Power Supply noise issue
FlamePSU
4 (0.10/day)
I have installed two different corsair power supplies RM series. RM650 and RM 750 ATX power supplies into my PC and hear this noise at random. Any ideas?
Maenad
S.T.A.R.S.
6,643 (2.03/day)
Jyväskylä, Finland
System Name Mah buddy
Processor AMD Ryzen 5 3600 @ PBO +200
Motherboard Gigabyte B550M Aorus Elite
Cooling Cryorig C7 RGB
Memory 32GB HyperX Fury DDR4-3200 @ 3466 16-18-18-36-1T
Video Card(s) Gigabyte GeForce GTX 1080 Ti Gaming OC Black
Storage 256GB SSD + 3x 480GB SSD + 2TB USB HDD
Display(s) 2x 24" 1080p60 @ Arctic Z2 gen3
Case Fractal Design Define Mini C
Audio Device(s) Onboard audio, Superlux HD668B
Mouse Logitech G MX518 Legendary
Keyboard Dell Multimedia Pro
VR HMD Oculus Rift CV1
Software Windows 11 Pro English
Sounds like it's resonating to me. Is it firmly secured and are there foam pads between the PSU and case?
Could be a wire hitting the fan blades too.
575 (0.85/day)
System Name Still waiting for a 5900x/3080 or 6800xt...or not.
Processor I9 9900kf w/ HEATKILLER IV PRO Copper Nickel
Motherboard MSI MEG Z390 ACE
Cooling BarrowCH Boxfish 200mm-HWLabs SR2 420/GTX&GTS 360-BP Dual D5 MOD TOP-Koolance PMP 450-EK D5 PWM G2
Memory 4x8gb HyperX Predator RGB DDR4 4000
Video Card(s) MSI RTX 2070 Duke 8G OC w/ Byski N RTX2080TI X
Storage XPG SX8200 PRO 1TB NVMe M.2 / Crucial MX500 1TB
Display(s) Acer XG270HU
Case ThermalTake X71 w/5 Noctua NF-A14 2000 IP67 PWM/3 Noctua NF-F12 2000 IP67 PWM/3 CorsairML120 Pro RGB
Audio Device(s) Klipsch Promedia 2.1
Power Supply EVGA SuperNOVA 1300 G2
Mouse Logitech G502 SE
Keyboard Black Aluminun Mechanical Clicky Thing With Blue LEDs, hows that for a name?!
Software Win10pro updated to whatever the latest MS crap is.
Sounds like its vibrating against the case.
33,200 (6.30/day)
Pull from case, verify with this.
Steps 3-7.
438 (2.16/day)
Processor Ryzen 5 3600
Motherboard B550 Elite
Cooling Hyperx 212
Memory Hyperx fury 16Gb DDR4 3333Mhz
Video Card(s) 3060 ti gaming oc pro
Storage Samsung 970 Evo 1Tb plus some HDDs
Power Supply MSI 750w
Mouse G502
this. try pressing your finger against the case near the PSU and see if the noise goes away
FlamePSU
4 (0.10/day)
Thank you for the reply, It is firmly attached, I do not have any foam pads underneath but I do have a dust filter underneath the fan could that cause an issue?
Thank you for the reply, What would you recommend as a possible solution? Or is it not really a major issue?
Steps 3-7.
Thank you for the reply, I will give this ago asap and get back to you!
Thank you for the reply, I have attempted this and the noise indeed does go away temporarily.
I have also attempted to reposition /push the power cable slightly which also causes the noise to go away temporarily.
575 (0.85/day)
If you can find a tiny strip of sound dampening foam, pieces of packing peanuts etc or some kind of dense thin foam to place between the psu and case that will likely take care of it. You only need very very small pieces for the corners of the psu to rest on.
It may also be something loose near the psu mount that's vibrating.
Edit- it may be the filter vibrating.
FlamePSU
4 (0.10/day)
Right I see what you are saying Maxfly I have some packaging foam which came with my PC case, perhaps I could cut that down to size and try that?
Or if I need sound dampening foam I will have to get some.
I will give your recommendation a go and let you know how it goes!
438 (2.16/day)
Cooling Hyperx 212
Mouse G502
This happens a lot. The fan should not make the psu case vibrate, and the case should have some anti vibration thing between it and the psu. Unfortunately even on high end PSU and cases this happens.
FlamePSU
4 (0.10/day)
I see what you are saying Bomby569 I was not aware that happens in high end builds, that is a shame to be fair but oh well
