Noob help - GPU cooling advice
JamesBay
9 (0.82/day)
Likes
0
#1
Hey all. I tried to search the forums here and couldn't find exactly what I was searching for. Basically, I set up a 6 GPU rig recently and can't figure out how to cool down the GPU's adequately. What I have is: 6 XFX RX580 and 3 fresh air fans coming in and 3 fans going out of the chassis. I also set the fans on each GPU to go to 100% at 75C. Even with all of this, I am running at 87-89C consistently. And from what I understand, this is going to either burn my cards up or create a fire hazard. So, two questions: 1) can anyone recommend a very high air flow fan that I can daisy chain with 4 pin molex and 2) any software tweaks I can use outside of afterburner?
After spending a butt load of money, this rig is going to be a paper weight if I can't cool down my cards.
Thanks for the help.
4,804 (3.57/day)
Likes
3,851
Duiven, Netherlands
Processor i7 8700k 4.8Ghz @ 1.31v
Video Card(s) MSI GTX 1080 Gaming X @ 2100/5500
Display(s) Eizo Foris FG2421
Case Fractal Design Define C TG
Power Supply EVGA G2 750w
Mouse Logitech G502 Protheus Spectrum
Keyboard Sharkoon MK80 (Brown)
Software W10 x64
#2
Open case / mining rig because let's face it, that's whats up here...
Also, keep in mind that ambient temperature is the first and foremost influence on your card temps under load. Cooling happens by dissipating heat. And you can only dissipate heat with a significant temperature difference, so anything you can do to increase the potential difference is going to increase the effect of any active cooling you do. First and simplest thing to think of is putting the rig in the basement if you have one. Second is airconditioning and/or ventilation (but this is a power hog too = $$$ so factor that in).
Something like this
These people know more (and finer) details than I do
@R-T-B
@cdawall
@trog100
222 (0.09/day)
Likes
91
Processor Phenom II 940
Cooling Coolermaster Hyper 212+
Video Card(s) Asus R9 290
Audio Device(s) X-Fi xtreme Gamer
Power Supply Antec Earthwatts 750
#3
You used a chassis, open or closed? If it's open it's better to have some large box fans instead of multiple 120mm PC fans, you will save a ton because for the amount of air they can move they are lot cheaper. also do have fresh air intake and hot air exhaust for the room itself.
JamesBay
9 (0.82/day)
Likes
0
#4
I was attempting to find a solution to stack rigs and not make it look like I was creating server farm to piss off the wife. So, I chose to go to a chassis rather than an open air solution. I have everything in a Hydra II chassis. Other people aren't running into the high temps, I think, because of the fans they are using (and closing the side vents for max flow). It sounds like you guys are recommending on going with an open rack...correct? No high powered fans or software adjustments?
https://www.amazon.com/gp/product/B07B4QHDPJ/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
222 (0.09/day)
Likes
91
#5
To save money, make one yourself with some wood if you have the power tools, customize it yourself and incorporate components wherever you want. Otherwise, have the case open, lay on the ground/table, have a large box fan blowing directly to the cards, much better than trying to direct the airflow in tight spaces with 6 cards.
JamesBay
9 (0.82/day)
Likes
0
#6
Thank you Super for the advice. I am going to have to find a decent looking open air, stackable frame from Amazon. My wife will get pissed me having a hokey wood thing in the house.
Wish I could keep the chassis...but I don't know how to cool the cards down....
10,559 (3.46/day)
Likes
7,353
Oregon
System Name Delta // Alpha-HTPC
Processor Intel i7 6700K // Intel i5 4570
Motherboard GIGABYTE Z270X-Gaming K7 // Gigabyte H97M -D3H
Cooling Corsair H80i V2 // Silverstone NT-06 Pro
Memory Corsair DDR4 3000 32gb //G.SKILL Ripjaws X Series 8GB 1600
Video Card(s) EVGA GTX980ti// EVGA GTX 1050ti
Storage Samsung 950 Pro 512, 2 Tb FireCuda// Samsung 850 Pro, Synology NAS with 2X Toshiba 6Tb
Display(s) ASUS PB278Q 27" 1440X 2560 // 50" Samsung Plasma 720p
Case Corsair Obsidian Series 550D // Silverstone Granada GD05
Audio Device(s) ASUS Xonar DGX // HDMI to Yamaha RX V571
Power Supply Corsair TX850M // SeaSonic G Series 550w
Keyboard Corsair K70
Software Windows 10 64bit // Windows 7 64bit with Kodi
#7
If changing the case or opening it up doesnt work. . Buy an AC unit tog get your ambient temps down
384 (0.62/day)
Likes
325
Riverwood, Skyrim
System Name I haven't decided yet
Processor Intel i5 6500
Motherboard ASRock H170M-ITX/AC
Cooling Stock cooler
Memory G.Skill Aegis 1x16GB 2133MHz
Video Card(s) Sapphire RX480 Nitro+ 4GB
Storage Samsung 850EVO 500GB, 2TB Seagate Barracuda
Display(s) 32' Sony TV
Case Cooler Master Elite 130
Audio Device(s) Onboard, HD 599 cans
Power Supply Antec High Current Gamer HCG-520M (520W)
Mouse Rapoo (can't remember the model number)
Keyboard Rapoo v56
Benchmark Scores Look in the various benchmark threads
#8
1,252 (1.58/day)
Likes
1,456
AK, USA
Processor Ryzen 5 2600X - Stock Clocked
Motherboard MSI B350M Gaming Pro
Cooling Stock Cooling
Memory TEAMGROUP Team DDR4 3000 8GB Kit @ 3,400 MHz 16-18-18-18-38-tRFC 64
Video Card(s) XFX RS RX 480 GPU @ 1288 MHz - 1.040 mV from 1.175 | GDDR5 @ 2100 MHz
Storage Samsung 850 EVO 250 GB, SanDisk Ultra II 480 GB
Display(s) IP2362 OCed refresh rate - 76Hz (Freesync supported over HDMI with CRU)
Audio Device(s) Realtek ALC887 (on-board)
Power Supply EVGA 850 BQ
Mouse Kingston HyperX Pulsefire FPS
Keyboard Logitech K520
Software Windows 10 Professional 64-bit
#9
I highly doubt screaming Delta fans would go over any better with the OP's wife. :laugh:
6,364 (1.65/day)
Likes
1,842
Austin Texas
System Name TimeDumpster
Processor Intel i7 7820X Delidded @ 4.75Ghz / 3.1Ghz Mesh
Motherboard MSI X299 Tomahawk
Cooling 240mm Corsair H105 Intake
Memory 32 GB Quad 3434Mhz DDR4 15-16-16-38-300-1T
Video Card(s) Gigabyte GTX 1080 Ti Gaming
Storage 1Tb Samsung 960 Pro m2, 1TB Samsung 850 Pro SSD
Display(s) Dell 24" 2560x1440 144hz, G-Sync @ 165Hz
Case NZXT S340 Elite Black
Audio Device(s) Arctis 7
Power Supply FSP HydroG 750W
Mouse zowie ec-2
Keyboard corsair k65 tenkeyless
Software Windows 10 64 Bit
Benchmark Scores Cb: 2103 Multi, 209 Single, 10450 Timespy - 10150 GPU/11900 CPU, superpi 1M - 7.71s
#10
Mod the case to hold a box fan as someone here said
Norton
Moderator & WCG-TPU Captain
13,282 (5.66/day)
Likes
38,106
USA
System Name My Fortress/Trish (WCG)/Julia (WCG)/Ella (WCG)/Junior(WCG)/Cruncher 1 & 2/Kreij (WCG)
Processor Ryzen 1700X/i7-970/2600K/i7-980X/Ryzen 1700/Opteron 6168x4/Ryzen 1800X/FX-8350
Motherboard X370 Taichi/ ASUS R3E/Asus P8P67 Pro/EVGA X58 SLI 3/B350 M/SuperMicro 4P/AB350 K4/ASUS 990X
Cooling NH-D14/Phanteks/NH-U14S/H70/Scythe Mugen5/CM 212+ (x4)/NH-U14S/Xig DK Nighthawk
Memory 16GB GSkill TridentZ-3200 (1700X), 16GB GSkill FlareX-2400 (1800X),... various...., 4P- 16x1GB
Video Card(s) RX 580/HD 4670/HD 7770/HD 7870/HD 7770/onboard/HD 7770/GTX 1080
Storage WD 500GB SSD/Seagate 2TB SSHD, everything else is Western Digital (mostly)
Display(s) Dell U2414H & 2409W / Dell 2208WFP (shared)
Case Silverstone FT01B/Source 530/Corsair 230T/Define XL R2/Silverstone FT05/Define R4/custom/Tt P3 open
Audio Device(s) on board (All)
Power Supply Corsair HX850/TX650/CS650M/X Gold 750/EVGA P2 850/X Gold 1050/HX650/M12 II 750
Mouse Logitech G300s
Keyboard Thermaltake Challenger Prime (Great for $30!!!)
Software Win 10 Pro (Fortress), Win 7 Pro (Ella), Ubuntu for everything else
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
#11
1,797 (0.87/day)
Likes
730
Jacksonhole Florida
System Name DEVIL'S ABYSS
Processor i7-4790K@4.6 GHz
Motherboard Asus Z97-Deluxe
Mouse Ttsports Talon Blu
Keyboard Logitech G510
Software Windows 10 Pro x64 version 1709
#12
But she won't mind sweating from the massive heat output, or the super loud Delta fans? As long as it doesn't look "hokey"? You have a problem, my friend. Tell her your machine prints money and she will be more tolerant! The Delta fans linked above would work, but they're very loud (like a nearby vacuum cleaner). Describe your climate and living space for more specific solutions (basement, attic, spare rooms?).
21,487 (5.40/day)
Likes
6,200
#13
Don't piss your wife off, if she tells you no on the mining thing don't go behind her back and do it or try to hide it, that would betray her trust in you.
430 (0.37/day)
Likes
278
System Name Wut?
Processor 4770K @ Stock
Motherboard MSI Z97 Gaming 7
Cooling Water
Memory 16GB DDR3 2400
Video Card(s) EVGA 980 SC
Storage Samsung 840 Pro 256GB
Display(s) 2 x 1920x1080
Case Thermaltake T81
Power Supply Seasonic 750 Watt Gold (was planning 290X CFX, never happened)
#14
Sounds like it is a little late for that. However, this was the best advice here. That said, I'll gladly take those cards off your hands so she doesn't find out.
5,546 (4.23/day)
Likes
3,339
Sunshine Coast
System Name Black Box
Processor Intel Xeon E5-2650 8c/16t @ 2.0GHz
Motherboard Cheap Chinese X 79
Cooling Coolermaster 240 RGB A.I.O.
Memory Geil 8Gb (2x4Gb) 1600Mhz
Video Card(s) iGPU, Nvidia GTX 710.
Storage Sandisk X 400 256Gb
Display(s) AOC 22" Freesync 1m.s. 75Hz
Case Coolermaster Mastercase 5 RGB.
Audio Device(s) No need.
Power Supply FSP Aurum
Software W10 Home Premium 64 bit
#15
Your GPU temps aren't too bad in my opinion, as long as they stay below 90C.
Does that rack come with a top that closes, and directs airflow more accurately?
I would look in to fans with a high CFM and hopefully low Db.
JamesBay
9 (0.82/day)
Likes
0
#16
Also if noise isn't a consideration, buy 6 of these and then you'll be fine, they move so much air it isn't funny https://pcpartpicker.com/product/dnPfrH/delta-electronics-case-fan-afb1212ghecf00
Actually, I am considering that fan. I need to make a decision on replacing the fans I have (1300RPM) or buying a new rig frame. The noise may be a problem, but an open air rig with subpar fans are going to make nice as well.
I may take you up on that. I just found out today that I am only going to make $5 a day running all 6 cards 24/7. This whole endeavor may not be worth it...
Yes, there is a cover. And others who have purchased it isn't having this heat issue. And I think it is because of the fans they have and some software tweaks. I am just too new to know what they are doing.
Also, based on what I have read on other forums, I may burn down my house if trying to run the cards at 90C for a long period of time. Not correct?
@JamesBay what are you using for fans?
Note that the manual for that case recommends some pretty heavy duty fans:
https://cdn.shopify.com/s/files/1/0817/8277/files/Hydra_2_Rev_B_User_Manual.pdf?184048170500311230
I thought 1300RPM would be good enough. But clearly I was wrong.
2,578 (1.36/day)
Likes
2,061
GMT +2
System Name Red Radiance
Processor fx 8320
Motherboard GA-990FXA-UD5
Cooling CM Hyper 212 EVO
Memory 16gb G.skill TridentX 2400mhz (2x8 kit)
Video Card(s) GV-R929XOC-4GD
Storage OCZ vertex 460 480gb
Display(s) 32" Toshiba Full HD TV
Case CMstorm Trooper
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat tyon
Keyboard roccat ryos mk fx
Software windows 10
#17
cooler master jetflo 120
try first with 1600 rpm adapter. it should give you good enough noise/performance rate.
edit:
first check fan directions. make sure those at the prot side of the gpus suck air out while those above cpu blow fresh air in.
6,398 (1.41/day)
Likes
1,014
System Name money pit..
Processor Intel 8700K at 4800 mhz.. vcore 1.264 volts..
Video Card(s) Palit Super Jetstream 1070 x 2..
Storage Three.. all solid state 128 Transend.. 1 T Sandisk.. 1 T Transend.. plus USB external..
Case Gigabyte mid-tower.. cheap and not really big enough for what is inside..
Audio Device(s) USB Sound blaster Roar 2 all in one unit with bluetooth
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
Benchmark Scores 3Dmark Firestrike Ultra 8542.. Timespy 11508.. everyday settings..
#18
a pic of my own mining rig.. it runs cool with all fans running slow and its nearly silent.. but its a bit on the large side.. :)
its currently producing maybe $14 US per day less power costs it pulls about 1000 watts from the wall.. its not worth building one with things as they are.. mine has been running faultlessly 24/7 since august 2017.. i built mine more out of interest than anything else..
trog
5,546 (4.23/day)
Likes
3,339
Sunshine Coast
#19
From what I see, both open air frames have a larger space between the GPU's, compared to the frame in the link supplied by the O.P.
This lack of space will limit air flow to the cards causing them to run hotter.
If they could be spread out a bit, it should help.
6,398 (1.41/day)
Likes
1,014
#20
one card feeds heat to another.. on a mining rig the gap between them is a "bigger the better" principle .. the front fans on my rig basically help cool the air gap between each card.. as i said earlier all my fans are running very slowly.. very slowly is all it needs if the air gap between each card is wide enough..
if all the fans on my rig were turned up the thing sounds like a jet engine... i only know because on a boot up once the thing got its knickers in a twist and fired up with all the fans running flat out..
i follow the same principle on my sli daily use rig.. blow air directly between the cards with two case side fans.. good cooling isnt about shifting tons of air with noisy fans.. its about blowing air where it does the most good..
on my mining rig starting from left to right as you move down the line of cards each card run a little hotter than the one on the left of it and it all adds up.. the five 140 mm front fans push air between the cards and help lesson this heat build up effect.. as i say.. blow the air where it does the most good..
trog
JamesBay
9 (0.82/day)
Likes
0
#21
edit:
On the fan direction - yes - I did it correctly. Just the fans are not strong enough.
Thanks all for your help and advice. I ordered some massive Delta fans for this set up and will keep the chassis to see how the new fans work. I know this is going to get very loud....so I will have to suck up to the wifey with chocolates or something. Now I have to look at the power going to the GPU's. When doing nicehash with updated drivers for mining, the GPU's are running 99% straight out. And then I have the two GPU fans at 100%. So if I can have more air flow with the new Delta fans and tweak the power settings, I think I should be ok. If this doesn't work, I will probably give up on this endeavor. I spent over $3000 on this experiment and can't have a fire hazard when leaving the house.
8,417 (4.11/day)
Likes
10,646
Massachusetts
Processor i5 8600k
Motherboard Asrock Z370 Extreme 4
Cooling Corsair H-110i GTX
Memory 2x 4Gb Crucial Sport LT
Video Card(s) MSI GTX 980 Gaming
Storage Samsung 850 evo 250Gb
Display(s) Dell Ultra Sharp Widescreen 24" 1200P
Case Fractal Design Meshify-C
Power Supply Seasonic Focus+ 750 Gold
Mouse Logitech G502 spectrum
Keyboard AZIO MRGB Kaith Blue
Benchmark Scores Congrats USA!! on the Travel Ban.....
#22
I don't know if it's a viable option for you, but I'm gonna share this because I've used a similar resolution to cool a computer in a hot room in the past.
Even the smallest air-conditioner (<$100) ,providing good 60°F or lower air is a huge help with ambient air cooled GPUs. If you were able to throw in a window mount, or even a stand-alone air conditioner ,you can then go to a hardware store or Home Depot, and purchase dryer vent duct tubing for five dollars ,some tape, and a vent hood possibly, you can almost direct port A/C cool air ,from an air conditioner right to the intake area of your gpu's. I've done this in the past with a buddy & it worked really well. I didnt think it would be a viable solution before we did it, but it cost less than $100 all said n done, and aside from the added cost of running an A/C (im guessing this isnt an issue as your running a large number of GPU's) the cost to benefit ratio was definitely in favor of the solution being viable , atleast in this experience.
something like this, which ran to a "hood" we fashioned, that allowed the case fans to draw fresh A/C cooled air from the vent tubing right into the GPU shrouds. Dropped 10c+
6,398 (1.41/day)
Likes
1,014
#23
my mining rigs gpu fans run at less than 50% the gpu temps are less than 60C.. my gpu power is set to a max of %80.. my (open air) rig has (including the gpu and psu fans) 23 fans in all running.. its cool and its also near inaudible..
i have given advice but you sure aint listening to it.. maybe giving up is the best idea.. :)
trog
430 (0.37/day)
Likes
278
System Name Wut?
Cooling Water
#24
I don't want to sound like an ass, but you should find out how to bail out now. $3000 is going to be tough to make back in this market. You shouldn't have these problems. No extra cooling should be required. I have 5 580s in my rig and my temps don't go beyond 72C.
A quick glance through the thread and I didn't see it but did you downclock the cores to the 1200 range? Did you undervolt them by 80 to 100mv or so? Did you lower the power level to 75% or so?
cdawall
where the hell are my stars
27,211 (6.29/day)
Likes
8,066
Houston
System Name Team Blue
Processor 5960X@4.8 1.42v
Motherboard Asus X99M-WS
Cooling EK Supremecy EVO, MCR220-Stack+MCR220+MCR320, D5-PWM+EK X-RES 140
Memory 4x8GB G.Skill Trident Z 3200 CL16
Video Card(s) (2) EVGA SC BLACK 1080Ti's+ EVGA reference 1080Ti soon to be under water+AMD VEGA FE
Storage Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron
Keyboard Thermaltake Poseidon ZX
Software W10P
Benchmark Scores Zoom zoom mofo
#25
I just run forced air with the cheap box fans blowing across the rigs. That with a steep fan curve is working fine with 95F days.
