Plz give a suggestion: Which memory is better?
sttc
18 (0.00/day)
same price $122.99, memory for i7 920
1: OCZ Gold 6GB
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820227365&Tpk=OCZ Gold 6GB
Brand OCZ
Series Gold
Model OCZ3G1600LV6GK
Type 240-Pin DDR3 SDRAM
Tech Spec
Capacity 6GB (3 x 2GB)
Speed DDR3 1600 (PC3 12800)
Cas Latency 8
Timing 8-8-8-24
Voltage 1.65V
Multi-channel Kit Triple Channel Kit
Heat Spreader Yes
Features Gold Z3 XTC Heatspreader
Designed specifically for the Intel X58 chipset / Core i7
2: CORSAIR XMS3 6GB
http://www.newegg.ca/Product/Produc...cm_re=CORSAIR_XMS3_6GB-_-20-145-222-_-Product
Brand CORSAIR
Series XMS3
Model TR3X6G1600C9
Tech Spec
Cas Latency 9
Timing 9-9-9-24
Voltage 1.65V
Heat Spreader Yes
Features Compatible with Intel Core i7 series CPU for Intel X58 Motherboard
TYVM!
at stock speeds i would go with the ocz due to lower timings but in oc enviroment probably the corsair would be better
lol i always thought higher timing = better performance
Nope, it's the opposite. I would still go for the Corsair, I have had excellent luck with Corsair products so far (3 PSUs and 4 kits of RAM), and the Corsair memory I have purchased in the past OCs excellently
hmm looks like we got different opinions here
the truth = low timings > high timings.
high frequncy > low timings
thats why at the same time frequency increases with each new standard (ddr, ddr2, ddr3), more frequency is added to enhance performance
both identical other than appearance.
they have the same chips.
samsung HFC0's
SPD doesnt matter.
Using the above info to base my views on, I'd go with the OCZ set as they look better and come with tighter stock timings.
