Power Surge detected in new build
2,596 (0.61/day)
Likes
106
Republic Of Ireland
Processor Intel i5 4670k 4.0Ghz
Motherboard MSI Z97 PC MATE
Cooling Cooler Master Hyper 212
Memory 16GB Corsair Vengeance Pro DDR3 2400mhz
Video Card(s) XFX R9 Nano @1050Mhz
Storage Samsung Evo 840 250GB SSD + Seagate 500GB\8Gb 5400rpm SSHD\64Gb Lexar P20 USB 3.0 Drive
Display(s) Samsung 27" s27d390h + 15.6" 1080p Matte 95% Color Gamut
Case Aerocool GT-A
Audio Device(s) Beyerdynamic DT990-Pro 250 ohms Headphones\Edifier R1600TIII 2.0 Speakers\Creative Sound Blaster ZXR
Power Supply Antec High Current Gamer 620m
Mouse Roccat Kone XTD 8200Dpi
Keyboard Redragon Karura
Software Windows 10 64-bit
#26
This was with 4.4Ghz and ram at 1.65.
I'm going to try stock everything now and see what happens!
2,521 (0.79/day)
Likes
759
System Name Nightblade / Dell Latitude / Wife's Rig
Processor Core i5 4690K / i7 2720QM / FX-6100
Motherboard Nightblade ITX z97 / Dell 032T9K QM67 / Gigabyte GA-970A-DS3 Rev3
Cooling tower style cooler, plus one 120mm fan / stock blower / CNPS7000V
Memory Patriot Viper 2x8gb DDR3 2400 / Micron 2x4GB DDR3 / 2x4GB 2x2GB DDR3 1333
Video Card(s) MSI Gaming GTX 970 4GB / NVS 4200M 512MB / nVidia GTX 460 1GB
Storage 120GB ForceGT SSD (OS), 2TB WD Black, 250GB Seagate 2.5in / 320GB WD Blue /240GB SSD M500
Display(s) ASUS ROG SWIFT 1440P / Dell 14in @ 1600x900 / Vizio 1080p TV
Case MSI Nightblade Z97 / Dell Latitude / Corsair Full Tower
Audio Device(s) Realtek ALC1150, Microsoft Lifechat 3000 / Intel / ALC887
Power Supply Gold rated 600W / Battery with 95w brick / Antec EA-650 Green
Mouse MadCatz RAT5
Keyboard G510
Software Windows 10 Pro x64 on all
#27
yea you have one of those 4+4pin PSUs. the 8pin splits into 2 4pins so that it can be used with motherboards that only have a 4pin. they should combine together and plug into the 8pin
2,947 (1.04/day)
Likes
1,386
System Name The Sheriff / The Deputy
Processor 2500K / G4560
Motherboard ASRock P67Extreme4 / Gigabyte GA-Z170-HD3 DDR3
Cooling CM Hyper TX3 / Intel stock
Memory 16 GB Kingston HyperX / 8 GB Kingston HyperX
Video Card(s) EVGA GTX 960 SSC / Gigabyte GTX 1050 Ti LP
Storage SSD, some WD and lots of Samsungs
Display(s) BenQ GW2470 / Samsung SyncMaster T220
Case Cooler Master CM690 II Advanced / Thermaltake Core v31
Audio Device(s) Asus Xonar D1/Denon PMA500AE/Wharfedale D 10.1/Senn HD518
Power Supply Corsair TX650 / Corsair TX650M
Mouse Steelseries Rival 100/ Mionix Avior 7000
Keyboard Sidewinder
Software Windows 10 / Windows 10 Pro
#28
Your overclock is not stable. Please don't increase volatge on RAM, it is not recommended for Sandy Bridge to run above 1.50v (although it seems there are no issues up to 1.65v but it's good to be on a safe side especially if you run your sticks at stock 1600MHz)
2,596 (0.61/day)
Likes
106
Republic Of Ireland
Case Aerocool GT-A
#29
OK I've set everything back to default settings and switched the RAM sticks into the other slots just in case.
RAM is set to 1333Mhz at 1.5v and the CPU is set to default at 3.3Ghz.
Running prime95 now for the past 5 minutes and it has passed my main error for the mean time.
It does appear that the RAM is having issues??
Or am I wrong?
2,596 (0.61/day)
Likes
106
Republic Of Ireland
Case Aerocool GT-A
#30
I'm still suffering crashes grr!
I tried with one ram stick at a time and it still causes the same problems!
I think at this rate I must replace the PSU!
Is it normal for prime95 to only give the error to one core and not all of them?
JrRacinFan
Served 5k and counting ...
19,675 (4.75/day)
Likes
4,765
Youngstown, OH
System Name Gamer :Server and Android BuildBox
Processor r4 1400 (r7 1700 temporary): Xeon e5-2660
Motherboard Biostar X370 GT5 : Generic
Cooling CM 212+ : Liquid cooled
Memory 2x4GB Viper Elite 2667 16-18-18 : 2x8Gb Vengeance 1600 cl9
Video Card(s) XFX Double D R9 290 : XFX R5 220
Storage Toshiba 256GB NVME HGST 2x2TB Raid0 : WD 3TB + HGST 2TB + 480GB OCZ Trion 150
Display(s) ViewSonic VX2457-MHD 23.6" : headless
Case CM Masterbox RGB: DIYPC D480-W White Window
Audio Device(s) Radeon HDMI : Onboard
Power Supply EVGA 500b : Tt 775W Modular
Mouse Tt Challenger : None
Keyboard Rosewill Neon : None
Software Windows 10+ Zorin 12.3: Zorin 12.3
#31
I say go ahead and replace PSU anyways(you said it's been 4 years, I tend to replace every 2), and if that's not the case RMA the CPU.
2,521 (0.79/day)
Likes
759
Mouse MadCatz RAT5
Keyboard G510
#32
it is possible one core is bad... try removing the "affinity" from that core for your programs and see if that helps, if you know which one. I'm not sure of an easy way to do this though.
edit: you can set the number of cores used by msconfig > boot > advanced options. it doesn't let you choose which ones though.
