, 2017
- 115 (0.06/day)
It's gonna be a fairly long one, so tl;dr for the lazy: old water-damaged long ago laptop suddenly won't boot from SATA, boots fine from USB, have ideas but need more
Years ago I received this old Acer Aspire AS 1410 as non-working gift with supposed water damage - owner couldn't recall precisely. Specs for spec's sake:
11.6" 1366x768 screen, Celeron 743 single core @ 1.30GHz, 2x2GB DDR2, 250GB HDD.
If I can remember correctly (it was a good while ago) in the beginning it didn't work for me either. I bought a replacement motherboard, but that also was no good. I put the original motherboard back in and left it sitting for a while. Then when I randomly decided to try it out, it worked fine. I played around with it a lot, it was stable - booted fine and ran fine. I replaced the damaged keyboard, reinstalled a fresh OS copy and gave it to my dad as a present.
My dad used it for a long time, however felt it was slow, so decided to upgrade it a bit. He bought some more RAM (2+1GB became 2+2GB) and a SSD. The guys at some PC shop handled the replacement. My dad says the laptop worked fine for a week when suddenly it refused to start booting from the SSD. He gave up on it, bought another laptop, took out the SSD and put it there, and returned the HDD to the faulty Acer.
What I found out after testing it:
- Starting the laptop results in either a message that no boot device is found or a hard lock of the whole machine after a brief HDD activity flash
- HDD is fine - SMART is good, tested and boots fine on another machine
- HDD ribbon cable looks fine
- HDD visible and listed in BIOS
- IDE/AHCI setting in BIOS makes no difference
- BIOS is updated to most recent version (not me)
- Replacing HDD with known good SSD and attempting to install Windows results in hangs and/or no device visible when it's time to specify install path
- Booting Ubuntu from USB works fine, HDD is visible, can read/write to it
- Booting same HDD from external USB adapter almost works, hangs at Windows logo (not a problem, I know it's not made to boot from USB anyway)
What I'm planning to do:
- My first thought was to remove the Mini PCIe WiFi module, install a small SSD there and boot from it. However, the BIOS boot list doesn't include the Mini PCIe slot, so this is probably a dead end. Correct me if I'm wrong.
- Plan B was to use an external HDD and install Ubuntu or Windows on it, but carrying the HDD everywhere would be a chore and the cables are a mess...
- Plan C was to just install Ubuntu on a USB flash drive and call it a day, but it would be a tad slow, and what's worse - I will always fear breaking the drive or the USB port if I hit it by accident
- Plan D, my current one, is to sacrifice one USB port: I could fill the port with something non-conductive in order to block it, solder some wires on its internal side, run the wires to the empty HDD space inside and solder the wires to a M.2 to USB adapter and install it there with some small SSD inside - I think I have just about enough space to cram it in there.
Why am I even doing this?
Apart from the SATA boot issues, the little guy seems to work absolutely fine -- I'm even typing this post on it right now! The other day I used it to go online shopping and browsing for hours upon hours. It's comfortable, the battery can still last for ~1.5-2 hours, the keyboard isn't bad for what it is, it's got an HDMI port for multimedia and it's cool & quiet. It deserves to get the zombie treatment and live a good after-life!
It could be used as a non-critical backup machine or given to some non-demanding family member.
Crazy ideas are welcome.
P.S. Just noticed it doesn't want to properly wake up after being suspended -- might be a temporary thing or related to opening it to remove the HDD today. Powers up with no display or activity. Either way, no big deal right now.
