Opteron temps, need cooling advice
Rurouni Strife
124 (0.03/day)
Processor AMD Athlon 64 X2 Windsor @ 2.81 (Artic Cooling Freezer 64)
Motherboard ECS Black 780G
Cooling 4 case fans, AC 64 Pro on Proc.
Memory 2 GB Kingston Ram
Video Card(s) Diamond Radeon 3850 stock (OC 740/930)
Storage 250 GB Segate SATA 2, 160 Samsung
Display(s) BenQ T705 17", SynchMaster 19"
Case generic
Audio Device(s) Something that makes sounds...by IDT
Power Supply 550W Corsair
Software XP Pro
Benchmark Scores 13000 3DM05
Hey all,
I'm trying to get my Opty 170 to 2.6 ghz. I feel that that is magical for some reason. Anyway, I can get it to 2.4 stable at 1.325 vcore. But a 1.375 vcore seems to get a 2.5 ghz stable but then It'll hard lock when I'm testing it towards the end. Using speedfan to check my temps I get up to 58C on load at 2.5 before the lockup, and when I'm at 2.4 I get to 53 or so. Idle temps hover around 34-36C.
Current cooling is 1 120 mm intake fan, 1 70 mm side intake, 2 80mm exaust. I have an Artic Cooling Freezer 64 Pro on it, with some relatively freshly applied AS5 (cleaned everything off before hand). The AS5 hasnt had it's "burn in" time completed yet but I dont think it'll drop my temps by 5C or more. Any suggestions? HTT and ram values are taken care of properly and all.
ASRock 939 Dual SATAII
Opteron 170
4,815 (1.07/day)
Wangas, New Zealand
System Name Darth Obsidious
Processor Intel i5 2500K
Motherboard ASUS P8Z68-V/Gen3
Cooling Cooler Master Hyper 212+ in Push Pull
Memory 2X4GB Corsair Vengeance DDR3 1600
Video Card(s) ASUS R9 270x TOP
Storage 128GB Samsung 830 SSD, 1TB WD Black, 2TB WD Green
Display(s) LG IPS234V-PN
Case Corsair Obsidian 650D
Audio Device(s) Infrasonic Quartet
Power Supply Corsair HX650w
Software Windows 7 64bit and Windows XP Home
Benchmark Scores 2cm mark on bench with a razor blade.
I get to 65 degrees C in coretemp 0.96 on core 1 in Orthos for over an hour but I haven't had a lock up.
Could be the motherboard.
11,960 (2.59/day)
Wherever I can find the iron.
Processor Haswell i7 4770K
Motherboard Gigabyte z79 UD5H Black Edition
Cooling Cryorig R1 Ultimate
Memory Gskill Trident DDR3 2400
Video Card(s) Asus 7970 Direct CU II
Storage Kingston Hyper Fury 240 SSD/ WD Black 640GB
Case Fractal Design R5
Power Supply XFX 650w
Software Win 7/Win 10 Tech preview
Hey all,
Opteron 170
Ok, best way for you to see if your temps are safe is looking at the "tjunction" temp in coretemp. Generally, you want to stay 15-20c below tjunction temps at full load.
sneekypeet
Super Moderator
26,901 (5.45/day)
System Name His
Processor Intel i9 7920X
Motherboard Asus Prime X299 Deluxe
Cooling Corsair H115i RGB Platinum
Memory G.Skill TridentZ RGB 32GB @ 3600MHz
Video Card(s) nVidia RTX 2080ti
Storage Samsung 960 Pro / Crucial MX300 750GB / Seagate 1TB Spinner
Display(s) Samsung 55" 4K 60hz
Case Cooler Master Cosmos C700P (Inverted Layout)
Audio Device(s) Realtek on board > Sony Receiver > Cerwin Vega's
Power Supply Thermaltake TPSG 1050W
Mouse Always Changing
Keyboard Always Changing
Software Windows 10 Pro 64
With a stock cooler on that opty it will get a bit warmer than wanted when OC'ing. I would suggest some better cooling B4 I clocked too much farther.
AF64PRO is cheap and performs really well for the money. Just so you realize as well, most opty 170's will hit 2.6-2.8GHz on stock voltage, so you may just not have a good OC'er!
Also Opty's require good ram to Oc well....try running memtest86+ to rule out the possibilitie of the ram hindering the OC!
MrW
188 (0.04/day)
Toronto, Canada
Processor Opteron 1212 @ 3.2Ghz
Motherboard DFI Infinity N-Force Ultra M2
Cooling Custom
Memory 4GB Ballistix DDR2-1000
Video Card(s) Ati Radeon X1900-AIW
Storage WD Caviar 640GB
Display(s) 21" Trinitron
Case Lian-Li PC-65
Power Supply Seasonic S12-500W
Software Vista & openSUSE
Hey all,
Opteron 170
Try these things:
Increase your cpu voltage to 1.45. Increase mem voltage a little. Re-mount your heatsink to be sure it is getting proper contact. Lower ram divider from 200mhz to 166/133/100. Lower HTT speed by 50%. Run SuperPI to be sure cpu & ram are stable. Compare temp readings from more than one program to be sure they are accurate. Leave side panel off to see if temps improve. Case airflow can be a major factor while overclocking.
PS: "Burn-in" time usually only yields a 1-2 degree improvement.
If voltage is the problem, your motherboard can be modified to give up to 1.55 core voltage.
Some 3rd party bios's can improve overclock on that board significantly.
42,961 (8.88/day)
Processor i7 8700K
Motherboard Asus Maximus Hero X WiFi
Cooling Water
Memory 32GB G.Skill 3200Mhz CL14
Video Card(s) GTX 1080
Storage SSD's
Display(s) Nixeus EDG27
Case Thermaltake Core X5
Audio Device(s) SoundBlaster Zx
Power Supply Corsair H1000i
Mouse Finalmouse Pro
Keyboard Razer BlackWidow Tournament Ed.
2.5 is probablly as high as your motherboard will let you take it.
Rurouni Strife
124 (0.03/day)
Case generic
Software XP Pro
Paulieg
"Ok, best way for you to see if your temps are safe is looking at the "tjunction" temp in coretemp. Generally, you want to stay 15-20c below tjunction temps at full load."
How do I see that? I got temp 1, 2 and 3. then CPU and HDD.
MrW-I already remounted the heatsink and all that jazz. I might try another bios, I have heard of the OCworkbench bios and apparently the 1.5 version of the offical works well too. But i wanna get my cooling under control first.
Thanks all, any other suggestions? Should the side fan also be an exaust fan?
MrW
188 (0.04/day)
Toronto, Canada
Cooling Custom
Case Lian-Li PC-65
Bios versions below 1.70 have a front-side-bus clock limit. Be sure to update it if it's below 1.70.
OCWBeta6 bios and above are unaffected by the clock limit.
Take the side panel off, if the temp lowers significantly you need higher case airflow.
4,815 (1.07/day)
Wangas, New Zealand
I have bad case ventilation.
I took off my side panel and temps dropped by 4 degrees.
Rurouni Strife
124 (0.03/day)
Case generic
Software XP Pro
Thanks everyone.
