PC Hangs when I hear a ticking sound
FewFlyBy
18 (0.01/day)
One reallocated sector is okay. You run into problems when that number starts growing quickly. Anything over 10 in my book is a cause for concern, but 1 isn't anything to worry about. Occasionally drives will simply have a bad block that can't be used. It happens.
I do notice that the start-stop counter exceeds the power-on time. You should try disabling HDD power saving so the drives don't spin down. If they're spinning up and down often, you may fry the motor and if they're spun down and you need to access something, it needs to spin back up again before anything can happen. A great example are my WD Blacks. They can take as long as 8 or 9 seconds to fully spin up to speed, so it only makes sense to keep them spinning as opposed to having to wait almost 10 seconds just to access the drives.
Where can I disable that HDD power saving? Thank you
Aquinus
Resident Wat-man
11,856 (3.68/day)
Concord, NH
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 10.15.6
Aquinus
Resident Wat-man
11,856 (3.68/day)
Concord, NH
System Name Apollo
I checked it and it is "Never" by default
Does your computer go to sleep often? The drives will spin down if the computer goes to sleep. That count just seems really high for a drive that's constantly running.
FewFlyBy
18 (0.01/day)
So I should choose Never in Turn Off the Display
Aquinus
Resident Wat-man
11,856 (3.68/day)
Concord, NH
System Name Apollo
No, you want the computer to never go to sleep, or at least not so often that you're always waking it up. The monitors don't matter.
2,154 (0.56/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 860EVO // Samsung840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G9
Keyboard Dell
Software W10 Pro 1909
Aquinus
Resident Wat-man
11,856 (3.68/day)
Concord, NH
System Name Apollo
From post #26: Why does drive show 144 Celsius as temp? Is the program running correctly? Did not see conversion to F.
You're looking at the wrong column.
2,154 (0.56/day)
Mouse Logitech G9
Keyboard Dell
Temp fine. Thanks Aquinus.
HGST page: http://www.hgst.com/support/downloads
See also possible firmware update for drive: http://www.hgst.com/tech/techlib.nsf/pages/main?OpenDocument
Edit: I think this is correct page and it looks like no updates:
http://www.hgst.com/tech/techlib.nsf/products/Travelstar_5K500.B
Everyone suspects HD as sound culprit but have you looked at fans as well?
What does health tab in HDTune say, post #9?
As a new member, please fill out "system Specs" in your user profile, it helps others to help you.
159 (0.03/day)
Chilliwack, BC
Processor AMD FX-8350 Black Edition
Motherboard ASUS Sabertooth 990FX 1.01
Cooling Zalman 9900NT
Memory 16GB G Skill TridentX DDR3 2400 @2133 CL9-11-11-31 F3-2400C10-8GTX
Video Card(s) XFX Double D R9-390-TDFD 8GB 512-Bit GDDR5
Storage Samsung 850Pro 128GB, WD VelociRaptor 600GB, Seagate 7200.14 500GB
Display(s) HP LP2065 IPS x2
Case Coolermaster Elite RC-330 ATX
Audio Device(s) HT Omega Claro Plus
Power Supply Corsair TX850W V2 Single 70A Rail
Mouse Asus 0K100-00030200
Keyboard IBM KB-9930
Benchmark Scores 1.21GW @88MPH
1,614 (0.37/day)
nobody mention head parking yet? that's what load cycle is, that's what ticking is, that's why the OS cant read anything on the drive while the heads are changing states
the firmware may even have itself spin down the drive if there is little to no activity (this would happen if you're reading a long article for example, drive could think it's idling)
we need to confirm if this is the (minor) issue or if there is a bigger problem happening
dorsetknob
8,712 (1.52/day)
Head Parking is part of the power saving settings
This was covered in earlier posts like post no 26 to 30
1,614 (0.37/day)
head parking is most certainly not part of windows power settings (windows can merely spin down the drive in its entirety)
WD drives for example, the wdidle tool changes a value stored in the firmware that controls the length of time in seconds of no activity until parking, this is low level outside of the OS
if OP's windows settings have always been set to never, then why would the load cycle count be many times higher than power cycle count?
dorsetknob
8,712 (1.52/day)
Western Digital started parking the heads after a period of inactivity in order to save power.
so Head Parking is part of the power saving settings and while this may be a firmware issue
Telling windows not to power down the drive would stop the drive parking its heads
2,448 (0.51/day)
System Name PC
Processor i7 9700KF
Motherboard MSI Z390 A PRO
Cooling Noctua NH-U14S
Memory 16GB Corsair Vengeance DDR4 3000mhz
Video Card(s) Palit GTX 1080 Jetstream
Storage Samsung 850 pro 512gb SSD, 2x Kingston 120GB SSD, 2TB WB Green
Display(s) LG 34UM68 34-Inch
Case Corsair Obsidian 550D
Audio Device(s) Audioengine A5+ Speakers
Power Supply Corsair RM750
Mouse Logitech G403
Software Windows 10 64bit
Um.... why is the link to the sound file from the original post removed by moderator?
dorsetknob
8,712 (1.52/day)
as far as i know the file was hosted on a dubious site
