Several months ago after a hardware failure, I had to put an old P4 CPU that I had laying around into my ASUS p5q se2 mainboard.
I recently purchased a core 2 duo e7500 to get me through until I can afford a decent upgrade. My bios is up to date and the mainboard supports the CPU. Upon putting in the e7500 I could not get it to post. The system powers up, no error beeps but will not post.
I am using 4 1gb sticks of Kingston DDR2 667.
I have tried unplugging all other hardware. I have reset the cmos. I have tried several bios versions. I have tried multiple power supplies (have a 700 watt in at the moment).
The only different result I can get is without ram I get the 4 beeps for no RAM inserted.
Knowing how unlikely it is the the CPU was DOA is it possible that the RAM is compatible with one CPU and not the other?
Unfortunately I do not have access to another PC in order to test the CPU. I am running out of ideas short of a DOA CPU or some kind of RAM problem.
The system works fine with the same hardware but with the P4 in.
Any help would be appreciated thanks.
