Problem with G.Skill DDR4 3200mhz on Asrock B450 Pro4
Geck0
3 (0.05/day)
Likes
0
#1
I upgrade my PC with a 2x8GB G.Skill Ripjaws V 3200mhz Kit - F4-3200C16D-16GVKB
Its impossible to boot with 3200mhz,i have tried raising voltage to 1.40, and nothing. The pc try to boot a few times, and then go back to default settings.
And when i try to boot with 2933mhz, i only get a blue screen.
I do not know what else to try or if my ram its broken...
5,136 (2.12/day)
Likes
2,060
Memphis, TN
System Name Black Prometheus
Processor AMD Ryzen 7 1700X @3.9GHz
Motherboard ASRock B350 Pro4
Cooling Corsair H70
Memory SK Hynix 32GB(8GBx4) DDR4 @2666MHz
Video Card(s) EVGA RTX 2070 XC Ultra Gaming
Storage Sandisk X300 512GB + Seagate 2TB
Display(s) HP LA2405WG 24" Triple Monitor (5760x1200)
Case DeepCool Matrexx 55 w/ 3x120mm Intake + 4x120mm Exhaust
Audio Device(s) Samsung 5.1 Setup
Power Supply Corsair RM750X
Mouse Logitech Trackman
Keyboard Dell OEM
Software Windows 10 EDU x64
#2
Full system specs and are you running the lad test BIOs
Geck0
3 (0.05/day)
Likes
0
#3
Oh sorry.
Yes latest bios, 1.80
Ryzen 2700X
Asrock B450 Pro4
G.skill 3200 2x8gb
nvidia 1070ti
5,136 (2.12/day)
Likes
2,060
Memphis, TN
Cooling Corsair H70
Keyboard Dell OEM
#4
Oh sorry.
Ryzen 2700X
Asrock B450 Pro4
G.skill 3200 2x8gb
nvidia 1070ti
The latest BIOs for that board is 5.10
But looking at the support list I don’t see that RAM kit listed as supported. You May have to manually tweak it instead of auto and run 2933MHz
Geck0
3 (0.05/day)
Likes
0
#5
5.10 is for Asrock B350, mine is B450 and the latest in asrock web is 1.80
9,200 (3.97/day)
Likes
11,470
Massachusetts
Processor i5 8600k
Motherboard Asrock Z370 Extreme 4
Cooling Corsair H-110i GTX
Memory 2x 4Gb Crucial Sport LT
Video Card(s) MSI GTX 980 Gaming
Storage Samsung 850 evo 250Gb
Display(s) Dell Ultra Sharp Widescreen 24" 1200P
Case Fractal Design Meshify-C
Power Supply Seasonic Focus+ 750 Gold
Mouse Logitech G502 spectrum
#6
did you try & set it to auto ? i see you set default, but maybe it isnt on auto..
try a single stick?
its not supported officially by Asrock, and that board isnt in the QVL for Gskill either. may need to return & order a QVL set
cdawall
where the hell are my stars
27,599 (6.00/day)
Likes
8,459
Houston
System Name All the cores || Bedroom Gamer
Processor 2990WX || 6700T
Motherboard Asrock X399M || MSI H170l
Cooling XSPC RayStorm Neo, MCR220-Stack+MCR220+MCR320, D5-PWM+EK X-RES 140 || Intel copper cored stocker
Memory 4x8GB G.Skill Trident Z 3200 CL16 || 2x8GB EVGA 2400
Video Card(s) (2) EVGA SC BLACK 1080Ti's || AMD Vega FE 16GB
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB|| PM951 128GB+evo 850 500GB+OCZ Vector 180 480GB
Display(s) Dell UP2414Q 3840X2160@60hz || 42" Plasma
Case Caselabs Mercury S5 || GEEEK A50
Power Supply Seasonic Prime 1200w || Corsair 450w SFX
Mouse Thermaltake Theron || Steam controller
Keyboard Thermaltake Poseidon ZX || Steam controller
Software W10P
Benchmark Scores Zoom zoom mofo
8,057 (2.47/day)
Likes
2,171
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
#8
1,042 (0.40/day)
Likes
1,456
Indonesia
Processor AMD Ryzen 5 2600X @ 4.1 Ghz
Motherboard ASUS STRIX X470-F
Cooling Thermalright True Spirit 140 POWER
Memory G.Skill FlareX 16 GB DDR4-3200
Video Card(s) Sapphire RX Vega64 8GB
Storage 512 GB Samsung 850 Pro + 2 x 4 TB WD Black
Display(s) LG 27MB85Z
Case Fractal Design Define R5 Black
Power Supply Seasonic Prime 650W
Keyboard DZ60 (Cherry MX Retooled Black) | Leopold FC980C (Topre 45g)
Software Windows 10 1803 x64 + Ubuntu 18.04 LTS
#9
cdawall
27,599 (6.00/day)
Likes
8,459
Houston
Software W10P
#10
Ripjaws V 3200 Mhz CL 16 so high possibility it's Samsung D-die.
That part number kicks for anything from Samsung D die to hynix mfr. Timings are 16-18-18 which is more typically a hynix or micron product.
25,020 (5.88/day)
Likes
8,394
Siux
2 (0.06/day)
Likes
1
Croatia
#12
I know that this is old post, but maybe it will help someone.
I have the same MBO. Check if you memory sticks are in correct slot. A2-B4 are correct ones. In A1-B2 you wont get more then 2666mhz.
I almost gave up of this, and then i saw Eidairaman1's post (post above mine)with link to MBO manual :D There is little table in there which says everything, which ofcourse i skipped at first reading :p
1,612 (1.51/day)
Likes
1,786
Processor Ryzen 5 2600X
Motherboard MSI B350M Gaming Pro
Cooling Scythe Kotetsu with AM4 bracket
Memory PNY Anarchy-X XLR8 Red DDR4 3200 MHz C15-17-17-17-35
Video Card(s) XFX RS RX 480 GPU @ 1288 MHz - 1.045 mV from 1.175 | GDDR5 @ 2075 MHz
Storage Samsung 970 EVO NVMe M.2 500 GB, SanDisk Ultra II 480 GB
Display(s) Samsung SyncMaster C27H711
Audio Device(s) Realtek ALC887 (dead)
Power Supply EVGA 850 BQ
Mouse Kingston HyperX Pulsefire FPS
Keyboard Logitech K520
Software Windows 10 Professional 64-bit
#13
Thank you for joining the forums, and leaving a post. Welcome to TPU.
196 (0.07/day)
Likes
62
System Name Arena-Fighter6a
Processor AMD Ryzen 7 2700x
Motherboard Asrock x470 Taichi Ultimate
Cooling Air
Memory 2x16GB 3000MHz CL16 DDR4
Video Card(s) Gigabyte Radeon R9 380 4GB
Audio Device(s) Creative X-Fi Titanium PCIe x1
Power Supply Corsair HX850 80+ Platinum
Software Windows 10 x64 Enterprise/Ubuntu Budgie amd64
#15
Recently i was facing similar issue and cause turned out to be a psu. I replaced old one with brand new and everything works fine.
