need motherboard advice for a micro atx case
killatia
210 (0.04/day)
Likes
2
hudson, fl.
Processor athlon64 x3800 oc'ed to 2.5 ghz
Motherboard ecs kn1-lite
Cooling ARCTIC COOLING Freezer 64 Pro
Memory 2 gig gigaram ddr 400
Video Card(s) geforce8600gt
Storage raptor 74k and 160 gig harddrive
Display(s) 19 inch lcd monitor with resolution of 1440x900
Case Antec case
Audio Device(s) sound blaster xi-fi
Power Supply 650 watts antec power supply
Software windows xp pro.
#1
i got an Antec LifeStyle ARIA case the other day and i was wondering if there any good micro atx motherboard to get? also the power supply has a 20-pin power connector and i know that motherboards are starting to come out with a 24-pin power connection; would that be a problem?
killatia
210 (0.04/day)
Likes
2
hudson, fl.
Case Antec case
#3
thats not a bad motherboard, but i am looking for one with socket 939 though.
3,651 (0.74/day)
Likes
341
Little Rock Arkansas, United States
System Name Monolith
Processor Intel Xeon E3110 Wolfdale@3.5GHz
Motherboard MSI P35-Neo
Cooling Active Air
Memory 4GB DDR2 800
Video Card(s) Sapphire HD 3850 512MB PCI-E
Storage 1 x 80GB Internal, 1 x 250GB Internal, 1 x 40GB External
Display(s) Acer X203w
Case Generic black case with locking front bezel
Audio Device(s) Creative SB Audigy 2 ZS
Power Supply 500 Watt Seasonic M12
#4
killatia
210 (0.04/day)
Likes
2
hudson, fl.
Case Antec case
#5
3,651 (0.74/day)
Likes
341
Cooling Active Air
Memory 4GB DDR2 800
#6
As long as you have a 12V connector you can plug the 20-pin into the 24-pin slot, then plug your 12V into the 12V connector on the motherboard.
I don't think I would go with the ECS Board. I'm not confident with ECS' reliability, and frankly there are better chipsets than the Radeon XPress 200.
Poisonsnak
362 (0.07/day)
Likes
18
Saskatoon, SK
Processor FX-8150
Motherboard Gigabyte 990FXA-UD3
Cooling Thermalright Ultra-120 Extreme lapped & shimmed
Memory Patriot Viper Extreme 8GB DDR3-1866 9-11-9-27 1.65V
Video Card(s) MSI 6950 2GB Twin Frozr II @ 6970 875/1375
Storage Crucial M4 0309 64GB
Display(s) Dell U2410
Case Corsair 650D
Power Supply Corsair AX750
Software Windows [8] Developer Preview
#7
The aria is a nice case, I have one with a socket A board in it and it runs pretty well. One thing to consider with motherboards though is my board (K7S41GX) puts the CPU socket right under the aria's PSU and the relatively small stock heatsink just barely fits.
So definitely look for a board with the socket near the middle instead of at the same edge that the PS/2 ports, etc. are on.
Also I think the 24-pin connector adds 1 each +12V, +5V, +3.3V, and GND, the 20-pin already has a lot of the last 3 so as long as you go with Thermopylae_480's advice on the 4-pin 12V you should be fine.
