Hello All!
I am in a pickle..
I have a 400W HP power supply with a 7 pin 6 wire connector going into the motherboard labeled "PWR CMD".
I changed my PC case for better airflow but I have a problem getting this wire to reach and connect into the motherboard because it is too short. I literally only need maybe 2-4 more inches on it.
My question is can i splice this wire to make it longer so that it will reach?
Can i use any type of wire with similar gauge? Perhaps some wire from a spare case fan as its similar gauge/thickness??
I looked online for awhile and i really have no other options, there are no adapters or extensions for this type of 7pin-6wire PSU->MOBO connector that i know of, and i am at a complete loss.
I can't change it out completely because it is hp proprietary, so the only thing i can come up with is to splice the wires to lengthen them the short amount that i need so that it can reach the MOBO and connect into it.
I have attached a picture of the connector and wire..
Any advice, suggestions, answers will be much appreciated, thank you !
I am in a pickle..
