CDdude55
Crazy 4 TPU!!!
- Jul 12, 2007
- 8,178 (1.33/day)
- Virginia
System Name | CDdude's Rig! |
Processor | AMD Athlon II X4 620 |
Motherboard | Gigabyte GA-990FXA-UD3 |
Cooling | Corsair H70 |
Memory | 8GB Corsair Vengence @1600mhz |
Video Card(s) | XFX HD 6970 2GB |
Storage | OCZ Agility 3 60GB SSD/WD Velociraptor 300GB |
Display(s) | ASUS VH232H 23" 1920x1080 |
Case | Cooler Master CM690 (w/ side window) |
Audio Device(s) | Onboard (It sounds fine) |
Power Supply | Corsair 850TX |
Software | Windows 7 Home Premium 64bit SP1 |
Hey guys,
I have a project due next month where i have to design a large company network that has 7 locations across the U.S., each location has 200 employees expect for the HQ which has 400.
Each location needs to be on it's own IP network and each location as 5 departments, Accounting, Finance, HR, Marketing and Customer Service, so should i use a VLAN to separate each department on a switch? And would i need 5x 48 port switches to connect them all up?
The company also owns a block of class B addresses, 150.15.0.0/16 and i need to map address blocks to each location. Does that mean that the company has 150.15.0.1-150.15.255.254 address available for static IP addressing?
And would i buy both UTP and STP cabling to the nework?
The company will also have an FTP server, Web server etc, would i put those servers at the site in the middle of the county for latency purposes or keep then at the HQ which is all the was on the east cost?
Remember that this isn't for a real company, so don't sweat it.
