[Case Gallery] oil cooling test bed mkii
shadapar
40 (0.01/day)
grand rapids, mi
Specs:
Amd Sempron 1250
Gigabyte GA-M61PME-S2P
1GB DDR2 800
Scythe SCORC-1000
Mods:
made a motherboard tray and back from lexon, removed the red LEDs from the tri color fans, removed the cover from the power supply and mounted a 120mm fan. added some aquarium rock, an air strip (which does have an effect on cooling) and filled with 5 gallons of mineral oil.
This is an update to mineral oil on the cheap. I've been through 2 eclipse system 3 aquariums now. As near as I can tell the heat and oil make the acrylic brittle over time leading to cracks....so I rebuilt it in a five gallon glass aquarium. We'll see how it goes. As before the purpose of this mod is not speed or cooling. Its a pure endurance testbed, I'm looking to see if I can get 2 years of reliable service out of this. Its mainly the motherboard, CPU, and memory I'm interested in testing at this time. The temp photo is what happens when you fill with cold mineral oil.. the temp actually stabilized at 26F. Other than the air pump its dead silent, and by upgrading to a whisper series air pump you can't even hear it.
huraco
26 (0.00/day)
i´m always suprised about the fact the system does run under these conditions, its a cool look for a pc as media center.
i would be pleased if u keep me up2date about ur testings etc.
9/10!
7,662 (1.24/day)
c:\programs\kitteh.exe
Processor C2Q6600 @ 1.6 GHz
Motherboard Anus PQ5
Cooling ACFPro
Memory GEiL2 x 1 GB PC2 6400
Video Card(s) MSi 4830 (RIP)
Storage Seagate Barracuda 7200.10 320 GB Perpendicular Recording
Display(s) Dell 17'
Case El Cheepo
Audio Device(s) 7.1 Onboard
Power Supply Corsair TX750
Software MCE2K5
shadapar
40 (0.01/day)
grand rapids, mi
okay...
not to be an emo kid... but two votes of 1 by someone who won't identify themselves and another 1 by someone who just joined today? if you're going to give that low a rating, it would be helpful if you identified:
1.)the reason you don't like it.
2.)the reasoning behind that decision
3.)suggestions for improvement.
because as it sits it looks more like someone trying to artificially boost their own score by low ranking others. That may or may not be true, however without some kind of explanation I have no way of knowing.
4,012 (0.75/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
I gave it a 9/10. I have always been intrigued by mineral oil cooled setups.
Now all you need are some fishies that can live in mineral oil. :D
4,012 (0.75/day)
shadapar
40 (0.01/day)
grand rapids, mi
indeed
everything except the hard drive is submerged in oil. hard drives cannot be submerged unless they're soild state disks.
shevanel
3,464 (0.64/day)
Leesburg, FL
let me ask this.. once you do this, that hardware is pretty much "scarred" for life? the hardware remains oily right? Dumb question but I wouldn't be surprised if you told me otherwise.
4,012 (0.75/day)
Good question, something I would like to know myself. I also wonder if the oil can work its way under BGA chips and the CPU socket and get stuck there.
shadapar
40 (0.01/day)
grand rapids, mi
sorta
it does to an extent. you can wipe of the excess and put it near a heat source blowing hot air (not too hot) and the rest of the oil will eventually evaporate away.
I spent a lot of money on fans and heatsinks to get my phenom ii system running under 20db. So I'm using this system as a test bed. If it survives 2 years, then the next major system i build is going straight to the tank.
shadapar
40 (0.01/day)
grand rapids, mi
pros.
1.)silent
2.)stable temperatures.
3.)eliminates the 'hot' areas you sometimes get with air cooling
4.)temperatures are more equally dispersed, and it takes a long time to heat that much oil.
cons.
1.)messy
2.)price. the cost of the equipment in this test rig is less than $300.. but the cost of 5 gallons of oil is about $75.
3.)crack the acrylic case, or the glass in this case, and be prepared to wipe up a lot of oil and point a hair dryer or space heater at the rest until it evaporates.
Over all the pro of Silent means more to me than the cons.. provided i can get a reasonable life span out of it. As I said I was having a problem with the smaller acrylic cases cracking after about 3 months. I know you can get the oil to evaporate from previous bad experience.
If I were to run this with something like my phenom ii and crossfire I would definitely add a water cooling pump and radiator. If i did that I'd probably wire a temperature sensor to a fan controller. cooling passively unless the temps rose above a certain level.
4,012 (0.75/day)
Probably the difficult issue with using the mineral oil bath is cooling the oil and getting it to circulate, although you can probably use the same principles you might use in water cooling to circumvent this issue.
shevanel
3,464 (0.64/day)
Leesburg, FL
Something tells me you love it quiet around the house.. If I slept at your house I'd probably just barely hear my heart beating over the sound of the worms digging holes under the house, no?
LOL..
thanks for the info man, this is cool thread.
1,018 (0.18/day)
New York
System Name Filtration tower
Processor i9 7900@4.4ghz
Motherboard ASRock X299 Taichi
Cooling Air
Memory 64g 3200 quad channel
Video Card(s) ASUS GTX 1080Ti
Storage 500gb Nvme, 200gb SSD, 1700gb HDD
Display(s) 34" Acer Predator 3440x1440
Case Thermaltake v71
Power Supply EVGA supernova 850 T2
im fascinated by this
4,251 (0.76/day)
California
Processor Intel i7 10700k
Audio Device(s) Onborad dts
Power Supply Corsair RX 650 W
Mouse Roccat Kiro
Keyboard Razer Tarantula
Software Windows 10 Home x64
I have a feeling that all these 1/10's are posted by the same person registered under different names. What do you have against shadapar? I think you should take your immature actions elsewhere because the people at TPU respect one another.
*Anyway very nice build! I've always liked oil submerged rigs, it gives a PC that non-computer look and is a great way to experiment with different ways of cooling your hardware. Good job man! 8/10
57 (0.01/day)
Processor AMD 965
Motherboard Crosshair III
Cooling Noctua nh-d14
Memory 4gb Patriot 7-7-7-20
Video Card(s) 5850
Storage whatever was laying around when I built the system
Power Supply 750w Corsair
Never seen anything like this.... very cool
mAfia_boy
36 (0.01/day)
The Underverse
System Name Markys Rig
Processor Intel i7 920
Motherboard Asus P6T Deluxe V2
Cooling DIY Watercooling (mainly Swiftech+Feser Company)
Memory 6gig Corsair Dominator Triple Channel DDR3
Video Card(s) Geforce 285 Superclocked 1gig
Storage 1xWD 150gb Velociraptor - 1xMaxtor 500gb
Display(s) Samsung syncmaster 22" lcd widescreen
Case Coolermaster HAF 932
Audio Device(s) Creative X-fi Fatality Championship
Power Supply OCZ X-treme 1000w
Software Windows 7 Home Premium
i gave this rig a 7/10 because im new to oil cooling but am curious all the same, this is the 1st one ive seen so far, i wanna look into this some more though, looks awesome, great attempt at a new type of cooling!!
196 (0.04/day)
Ottawa, Ontario
Processor Q9550@3.8Ghz
Motherboard Gigabyte X48-DS5
Cooling Zalman CNPS9700 (Nirvana)
Memory Corsair XMS2 2x2Gb 5-5-5-15
Video Card(s) x2 Saphire 4850 in Crossfire
Storage 2x Western Digital Caviar Black 1Tb HDD
Display(s) LG 24"
Case Thermaltake Armor VH8000BWS Midtower
Power Supply ABS Tagan BZ 700w
I voted 10/10 because:
just awesome
T
TechnicalFreak
I voted 9/10 because:
1.It's "odd", I like odd stuff
2.I don't have one like that..
3.That is a mod..
huraco
26 (0.00/day)
it's real cool and i hate the 1/10 vote that has no discripttion at all..
Play3r
241 (0.04/day)
Perth, Australia
System Name SexMachine
Processor Intel i5 750 @ 4Ghz 1.29v
Motherboard Asus P7P55D Deluxe
Cooling Prolimatech Mega Shadow
Memory Corsair CM3X2G1600C9DHX 4GBs @ 800Mhz @ 9-9-9-24
Video Card(s) VTx3d 6950 Modded +200 900mhz/1375mhz
Storage 120GB Corsiar Force 3, 2 1TBs, 6 1.5TBs, 3 2TBs
Display(s) BenQ XL2410T & Samsung SyncMaster 2693HM + Dell U2410
Case Lian Li PC-A70FB Black
Audio Device(s) Asus Xonar Essence ST
Power Supply CORSAIR 750W TX-750W POWER SUPPLY
Software Microsoft Windows 7 Ultimate 64bit
Benchmark Scores Benchmark ALL THE THINGS
Haha thats epic!
