No sound help
Discussion in 'General Hardware' started by Sky, Feb 7, 2007.
  1. Sky New Member
    Dec 31, 2006
    133 (0.03/day)
    5
    i recently got a new case. so i placed everything i had into the new case. now that i boot windows vista up, theres no sound. before there was sound when i had the old case. i use the onboard sound of the asus p5n32-sli se deluxe mobo.
    i checked:
    onboard sound is enabled in the bios.
    volume is up to the max.
    connections are correct.
    sound device is enabled.
    reseted the cmos.
    driver was reinstalled.
    tested the device (i can see the volume meter go up and down which indicates there is sound)
    still....cant hear anything. any advice? i dont want to buy a sound card if there's a fix. thanks.
    10 Year Member at TPU
  2. k0rn_h0li0 New Member
    Feb 1, 2007
    1,180 (0.31/day)
    46
    Hometown CALI, Current WI.
    well if its enabled check the control panel settings to see if its turned up and on
  3. Sky New Member
    Dec 31, 2006
    133 (0.03/day)
    5
    yeh it's turn on and turn up to the max. on the OS and the speaker volume controls.
  4. k0rn_h0li0 New Member
    Feb 1, 2007
    1,180 (0.31/day)
    46
    we need more people to get in on this about vista cause it just came out and so many people have problems with it already
  5. DR.Death
    DR.Death New Member
    Jul 10, 2005
    1,737 (0.39/day)
    64
    Canada
    go into the sound control panels And see if it is selected
  6. Sky New Member
    Dec 31, 2006
    133 (0.03/day)
    5
    yup its selected.
