need to hardware gpu accelerate a chinese mouse cause it lags the pointer movement
801 (0.16/day)
UT,US
System Name Asrock 2012
Processor FX 8350 4.2Ghz no turbo
Motherboard ASRock 970 PRO3 AM3+
Cooling Corsair H70 for CPU
Memory 32GB DDR3 1960Mhz
Video Card(s) NVIDIA 1080 with stock fan
Storage 1TB GIGABYTE SSD NVME PCIE 2.0 + Samsung SSD Evo 850 250GB with Ubuntu + Samsung SSD 860 500GB win7
Display(s) LG HDR 31.5"
Case Big Black Tower
Audio Device(s) Realtek audio + Audigy 2 ZS platinum
Power Supply CORSAIR RM850X
Mouse microsoft intellimouse usb to ps/2
Keyboard Logitech
Benchmark Scores +
see videos. I need some acceleration. ¿how to?
Dude get rid of that mouse and get a reputable unit.
you're saying it's cause is a cheap mouse I get lag? i found a bluetooth wifi adapter iwas gonna connect to a 1x but this 9 pin circuit is struggle cause can't find a port for it. it looks like the Intel 9 pin header standard. foto.
Are you on drugs? Always say no to drugs.
I still get lag even from a logitech g604 bluetooth mouse connected to my axe3000 wifi/bluetooh pcie 1x adapter
I think is either normal or my cpu is old or mobo combination is old, I'll try it later on a newer 2017 icore7 cpu and report what I feel i get.
UPDATE:
-I get lag even on a chinese mouse wired on the 2017 i7core cpu (i forgot to check details like what port is it connected usb2.0 or 3.0)
-I get lag on my 2011 phenom ii with both logitech bluetooth g602 and chinese mouse (wired) at low resolutions such as 1024x768px altough the wired chinese mouse seems to give me less lag than the wireless logitech g602 but both give me lag at higher 3000~px resolutions.
-I'll look online what mouses are killer for performance.
Its the rest of your system. You need a serious upgrade, save your money for a complete ryzen 5000 build.
i don't know really cause the 2017 was bought by my sister as a serious upgrade. it's using a cheap Chinese mouse tho but i doubt it's that.
my i7core 2011 laptop usb 2.0 gives me no lag with the Chinese wireless mouse at 1366px resolution and the same mouse on my 2011 desktop phenom usb 3.0 with the same resolution gives me lag... what can it be? my desktop is using a much better gpu
the 2017 desktop using the wireless chinese mouse gives me no lag on a 1920 1080 resolution (same with the wired mouse) I don't know why I said it gave me lag. I also don't get lag on my 2015 laptop with another wireless chinese mouse of the same type as the one used by the 2011 laptop.
the problem is the phenom might be the buses are old. I just bought a 850w evga t2 power supply for it thinking I'd overclock the cpu.
From the video, I can't see any input lag from the mouse. That could be me or the framerate of the video or just that it's not noticeable unless one has the mouse and monitor in hand.
I would check the following: polling rate for the mouse, ghosting on the monitor on testufo, and or a Java or web based mouse latency test for your mouse.
it was just the refresh rate of my monitor it was set to 30hz after changing the desktop resolution higher than 1080p. Please mark this thread as solved. It's smooth again after reverting to 1080p. By the way Wow looks great again
