Ryzen_Mike
- Nov 15, 2019
- 4 (0.00/day)
I have an Alienware M15 with a 9750H, temps are hot, I know its normal. It concerns me tho because I only have one year warranty and Dell only warranties if it hits 101c. I'm normally at 99c to 100c during heaving loads and even sometimes at idle. Honestly for a $2k plus computer, that's a huge risk after a warranty that ends in a year. However unlikely or implausible to fry my computer after the warranty expires is just not worth it. I managed to use ThrottleStop to bring temps down to a max of about 85c during gaming, stress test, etc. I have it set to hold the cpu at 4 - 4.1Ghz all the time. I thought when you made a performance and battery profile you could set different values for each but it seems that the values in the Turbo Power Limit section don't allow this. Its a once it's set its set kinda thing.
I'm trying to figure out a way to have a battery profile setup using my existing values with the max frequency at say 2 - 2.5ghz and the minimum at a few hundred Mhz. Its currently at a min 4 and a max of 4.1Ghz. The only way I know so far to get this to work is to either change it manually everytime I change battery profiles or to make another config file and have 1 for Battery Longevity and 1 for Performance then swap those everytime.
Was also thinking of duplicating the install in another folder. Right now its in program files (x86), thought of adding one in program files and when I want to switch profiles end the running ThrottleStop and start the other. I could see it working but could also see potential issues. Am I pretty much stuck with those 3 options or is there something else I'm missing?
