PowerColor Formally Launches Radeon RX 6900 XT and RX 6800 XT Liquid Devil
41,770 (8.19/day)
Processor AMD Ryzen 7 2700X
Cooling AMD Wraith Prism
TUL Corporation, a leading and innovative manufacturer of AMD graphic cards since 1997, today brings it's fastest AMD Radeon RX 6000 series models with its Liquid Devil series, designed for the most demanding gaming and PC enthusiasts that require the very best performance for their existent custom loop water-cooling.
PowerColor and EK teamed up to create the fastest AMD Radeon RX 6900 XT and RX 6800XT. The new PowerColor Liquid Devil series are powered by the revolutionary AMD RDNA 2, with Raytracing support, groundbreaking AMD Infinity Cache, and 16 GB of dedicated GDDR6 memory to deliver outstanding gaming experience while running with zero noise at the lowest temperatures with the beautiful designed and high performance full-cover EK water block.
The Liquid Devil, features a precisely engineered nickel-plated copper base. The copper base effectively increases heat transfer efficiency. While the stunning nickel-plated quality finish, as good as it looks, has a crucial characteristic that ensures the copper base avoids corrosion.
State of the Art PCB
The PowerColor Liquid Devil AMD Radeon RX 6900 XT and RX 6800 XT graphics cards come with a powerful VRM configuration, a 14+2 phase using the industry's best DrMOS as well as high polymer capacitors. This combination enables greater performance and power stability compared to the 13/12 phase found on the AMD reference card. With the robust and remarkable PCB design, PowerColor Liquid Devil can handle over 400 W power.
Extra Rage with Unleash BIOS Mode
Unleash the Liquid Devil, playing with two modes of operation OC for solid performance with more balanced energy consumption and Unleash for the highest clocks and break records.
Customize Your Custom Loop Coolant Color
Bundled with the Liquid Devil card, comes our Devil Dye pack, this creativity pack will allow users to transform their clear or white EK-CryoFuel coolants into beautiful, personalized, one-off colors.
Robin Seina
26 (0.06/day)
This seem nice. I assume, this is just card with EK waterblock preinstalled. So what is the price and availability? It is better than when buying card and block independently? What other components do I need to make it work? I already have Noctua cooler on my Ryzen 3700X and have Fractal Design R5 case with DVD drive installed.
2,953 (1.52/day)
Currently Norway
System Name Bro2
Processor Ryzen 5800X
Cooling Corsair h115i pro rgb
Memory 16GB G.Skill Flare X 3200 CL14
Case Fractal Design G
Audio Device(s) Realtec 5.1
Power Supply Corsair AXi 760W / Seasonic 750W GOLD
Mouse Logitech G402
Keyboard Logitech slim
Software Windows 10 64 bit
I wonder if I will be able to get this waterblock separately. Probably yes but you never know.
882 (0.25/day)
Slovenia
System Name PC.
Software Windows7 64....
Two for me please :) !
To cool the GPU you need to buy: Radiator (at least x120x240x25),reservoir , pump, connecting pipes, connectors, at least distilled water, fans. But if you add, CPU cooling as well you need a CPU block and a larger radiator. Optional control circuit for fans and pump RGP accessories display flow . but not required. GL.
510 (0.20/day)
Scotland
Processor 5800x
Motherboard b550-e
Memory cl14 - 16gb
Video Card(s) vega 64
Storage nvme evo970 1TB + ssd 750gb
Display(s) S3220DGF
Case h630 - modificated
Power Supply 750W - gold
Software 10 - 64bit
In last 4 months it's already 3rd post about this card, but still no price and date when it will be available..
654 (0.29/day)
Sokovia
System Name Alienation from family
Processor i7 7700k
Motherboard Hero VIII
Cooling Macho revB
Memory 16gb Hyperx
Video Card(s) Asus 1080ti Strix OC
Storage 960evo 500gb
Display(s) AOC 4k
Case Define R2 XL
Power Supply Be f*ing Quiet 600W M Gold
Mouse NoName
Keyboard NoNameless HP
Software You have nothing on me
Benchmark Scores Personal record 100m sprint: 60m
On paper, words are free.
2,969 (1.31/day)
System Name My all round PC
Processor i5 750
Motherboard ASUS P7P55D-E
Memory 8GB
Video Card(s) Sapphire 380 OC... sold, waiting for Navi
Storage 256GB Samsung SSD + 2Tb + 1.5Tb
Display(s) Samsung 40" A650 TV
Case Thermaltake Chaser mk-I Tower
Power Supply 425w Enermax MODU 82+
Buy me, if you can...
510 (0.20/day)
Scotland
Processor 5800x
Motherboard b550-e
Memory cl14 - 16gb
Display(s) S3220DGF
Software 10 - 64bit
some people already have it for ages :) and they just waiting for something like this sweety :) to upgrade their stuff :)
but like i said in a previous post, its already 3rd post about this GPU, and still nothing new they told us :)
1,803 (0.57/day)
You dont NEED a 240mm radiator. AMD's 295x2 managed just fine with a 120mm rad, and that was a monster compared to even an OCed 6900xt.
  • Like
Reactions: SQr
510 (0.20/day)
Scotland
Processor 5800x
Motherboard b550-e
Memory cl14 - 16gb
Display(s) S3220DGF
Software 10 - 64bit
The PowerColor Liquid Devil Series will be available on the week of March 15th.
882 (0.25/day)
Slovenia
System Name PC.
It was 45 mm 120 x120 mm if i remember well ! not 25 mm thick radiator ! The temperature regime increased in comparison on 6900xt . The bigger the radiator the better OC mode will be , more stable and higher CL. than with air cooled GPUs!
301 (0.37/day)
Availability of these should hopefully be a bit better, if only because it requires more investment to get this up and running without frying itself, even on a dedicated mining BIOS (still have to pay for 120mm Rad + Fan + tubing + connections + pump). The cards themselves would also lose value faster if they also didn't take care to include biocide and corrosion inhibitors to prevent corrosion or gunk build-up (assuming they would want to try and resell them afterwards).
The real issue is how badly marked up these would be more because other models are already marked up. I can understand a slight mark-up over the basic 6900XT MSRP due to the semi-custom EK WB, but given how everything's been inflated due to demand of the air-cooled variants, this one could probably be marked up even more as a side-effect.
558 (0.20/day)
Germany
System Name Main Machine
Processor Ryzen 9 5900X
Motherboard Asus ROG Crosshair VIII Dark Hero
Cooling Water cooling, EK-DDC 3.2 PWM, 1x360mm+1x240mm+1x120mm EK Rads, CPU TechN Ryzen 5000 waterblock
Memory 16GB G.Skill Trident Z Neo DDR4-3600 CL14
Video Card(s) PowerColor 6900XT Liquid Devil Ultimate
Storage 2xSamsung SSD 970 EVO NVMe 1TB, 1x Samsung SSD 840 EVO 1TB, 4x3TB Seagate
Display(s) ASUS ROG Strix XG27WQ 27inch 165Hz FreeSync Premium Pro
Case Cooler Master COSMOS C700P
Audio Device(s) Turtle Beach Elite Pro Tournament + Elite Pro TAC
Power Supply be quiet! Dark Power Pro 12 1200W 80 PLUS Titanium
Mouse Logitech G903 LIGHTSPEED Wireless
Keyboard ROCCAT Ryos MK Pro
The real issue is how badly marked up these would be more because other models are already marked up. I can understand a slight mark-up over the basic 6900XT MSRB due to the semi-custom EK WB, but given how everything's been inflated due to demand of the air-cooled variants, this one could probably be marked up even more as a side-effect.
Most probably at least 200€ over the price of regular RED Devil. :oops:
EK sells blocks for reference 6800XT/6900XT in range from 150€-220€ depending on which style one chooses
The regular Red Devil 6900XT for example cost 1449€ in Germany at Mindfactory. They have that card very often in stock.
So most probably these will cost in range of 1649€ to 1700€. :(
As also comparison they had Sapphire 6900XT Toxic limited Edition in stock for 1799€ but that is a special edition so premium price.
These are also kind of special. :rolleyes:
I hope PowerColor chooses higher binned chips for these otherwise only advantage of these would be temperatures and noise and not performance especially for 6900XT.
I had 6900XT Red Devil for one week before I return it back to Mindfactory.
I was not very lucky with that sample.
The performance was not that amazing. It was only about 5% faster than mine watercooled 6800XT while consuming much higher power to achieve this performance increase. :oops:
136 (0.15/day)
The worst part of this card is resale value...
As a veteran water cooling "enthusiast".
Much easier to sell a card when you slap the original cooler back on.
boidsonly
23 (0.02/day)
Go to AMD.com and check the "buy direct" link. Unfortunately there is no reserve/sign-up ability. Expect these new cards to Bot out in a minute or less.....
239 (0.30/day)
System Name Not a Threadripper but sill pretty good!
Processor Ryzen 9 3950x
Motherboard ASRock X470 Master SLI/AC (revision 1.02, BIOS/UEFI version P4.10)
Cooling EK-FB ASRock X470 Gaming K4 RGB Monoblock, EK-Quantum Kinetic TBE 200 D5 PWM, EK-CoolStream PE 360
Memory Micron 18ASF2G72AZ-2G6D1 ECC DDR4-2666 (dual rank, 4 sticks, 64GB, OC to DDR4-3200)
Storage Samsung 970 EVO M.2 2280 500GB PCIe Gen3x4 NVMe
Case Lian Li PC-O11 Dynamic Black
Power Supply Corsair RM750x
Mouse Logitech M570
Software Windows 10 Professional (64bit, version 19.09)
Benchmark Scores CBR20=9,538 (multi-core, stock) CBR23=24,074 (multi-core, stock)
Found the older 5700 XT Liquid Devil on Amazon for $1050 USD. I think at EK shop it was originally going between $600 to $700 when it was available so I'm not holding out any hope for good pricing for the 6900 XT Liquid Devil for awhile.
558 (0.20/day)
Germany
Well I had not that bad an experience when selling my custom cooled cards in the past.
It seem here in Germany we have many enthusiast who dare to buy used cards over eBay.:p
When I sell these cards I usually offer the original cooler as free addition to the package if somebody is interested to put it on again.
Vega 64 was sold very easily and with a good price on eBay of around 60% of original cost. I sold it after 2.5 years.
I was blown away when I sold Radeon VII watercooled on eBay.
Unbelievably I got 700€ for that in December 2020. :twitch:
My original cost was about 950€ with water block and I had the card for almost 1.5 years. :D
This made my move to 6800XT easier, financing large chunk of the 999€ that I paid for reference 6800XT which I have also now put under water. :D
1,848 (1.04/day)
System Name The de-ploughminator
Processor I7 9900K @ 5.1Ghz
Motherboard Gigabyte Z370 Gaming 5
Cooling Custom Watercooling
Memory 4x8GB G.Skill Trident Neo 3600mhz 15-15-15-30
Video Card(s) RTX 3090 + Bitspower WB
Storage Plextor 512GB nvme SSD
Display(s) LG OLED CX48"
Case Lian Li 011D Dynamic
Audio Device(s) Creative AE-5
Power Supply Corsair HX850
Mouse Razor Viper Ultimate
Keyboard Corsair K75
Software Win10
Should have sold your Radeon VII for 1000e, it's as fast as the 3090 in mining ETH:respect:
