Power Bright 1500 Watt inverter.
1 (0.01/day)
Likes
0
#1
I hooked up my converter and I have 0 voltage coming out. The lights are lit up but no output. When I turn it on, the led is green. After it beeps, the lights turn red (may be normal, can’t remember).
TIA for any help!
3,580 (0.85/day)
Likes
2,359
Nebraska, USA
Cooling Quality case, stock CPU HSF
Memory 16GB (2 x 8GB) DDR4 3000 Corsair Vengeance
Storage Samsung 850 Pro 256GB SSD, Samsung 850 Evo 250GB SSD
Case Fractal Design Define R4
Mouse Microsoft Wireless 5000
Software W10 Pro 64-bit
#2
I can only assume there is a switch or breaker that is flipped, or some other fusable link that is burned or broken.
10,114 (2.27/day)
Likes
3,999
Manchester, NH
System Name Working on it ;)
Processor I7-4790K
Motherboard MSI Z97 U3 Plus
Video Card(s) GIGABYTE AORUS 1070 Ti 2040/2400 (GPU/MEM OC)
Storage Samsung EVO 500GB / 8 Different WDs / QNAP TS-253 8GB NAS with 2x2Tb WD Black
Display(s) 34" LG 34CB88-P 21:9 Curved UltraWide QHD (3440*1440)
Case Rosewill Challenger
Power Supply Corsair HX750 (love it)
Mouse Logitech G5
Software Win 10 upgraded from Win 7 Pro
#3
TIA for any help!
Mine did that once when the two 12v leads had frayed wires that shorted. I cleaned it up and it still did it but only for a few minutes then worked fine. I assume it was a thermal overload protection thing.
3,580 (0.85/day)
Likes
2,359
Nebraska, USA
#4
Do you mean for the OP's? Or yours? Overload protection might cause wires to burn "open" to break the circuit, but not become frayed.
10,114 (2.27/day)
Likes
3,999
Manchester, NH
Processor I7-4790K
Mouse Logitech G5
#5
No, the *symptom* in my case (caused by a short) was the same as the OP is seeing, the green then red light and a non-functioning inverter. Though for me, it corrected itself within 5-10 minutes after I fixed the short, so presume it was thermal overload protection kicking in. Thinking the OP might have a short.
3,580 (0.85/day)
Likes
2,359
Nebraska, USA
#6
So were the stray wires from poor quality control at the factory? Or some other abuse after the sell?
10,114 (2.27/day)
Likes
3,999
Manchester, NH
Processor I7-4790K
Mouse Logitech G5
#7
I've had that inverter for 10-15 years (and have used often). 400W... the 12v wires connect via screw terminals, and have frayed over the years. one post came loose and frayed wires turned so they were touching eachother. I thought it was kaput when it started doing that.
3,580 (0.85/day)
Likes
2,359
Nebraska, USA
#8
Okay. 10 to 15 years of service is nothing to complain about. Thanks for clarifying.
