Noctua Presents Chromax Line NF-A12x25 Fan, NH-U12A Cooler and Heatsink Covers
5,432 (3.25/day)
Norway, currently in Lund, Sweden
System Name Hotbox
Processor AMD Ryzen 7 5800X
Cooling Aquanaut + Laing DDC 1T Plus PWM + Corsair XR5 280mm + 2x Arctic P14
Memory 32GB G.Skill FlareX 3200c14
Video Card(s) PowerColor Radeon 6900XT Liquid Devil Ultimate, UV@950mV/2050MHz/180W
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Keyboard Cooler Master MasterKeys Pro M w/DSA profile caps
Bullshit. As I posted in the relevant thead, the ”noise normalized” results are calculated incorrectly.
If we try to look at the data as @VSG measured them, and not fuck up the analysis of said measurements, it is clear that the T30 is better only at high noise levels.
I'm not looking at noise normalized results, I'm looking at airflow and noise results at fixed fan speeds. At 1000rpm, the T30 is listed at 26CFM vs. 24.2CFM for the NF-A12x25 (I mistakenly looked at the airflow number for the NF-F12 in my previous post, but the difference isn't that huge), while the noise measurements at that speed are 30.6dBA vs. 29.1dBA. Now, this doesn't tell us anything at all about the sound signature, which is very significant, but those numbers still show that the T30 delivers noticeably more airflow at the same speed for an unnoticeable increase in noise. It's not a massive difference, but it's clearly there. As for your graph, that's a rather problematic presentation as it relies on unaligned data points that don't correspond with any of the axes - if I didn't know those data points were based on RPM, it would look like you had picked four entirely random measurement points. For a full comparison, we clearly need more data points - 100rpm intervals, for example. But it's still safe to say that the T30 delivers more airflow at 1000rpm for slightly (and not likely to be noticeably) more noise, while the NF-A12x25 still clearly wins out below 1000rpm. IMO, either fan will likely be fantastic - and I completely agree with @Chrispy_'s summary above. There are several good options out there.
376 (0.48/day)
as for comparative performance, apples to apples, exact build to exact build, the T30s provide about 2C better cooling for Xeons at same RPM range.
But at same noise range, they lose. According to the TPU review measurements anyway.
129 (0.03/day)
System Name VENTURI
Processor Dual Xeon 8280L 56 cores /112HT
Motherboard Asus c621e Sage, Version 2.1, bios 9906
Cooling Air, noctua, heatsinks, silent/low noise, phanteks T-30
Memory 1.5TB 2933mhz LRDIMM ECC REG
Video Card(s) 2x 3090 FE RTX SLI
Storage Rocket 4Tb and 4x Micron 9300 (51.2 TB) Raid
Display(s) Asus ProArt PAU32UCG-K
Case TT miniITX P1 (SFF)
Audio Device(s) harmon Kardon speakers
Power Supply 1600 AXi digital (silent)
Mouse TT BMW LM10
Keyboard Corsair
Software MS 2019 Data Center Server, Ubuntu, dev MS Data Center 2022
Benchmark Scores Cinebench R23 106,400 GravityMark 70,668
at same RPM, they seem just as quiet, bare in mind I've never needed to run the T30s at their max 3000 RPM (then again the Noctuas do not have a 500-3000 rpm range) so maybe at 2000RPM the noctuas may be quieter. But - at the 500-1300 rpm range the T30s seem just as quiet and give about 2C better cooling. Yes, 2C isn't much and for many its not worth the effort, but for me it was.
376 (0.48/day)
Yeah, it would be nice if TPU would give actual noise normalized results (as in fixed noise level), or tighter intervals.
I don’t give a rats ass about rpm speeds, only performance to noise ratio, and neither should anyone else for that matter.
The T30 and A12x25 are both very good fans, it just irks me when people post things like ”T30 has better airflow”, because it seems not to be universally true.
Just run the noctuas at ~200 rpm more than the phanteks and you have an equal performance and still less noise at 500-1250rpm. Both are quiet enough and powerful enough for most people.
129 (0.03/day)
System Name VENTURI
Mouse TT BMW LM10
Keyboard Corsair
Sir, the motherboard is using Fan curves that I put in the bios settings, at same rpm, the T30s push more air and are/seem just as quiet. So for same RPM and noise I'm running 2C quieter. I switched to the Phantek T30 because performance was slightly better per RPM and because they weren't ugly brown in an open case where everything is visible. I don't see the value of switching back and give up 2C cooling performance. At least that is my personal PC and personal opinion. Other builds and other peoples preferences may play a part in their unique environment.
I looked at this from all angles literally. Its not that the Phanteks are 5mm wider, its that the depth of the T30 blade is almost 9mm more. The Noctua fan is less blade depth and the Noctua fan case has a slope-out from the end of the blade depth that is significant, vs the Phanteks blade goes as close as possible on the front and on the back in relation to blade depth. Hence its more than just a 5mm difference on the fan case, which is what most people focus on.
I seriously made lots of considerations before I experimented with 2x of the 3 unit T30 packages. Then after reading everything on it, decided to test them myself.
Results - same RPM fan curve, same level of quiet/noise, I get 2C better cooling. I have an open case design (its dense in there), and the Noctuas did not perform as well as the Phanteks at the same RPM / Fan curves.
I hope that helps.
376 (0.48/day)
Why the focus on performance at a given rpm? I care about performance to acoustics ratio, as those are the only thing that I can, as a human, directly sense, or what matters to the computer. RPM is just some arbitrary number you set in the fan curve.
Also, sensing difference in noise levels is very difficult, except in a A/B blind tests. So you simply stating that they ”seem” to produce the same amount of noise has little meaning to me, and neither should to you or anyone else.
T30 and A12x25 are very close to eachother when it comes to performance to noise and are both good candidates for most people.
The noctua is slightly better at low noise and phanteks at high noise operation. At least based on the measurements by TPU.
892 (0.29/day)
Audio Device(s) A LOT
Because at 700rpm fan A might provide better a noise/performance ratio than fan B, while at 1500rpm Fan B might be the winner. Noise normalized is a useful test, but as folks like gamersnexus are quick to point out, while performing the test, it doesn’t tell the whole tale.
In the case of GN, I appreciate that they do noise normalized tests, but 35dB is too loud for me. What happens at a lower noise threshold suddenly becomes significant for users who care (not that you have to, but I do!).
143 (0.04/day)
Processor AMD Ryzen 3800X
Motherboard MSI MAG X570 Tomahawk
Cooling Custom Water Cooling
Memory 4x8GB G.SKILL Trident Z Neo 3600C16
Video Card(s) AMD Radeon RX 5700XT Reference
Storage ADATA SX8200 480GB, Hitach 3TB
Display(s) MSI MAG341CQ
Case Lian Li PC-O11 Dynamic XL
Power Supply Fractal Design Ion+ 660p
Mouse Glorious Model D
Keyboard Das keyboard Model S Professional, Cherry MX Blue
A liquid crystal polymer will never have a perfectly uniform color, so ... meh.
I'm not even talking about that, I'm talking about how the covered up the bearing center with that ugly pimple. The contrast is nice and the little bit of brass in the middle is a nice touch.
Also, I'd be pretty surprised if that paint layer is thin enough to not affect airflow and noise at all while also being durable enough to stay on for the useful lifetime of the fan. You're also pretty lucky if the paint didn't unbalance the rotor or increase the weight sufficiently to cause long-term wear. It's possible to avoid all of this, but it takes some luck and some skill, and definitely isn't feasible at scale.
Obviously Noctua wouldn't be spray painting their fans at scale, but a coating a few tens of microns thick like you get when spray painting isn't going to cause any issues with noise or vibration. This is like the FUD spread by the Noctua fanatics that claimed the tip clearance was too small and that the fan wouldn't spin after painting. I've been running these fans continuously for 1.5 years at this point with no issues, and that includes a 5 V version that I've run all the way up until the blades start scraping the frame at almost 3000 RPM (which it also did before it was painted, I might add.)
862 (0.75/day)
We dont know the longetivity of T30's as of yet. Pretty new. Horizontal or vertical? All those sorts.
5,432 (3.25/day)
System Name Hotbox
Ah, that wasn't clear from what you said first. As I noted in my first post here, I agree with that sentiment.
That's only true if you're either very lucky or impeccably skilled (or some mixture of the two) at spray painting. Paint is notoriously uneven, and most off-the-shelf spray paint nozzles does not lend itself to even coatings a few tens of microns thick. You can get it thin, but thin + even coverage is pretty hard, plus drips, blobs, accumulations in contours (such as where the blade meets the hub) is par for the course. Paint adhesion to plastic is also very hit or miss, depending on all kinds of factors (the paint, the plastic, its cleanliness (both from dust, touching and any oils and residues left from manufacturing), so ... you might have gotten it to work, but that doesn't mean it's generally a good idea.
3,318 (3.28/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Yes we do, it's the SUNON maglev bearing that has been used in industrial/datacenter fans for years. They're the best in the industry and patented so you won't find (legal) imitations.
6 year warranty and 150,000 MTBF which matches Noctua's warranty and MTBF but unlike the SUNON bearings, there are far fewer Noctua fans used in servers, datacenters, and non-PC appliances.
I'd put faith in both to massively outlast their warranty period but if I had to pick a winner I'd take SUNON's maglev bearings over Noctua's tried-and-tested fluid dynamic bearings. Noctua's SSO2 bearing has a proven track record, but they're prone to rapid death when they do eventually start to dry out. Maglevs just seem to last forever (I've yet to ever encounter a dead one).
143 (0.04/day)
Well, I've done 13 NF-A12s at this point (not to mention the dozens of other fans throughout my time in the hobby) and they've all been fine, so I must be the luckiest person alive! :D
2,863 (0.75/day)
US of A
System Name gaming
Processor Intel i7-9700k @ 4.9ghz
Motherboard Gigabyte Z370 AORUS Gaming 3
Cooling Noctua U12A
Memory 16GB Corsair Vengeance LPX 3000mhz
Video Card(s) Gigabyte GTX 1660 Ti OC 6G
Storage Crucial MX500, Western Digital 550N NVMe, Crucial P1 NVMe, SanDisk Ultra 3D, WD Blue 3D
Display(s) LG 27GL83A-B & Dell - SE2717HR 27"
Case Phanteks P400A w/ Noctua fans
Audio Device(s) Klipsch pro-media 2.1 speakers
Power Supply Seasonioc Focus Plus 650w
Keyboard Logitech G15 original & Razer Ornata V2
Software Win 10
Benchmark Scores i can finally play crysis
I preferred the old Noctua that allowed you to have any color fan you wanted as long as it came in brown.
5,432 (3.25/day)
System Name Hotbox
Lucky enough to avoid severely unbalancing anything at least :) Might be as simple as your preferred type of spray paint being relatively thin and/or having a decent nozzle.
528 (0.40/day)
I wonder if the new 140 Fans will take 5 years to come out in black now that they figured out the formula.
I only shudder at the Australian prices, I gave up on Noctua with my new build, prices are absurd. My Dark Rock Pro 4 is performing brilliantly and cost me 55% the equivalent Noctua and that's without black fans.
68 (0.08/day)
I recently tore apart a very old dell power edge server that had a pair of 120mmx38mm Sunon Maglev fans. This server ran 24/7 for almost 15 years running a now antique shipping label service. As far as I know the fans were original and still moved mountains of air, no play in the bearings and no signs of stopping. I've seen delta and nidec fans do equally impressive things but there is no doubt maglev fans have proven to be one of the best.
3,318 (3.28/day)
Case Veddha T2
Mouse MX Anywhere 2
Thanks, I don't think I've ever encountered a server in use for that long, but unsurprising to hear about the fans; Sunon Maglev fans are absolutely bombproof - most Delta/Nidec/Sunon/Sanyo fans are because they're not intended for the cost-sensitive consumer market, but aimed at the reliability-sensitive industrial market.
Sanyo powers the cooling fan in my 2004 electric oven, and Sunon powers the hefty 235mm primary air-source heat exchanger fan running 24/7 in my apartment for the last 11 years.
People forget that consumer PC fans are unbelievably cheap and nasty things compared to enterprise grade hardware. By server/enterprise standards, these Phanteks T30 fans are an absolute bargain. €50-130 per fan is what a quality unit will cost for rackmount hardware.
68 (0.08/day)
Thanks, I rest my case. Sunon Maglev fans are absolutely bombproof.
Most Delta/Sunon/Sanyo fans are.
People forget that consumer PC fans are unbelievably cheap and nasty things compared to enterprise grade hardware that has to run for a decade in a datacenter at 3000-7000rpm without requiring replacement. By server/enterprise standards, these Phanteks T30 fans are an absolute bargain. €50-130 per fan is what a quality unit will cost for rackmount hardware.
While it is true most consumer fans are built to a lower standard completely writing them off isn't fair. Decent but still cheap fans such as the Arctic P12 or Fractal X2 GP-12 will easily last the lifetime of the typical build. I use P12s or the fractals in most of my lower to midrange builds and they are never an issue. Still, my favorite high end fan is the Gentle typhoon 2150, now you can get them easily under the name XPG Vento Pro.
I haven't tried one of the new T30s but they look top notch, however $10 more per fan over a XPG Vento Pro is a tough sell for me.
5,432 (3.25/day)
System Name Hotbox
AThanks, I don't think I've ever encountered a server in use for that long, but unsurprising to hear about the fans; Sunon Maglev fans are absolutely bombproof - most Delta/Nidec/Sunon/Sanyo fans are because they're not intended for the cost-sensitive consumer market, but aimed at the reliability-sensitive industrial market.
Re there any industrial/commercial fans using sleeve/rifle/similar bearings, or are they all either ball bearing or maglev? Noctua's strength does seem to lie at least partly in very good silent bearings that last long and handle decent speeds (at least 3000rpm) - but I wouldn't expect them to handle server grade speeds at all. Ball bearings will always sound grindy at low speeds, but maglev does seem to promise the best of both worlds. Corsair's ML series failed to deliver on that promise (definitely not quiet!), but if the T30 is maglev I guess that makes it the first truly successful consumer implementation.
3,318 (3.28/day)
Case Veddha T2
Mouse MX Anywhere 2
I'm not writing them off. My mining rigs use Arctic P12s, my HTPC and Desktops both use BeQuiet Pure Wings 2 (the cheapo ones). I just accept that they have a lifespan of maybe 3 years before RPMs drop or they start to sound scratchy.
As for the T30 fans, I don't have any yet but I'm likely to buy them next time because the $10 premium is worth it for the daisy-chaining of cables alone.
Not sure. I suspect not because sleeve/rifle/fdb bearings don't scale up to larger diameter fans as well. If you look at industrial fans sold by a hardware store (rather than a PC components store) you'll see that most of the fans are ball bearing:
Whilst there are still some sleeve fans in that selection of ~1500 fans on sale, when you filter the selection by connector type, almost all of those sleeve fans are 60/80/92/120/140mm x 25mm and have TX3 or 4-pin PWM connectors, meaning that the sleeve fans are almost universally PC fans.
https://uk.rs-online.com/web/c/hvac-fans-thermal-management/air-conditioning-fans/axial-fans/ if you want do your own hunting....
