Power Supply For 10850k and MSI Z490 Gaming Edge
landstrom27
3 (0.09/day)
Hello, this is my first post. I'm building a 10850k build on a MSI Z490 Gaming Edge mobo and noticed the extra 4 pin cpu power connector. I have everything but cpu, should be arriving tomorrow. The power supply I just put in doesn't have the extra 4pin cpu connector though, and is a non-modular psu. I've read that you don't need to use the extra 4 pin unless you plan to do extreme overclocking, but I've also read that you do need it even if you don't overclock. It doesn't really say anything about it in the manual except that it needs to be connected. I have a Corsair HX 750 in my 4770k build. It's an older version than the new ones though. It four cpu/pcie 8 pin outputs. Would this power supply work if I can find the right cable for it? What's weird is cpu power are +12 on one side and ground on the other, which is different, I thought, than pcie, but I take it you can connect any of the cpu/pcie outputs to the cpu or graphics cards? Would the HX 750 work if I got this cable?
Not sure about the keying on the mobo for the extra four pin, but I can look if it will help.
I do plan on overclocking it. I don't know what would be considered extreme for this cpu, but I'm hoping to get it to at least 5.1 ghz. I was planning on taking the PSU I just put in back anyway for a better one. It's a EVGA 700W Bronze, non modular. I wonder if the newer HX 750 has the extra four pin or if there are others that have it?
landstrom27
3 (0.09/day)
Ok, I guess I'll trust that it don't need it and go ahead and fire it up when the cpu arrives tomorrow. Say it ends up bugging me though and I wanted to connect the extra 4pin and see how far I could go with overclocking, would this cable work?
Also, is the EVGA - 700W ATX12V /EPS12V 80 Plus Bronze an OK PSU for this system? It will have an RTX 2070 S in it til I can get a 3080. Thanks for your help
18,757 (4.74/day)
Again, you don't need to connect the extra 4-pin to overclock. It will not help you.
No that cable won't work. You have a single 8-pin only, right? So if you plug that in it takes the 8 to 4+4. What you would want is molex to to 4-pin EPS.... but you really don't even want to bother. Seriously. Don't. :)
hat
Enthusiast
21,190 (4.16/day)
Ohio
Processor i7 2600k 4.4GHz :: Athlon II x4 630 3.5GHz
Motherboard ASUS P8P67 Pro :: GIgabyte GA-770T-USB3
Cooling Corsair H70 :: Thermaltake Big Typhoon
Memory 2x4GB DDR3 1866 :: 2x1GB DDR3 1333
Video Card(s) 2x PNY GTX1070 :: none
Storage Plextor M5s 128GB, WDC Black 500GB :: Mushkin Enhanced 60GB SSD, WD RE3 1TB
Display(s) Acer P216HL HDMI :: None
Audio Device(s) Creative X-Fi Titanium Fatal1ty Pro - iLive IT153B Soundbar (optical) :: None
Power Supply FSP Hydro GE 550w :: something
Benchmark Scores >9000
That power supply you mentioned should have a 4+4 connection for CPU power. That means it's an 8 pin connector, but it's split so you can easily use it with a motherboard that only takes a 4 pin connector. Look harder... unless the power supply you're actually using is a different model?
13,621 (6.09/day)
The Kitchen Table
Processor i7 8700k 4.7Ghz @ 1.26v
Video Card(s) MSI GTX 1080 Gaming X @ 2100/5500
Display(s) Eizo Foris FG2421
Case Fractal Design Define C TG
Power Supply EVGA G2 750w
Mouse Logitech G502 Protheus Spectrum
Keyboard Sharkoon MK80 (Brown)
Software W10 x64
When it comes to power supplies for Ampere, you might want to let the dust settle for a month or two as things get worked out, from Nvidia's end, but also from tech community as they figure things out. Stability seems shaky unless you've got a well oversized PSU. Would not buy this yet.
230 (0.76/day)
System Name PC ?
Processor Intel Core i9 10850k 5.1 Ghz/4.8 Ghz 1.36V
Motherboard MSI MEG Z490 Unify
Cooling NZXT Kraken X73
Memory G.Skill Trident Z Neo 3600 Mhz CL14 (2x16GB)
Video Card(s) ASUS TUF GeForce RTX 3080 OC (+150/500)
Storage Samsung 970 Evo Plus 500GB, Samsung 870 QVO 4TB, Crucial MX500 2TB
Display(s) LG 27GL850-B
Case NZXT H710 Black
Audio Device(s) Bose Companion Series 2 III, Sennheiser GSP600
Power Supply bequiet! Dark Power Pro 750W Platinum
Mouse Logitech G903 Lightspeed Hero
Keyboard Logitech G815
8 Pin EPS can/should be able to supply 336W
you "can" reach that but only with chilled water and ridiculous voltages at ~5.5 Ghz in Prime95.
