New build with Ryzen 5 3600 freezing.... Help!!
Status
Not open for further replies.
Low quality post by eidairaman1
Dude, read my thread on reddit first, then answer. I tried all of that already MULTIPLE times.
It was fortunate i read your TL wall here lol.
Low quality post by FinneousPJ
Try a Linux, it might be a Windows issue.
Low quality post by spectatorx
Same under linux, even less predictive. Kernel version doesn't matter if it is any 4.x or 5.x.
Let's keep it on topic and wait for the OP's post back once he is up and running.
Do not hijack a thread... if you are having a problem start your own thread to find help, as it confuses things.
Thank You.
Hi, as per the title, I just wanted to close down my original thread but it has already been closed by someone.
I just want to say thanks to everyone that gave me advice. It is very much appreciated.
The solution was pretty simple.....
I received the items back from the retailer that I had sent for RMA. They were tested and no fault found. I installed everything back in the case but this time rather than running my windows 10 pro CD I downloaded update 1903 and put it on a usb stick via windows media tool. Installed fine. Once up and running I went straight to AMD website and installed the latest B450 chipset driver. All fine. Corrupt windows install.
So after playing around a bit I have now got a perfectly stable PC with the 3600 running @ 4.0 ghz at 1.25volts. After 3 hours of prime95 hitting 71 degrees Celsius with 22 degrees ambient.
Very happy with the results.
Just wanted to say thanks again to everyone for the help.
Matt
Status
