- Dec 31, 2009
- 19,366 (3.70/day)
Benchmark Scores | Faster than yours... I'd bet on it. :) |
4.4ghz? Dude.. at least overclock it, that's lower than turbo, lol!
Processor | 8700k OC @ 5GHz (1.35 V) |
Motherboard | ASUS Prime Z390-A |
Cooling | Corsair H100i v2 |
Memory | 16GB DDR4 OC @ 3000MHz |
Video Card(s) | EVGA RTX 2070 XC Ultra |
Storage | 4 x 250GB PNY SSD & WD BLACK 1TB HDD |
Display(s) | Samsung UHD 4K / BenQ RL2455HM |
Case | NZXT H500i |
Power Supply | Corsair 750W |
Software | Windows 10 Pro |
part of the problem is the sensors are more accurate towards tjmax, than at idle.If it's idle already sitting lets say 8 degrees higher than ambient, your load temps will be higher as well....
out shoot.. 7600k, lol.. yeah. 4.2 is turbo.Turbo is 4.2 I thought lol
Processor | Intel i7 10700K |
Motherboard | Asus ROG Maximus XII Hero |
Cooling | 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140 |
Memory | 32GB G.SKILL Trident Z RGB 3600Hz |
Video Card(s) | EVGA GEFORCE RTX 3080 XC3 Ultra |
Storage | Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB |
Display(s) | Asus ROG PG278QR 2560x1440 144Hz (Overclocked 165Hz )/ Samsung |
Case | Corsair Obsidian 1000D |
Audio Device(s) | I prefer Gaming-Headset |
Power Supply | Enermax MaxTytan 1250W 80+ Titanium |
Mouse | Logitech G502 spectrum |
Keyboard | Virtuis Advanced Gaming Keyboard ( Batboard ) |
Software | Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro |
Benchmark Scores | My PC runs FiFA |
Current setup using CPU-Z and Core Tem 1.5
4.4GHz at 1.25v at 76c loads, 30c idle. Memory is at 3000.
System Name | Computer of Theseus |
Processor | Intel i9-12900KS: 50x Pcore multi @ 1.18Vcore (target 1.275V -100mv offset) |
Motherboard | EVGA Z690 Classified |
Cooling | Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active |
Memory | G-Skill Trident Z5 (32GB) DDR5-6000 C36 F5-6000J3636F16GX2-TZ5RK |
Video Card(s) | EVGA Geforce 3060 XC Black Gaming 12GB |
Storage | 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data 1 and 2), ASUS BW-16D1HT |
Display(s) | Dell S3220DGF 32" 2560x1440 165Hz Primary, Dell P2017H 19.5" 1600x900 Secondary, Ergotron LX arms. |
Case | Lian Li O11 Air Mini |
Audio Device(s) | Audiotechnica ATR2100X-USB, El Gato Wave XLR Mic Preamp, ATH M50X Headphones, Behringer 302USB Mixer |
Power Supply | Super Flower Leadex Platinum SE 1000W 80+ Platinum White |
Mouse | Zowie EC3-C |
Keyboard | Vortex Multix 87 Winter TKL (Gateron G Pro Yellow) |
Software | Win 10 LTSC 21H2 |
Case | NZXT H500i |
Case | NZXT H500i |
I don't know why we aren't at 4.5. Plenty of temp and voltage headroom.....
Your replacement might be just as bad. I guess it couldn't get worse. Then again, it could. I tried for a few chips near the end of Ivy Bridge's production and they were all crap, each worse than the last, and worse then the chip you have now. You might end up with a chip that can't even get past turbo, idk.Is it a guarantee I got a bad chip? I'll RMA idc lol
Are you for real?at least overclock it,
System Name | AlderLake / Laptop |
Processor | Intel i7 12700K P-Cores @ 5Ghz / Intel i3 7100U |
Motherboard | Gigabyte Z690 Aorus Master / HP 83A3 (U3E1) |
Cooling | Noctua NH-U12A 2 fans + Thermal Grizzly Kryonaut Extreme + 5 case fans / Fan |
Memory | 32GB DDR5 Corsair Dominator Platinum RGB 6000MHz CL36 / 8GB DDR4 HyperX CL13 |
Video Card(s) | MSI RTX 2070 Super Gaming X Trio / Intel HD620 |
Storage | Samsung 980 Pro 1TB + 970 Evo 500GB + 850 Pro 512GB + 860 Evo 1TB x2 / Samsung 256GB M.2 SSD |
Display(s) | 23.8" Dell S2417DG 165Hz G-Sync 1440p / 14" 1080p IPS Glossy |
Case | Be quiet! Silent Base 600 - Window / HP Pavilion |
Audio Device(s) | Panasonic SA-PMX94 / Realtek onboard + B&O speaker system / Harman Kardon Go + Play / Logitech G533 |
Power Supply | Seasonic Focus Plus Gold 750W / Powerbrick |
Mouse | Logitech MX Anywhere 2 Laser wireless / Logitech M330 wireless |
Keyboard | RAPOO E9270P Black 5GHz wireless / HP backlit |
Software | Windows 11 / Windows 10 |
Benchmark Scores | Cinebench R23 (Single Core) 1936 @ stock Cinebench R23 (Multi Core) 23006 @ stock |
The fact you believe you are idling 2c above ambient should tell one something.
not bad for a 212, nice!I'm talking about core temps, well my CPU core temps while playing GTA V highest core 40c max, at a 20.5 ambient temp so yeah I think these temps are about right,
if the cores were idling at 30, the load temp would be around 50 in my case...
Do whatever you do best....
Case | NZXT H500i |
System Name | Ryzen Reflection |
Processor | AMD Ryzen 9 5900x |
Motherboard | Gigabyte X570S Aorus Master |
Cooling | 2x EK PE360 | TechN AM4 AMD Block Black | EK Quantum Vector Trinity GPU Nickel + Plexi |
Memory | Teamgroup T-Force Xtreem 2x16GB B-Die 3600 @ 14-14-14-28-42-288-2T 1.45v |
Video Card(s) | Zotac AMP HoloBlack RTX 3080Ti 12G | 950mV 1950Mhz |
Storage | WD SN850 500GB (OS) | Samsung 980 Pro 1TB (Games_1) | Samsung 970 Evo 1TB (Games_2) |
Display(s) | Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode) |
Case | Lian Li PC-011D XL | Custom cables by Cablemodz |
Audio Device(s) | FiiO K7 | Sennheiser HD650 + Beyerdynamic FOX Mic |
Power Supply | Seasonic Prime Ultra Platinum 850 |
Mouse | Razer Viper v2 Pro |
Keyboard | Razer Huntsman Tournament Edition |
Software | Windows 11 Pro 64-Bit |
Gonna do some tweaking and report back. What is the max voltage I should be touching? And with a hyper 212 evo I am getting around 80c with any voltage over 1.300.
So I am stable at 4.5 if I allow the voltage to go to 1.31. None of the workers stop anymore in Prime 95, and wPrime can run 1024M indefinitely. Ram is still at 3000.
Side note: Last night I was playing with the ASUS AI SUITE, and messing with CPU line load and phase power. I have since uninstalled the program, and reset bios to optimized defaults, any chance of those settings lingering? the app itself didn't have a default key.
Yeah indefinitely isn't 10 minutes.Wait wait.
17 minutes ago you said that you were playing Battlefield now you OC'ed the CPU to 4.5 and in less than 10 minutes you say that your OC it's stable?
I don't use prime anymore for stress testing, just Aida64, the CPU load from this is more realistic (comparable to when you would be gaming) then prime.
Nope.Doesn't prime 95 damage skylake? I thought for all releases after Haswell, stability testers were advised to use AIDA instead.
again, sensors are inaccurate at idle, so it doesn't always translate that way.I'm talking about core temps, well my CPU core temps while playing GTA V highest core 40c max, at a 20.5 ambient temp so yeah I think these temps are about right,
Case | NZXT H500i |
Case | NZXT H500i |
