power supply is HOT HOT HOT! :eek:
Discussion in 'Overclocking & Cooling' started by xBruce88x, May 1, 2010.
  1. xBruce88x
    xBruce88x
    Oct 29, 2009
    2,515 (0.89/day)
    757
    Should my power supply really be this hot!?
    [​IMG]
    See Power/aux Temp :eek:
  2. Easy Rhino
    Easy Rhino Linux Advocate
    Nov 13, 2006
    14,371 (3.68/day)
    4,327
    hrm...how is that program reading that temperature? also, you live in georgia so i am guessing your ambient temps are high?
    10 Year Member at TPU
  3. n-ster
    Jan 11, 2009
    9,024 (2.89/day)
    1,476
    Montreal, Canada
    Could you get your temps in celsius? I'm lazy to convert and can only compare temps in celsius lol
    Easy Rhino says thanks.
  4. erocker
    erocker Senior Moderator Staff Member
    Jul 19, 2006
    42,167 (10.48/day)
    18,106
    77c and it is highly unlikely your PSU has any sort of temperature monitoring so it may be a false reading. Does the PSU and the air coming out of it feel very hot?
  5. n-ster
    Jan 11, 2009
    9,024 (2.89/day)
    1,476
    Montreal, Canada
    Try other temp reading software if the air doesn't seem that hot
    your case may be the culprit of all those high temps
  6. mlee49
    mlee49
    Dec 27, 2007
    8,506 (2.43/day)
    2,133
    Kansas City
    I have yet to find a PSU temp monitoring program. Unless you PSU has a 3/4 pin that can hook up to the mobo.
  7. xBruce88x
    xBruce88x
    Oct 29, 2009
    2,515 (0.89/day)
    757
    my case has no side panels on atm... and the case feels warm near the psu, and the air comming out the back is fairly warm (but not moving much... ) I stuck a small desk fan blowing in the side of the case aimed at the psu and now the temps have gone down to 165F/72c, better than 172/77c i guess.
    It must be measuring something if it shows its cooler with a fan blowing on it.
    edit, yea it has a 3 pin plug (2 wires tho, one blue and one black) that goes to the mobo
    edit 2, yea rhino its usually warm here, but its not so bad now...its 68f/20c now and ZOMG TORNADOES IN THE FORCAST?!?!
  8. n-ster
    Jan 11, 2009
    9,024 (2.89/day)
    1,476
    Montreal, Canada
    20c is cold :p My ambient is 22-23 right around now, in winter its 20, sometimes 21c... in summer, 23-26C :(
  9. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    45,923 (9.82/day)
    13,471
    Australalalalalaia.
    power/aux is usually not connected to anything.
    That software doesnt know where the sensor is - hence, called aux. its likely on your VRM's or something, and not related to the PSU at all.
  10. xBruce88x
    xBruce88x
    Oct 29, 2009
    2,515 (0.89/day)
    757
    lol well w/e it is its slightly cooler now
