brandonwh64
- Sep 6, 2009
- 19,542 (3.66/day)
Here is the ram i have - Corsair TWINX Dominator Dual Channel 4096MB PC12800 DDR3 1600MHz Memory (2 x 2048MB)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3424736&CatId=3361
TOday sometime i will hookup my Ultra LSP 650W psu and see if it will do better
Primary timings:
9-9-9-20-4-27-8-4
9+9+9=27.
9+27=36(TRC)
TRTP should be 6.
TRRD and TWR are fine, but some sticks require TWR of 10 @ 1600mhz
secondary timings:
Currently
8-10-4-3-3-110-0
I run 8-2-5-4-4-110-110(110/110 @ 90/90 for 1333mhz)
I must verify the bolded timings, will do so with an edit.CONFIRMED
All that said, you should be able to just bump up multi, leave all else @ stock, and not even worry about it. something is definately amiss here.
as erocker said, those volts need no adjsutment for me, even up to 260 on that board, my Crosshair3 will hit 300mhz "FSB" with stock.
500w PSU is pushing it, IMHO, with what you got..maybe just that alone is your issue, but you should be able to get 3600mhz with jsut a multi jump....
Also, what dominator sticks do you have exactly? 2.00v is pretty high...
