random system troubles
191 (0.03/day)
System Name "the strong silent type"
Processor i5 3570k
Motherboard Asus Maximus V Gene
Cooling Thermalright Archon
Memory G.Skill RipjawsX D3 8GB 1866-899 RipjawsX K2 GSK
Video Card(s) XFX 6950 1GB dualfan
Storage Crucial M4 128GB / Samsung F3 HD103SJ 1TB
Display(s) LG W2253V
Case CM 690 II Advanced
Power Supply Coolermaster Silent Pro Gold 600w
Software Win 7 Ultimate 64bit
I recently had a BSOD, probably because after 3 months my system suddenly decided my overclock wasnt stable after all, and the thing is all kinds of strange symptoms started showing up, before i took out the oc and updated my mobo's bios, it froze at random points in the startup. Afterwards those were gone, then windows suggested I might have a memory problem, so i ran the build in windows mem check and the memtest86 utils, both not showing any problems. But i still feel some mallfunctioning part is slowly demolishing my windows installation. I however dont have a clue which part.
Right now I'm running my system default bios settings with only the memory settings at xmp, to find out if thats the culprit.
My system seemed sort of ok last 3 days but tonight suddenly my internet went out and when i checked the system logs this showed:
Windows detected your registry file is still in use by other applications or services. The file will be unloaded now. The applications or services that hold your registry file may not function properly afterwards.
DETAIL -
6 user registry handles leaked from \Registry\User\S-1-5-21-3496739161-1968194996-2505047869-1000:
Process 1544 (\Device\HarddiskVolume5\Windows\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3496739161-1968194996-2505047869-1000\Software\Policies\Microsoft\Windows\CurrentVersion\Internet Settings
Process 1544 (\Device\HarddiskVolume5\Windows\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3496739161-1968194996-2505047869-1000\Software\Microsoft\Windows\CurrentVersion\Internet Settings
Process 1544 (\Device\HarddiskVolume5\Windows\System32\svchost.exe) has opened key \REGISTRY\USER\S-1-5-21-3496739161-1968194996-2505047869-1000\Software\Microsoft\Internet Explorer\Main
it also does this a lot when utorrent is working, i did recently ( 3 days ago ) update my LAN drivers from intel.
and all kinds of other errors related to my internet connection suddenly mallfunctioning.
Session "Circular Kernel Context Logger" failed to start with the following error: 0xC0000035
I havent a clue on how to find out what is going wrong, anyone got any ideas.
Cheers.
Run a system scan with defender or mse
You think it's a system hack or something?
I did run several virus tests in the last couple of days.
Spyhunter 4 windows defender and MSE and spyware doctor.
I've also been getting loads of these
Session "Microsoft Security Client OOBE" stopped due to the following error: 0xC000000D
also reinstalled the thing etc didnt help
Running a full MSE scan now. But Im doubting it'll turn anything up
Update,
I've ran about 6 virus and anti malware scanners, and switched to avast because of the failing mse oobe proces over and over again.
But nothing has really turned up, I will keep an eye on things, apparently my ISP is under ddos attacks a lot this week, so maybe they've upped the security and kicked me off for a bit because of utorrent making too many connections. Just mindlessly spitballing here. :/
oh boy, everything falling apart then
freezing at random points of startup, was that before windows loaded?
how are your SMART values of the hard drive(s), how are the cables, everything plugged in tightly? ports are reliable? try another port?
Well crystal disk info says everything is peachy.
I'll go over the cables tommorow, just to make sure, I'll take out the memory and put it back in again etc.
running prime 95 blended now for a couple of hours, all is good, only error i get now is
Het stuurprogramma \Driver\WUDFRd kan niet worden geladen voor het apparaat WpdBusEnumRoot\UMB\2&37c186b&0&STORAGE#VOLUME#_??_USBSTOR#DISK&VEN_&PROD_USB_DISK_2.0&REV_PMAP#0796150263B006E5&0#.
Every time i enter a memory stick or something like that. I kinda wonder if that is the reason i had the startup problems because i often had usb sticks in the computer whilst booting.
Though i have disabled anything usb like being able to alter boot in the bios, that error might be enough to upset the booting?
Other then that i had a memory exception crash whilst on the desktop which didnt turn into a bsod, I couldnt dig out the error in the windows log afterwards though. (this happened about 3 days ago)
It's all not big problems but so many of em happening, I still feel something is sneakily destroying my windows installation :P
I've been up and running for 26 days since the last post, however since last night, suddenly I'm getting a new apparently bad error
Event 474 ESENT
Windows
4416
Windows:
D:\Index\Search\Data\Applications\Windows\Windows.edb
28606464 (0x0000000001b48000)
32768 (0x00008000)
-1018 (0xfffffc06)
[56155615d473632b:2f972f9749067923:79e879e888729b39:43aa43aab9014bf4]
[4469bb96d462690b:2f972f9749067923:79e879e888729b39:43aa43aab9014bf4]
872 (0x368)
I got 31 of those in the last 24 hours. most of em 4416 others being 3728 3828 3436.
After i totally shut down everything and took the power off for 10 mins, the computer was massively slow starting up again.
I did a sfc /verifyonly as some forum suggested, which returned no errors.
Googling the problem seems to suggest a faulty CPU as possible cause. (which I was kind of thinking somehow even before this latest problem started showing up)
Anyone have any clue as to what I should do next? how do I find out which harware part is the culprit? I dont have any spare compatible parts laying about to switch things out.
I've never overclocked the thing beyond 1.28v and 4.5 ghz, though I've gotten a lot of bsods getting the thing stable over time.
Event 474 ESENT
Windows
4416
Windows:
D:\Index\Search\Data\Applications\Windows\Windows. edb
32768 (0x00008000)
-1018 (0xfffffc06)
[56155615d473632b:2f972f9749067923:79e879e888729b39 :43aa43aab9014bf4]
[4469bb96d462690b:2f972f9749067923:79e879e888729b39 :43aa43aab9014bf4]
872 (0x368)
First, check your cables for the hdds/ssds and connections.
Then, run chkdsk /f on all drives.
Now, you can try, either, turning off windows search indexing or rebuilding the database files.
And, test to see if your are still getting that event.
And, if you believe Windows search indexing is already disabled, check to be sure in the services section of the administrative tools.
Some other info:
Change advanced indexing options
And, if you want to un-install search, altogether --> Uninstall the Windows Search Engine
Event 474 ESENT
Windows
4416
Windows:
32768 (0x00008000)
-1018 (0xfffffc06)
872 (0x368)
If you cant swap stuff out try downclocking the cpu permanent so its very low with all other frequency as is ie mem etc, running cold and slow with ample power should improve instability if it is the cpu , you could try doing the same with other components until you are sure of the cause.
you mean because it'll tax the cpu more because I'll bottleneck it?
I am already running without any overclock for a month now btw. You want my to clock it as low as possible?
When I think back on it the problems originated when I installed framework 4 + 6 updates because some program claimed i hadnt installed it even though I already had.
Could this have messed up things?
I've rebuild the search database, and will replug all the cables tommorow.
Tnx for the advice peeps :)
I just ment that running even lower then stock and turning all eco features off should make the processor as stable as its possible too but you can use the same ideology with other parts of the system because whenever Ive had the issues your stateing its ended up either a very slightly unstable memory, cpu or northbridge oc or high all round temps after a while causing it, sometimes a motherboard just Likes a bit more Tras timing on its memory for eg
Sometimes when you oc everything the slightest change can cause real havoc as do failed boots after a few and isolating the culprit a definitely as possible is better then wasted money
Anything is possible.
If all else fails and you want to, you can try this:
First...Microsoft .NET Framework Repair Tool
Overview
This tool troubleshoots common issues with the setup of or with updates to Microsoft .NET Framework setup installation. Additionally, this tool tries to resolve these issues by applying known fixes or by repairing the installed product.
Note: The current version of the tool supports repairing the .NET Framework 4, .NET 3.5 SP1 (includes .NET 3.0 SP2 and .NET 2.0 SP2).
Some more info for reading: Unified .NET Framework Troubleshooting Guide
So the former problems are a thing of the past but now I've gotten a BSOD with nothing overclocked and whilst just browsing. (which makes me cry)
This seems to state something is wrong with the videocard, at least when i google the error code, and when I've come to think of it, I've been having this problem since the day I bought this graphicscard, and I've used it in two different systems. Might it be that the graphics card is faulty? I kinda think that I might've been blaming unstable overclocks falsely for my bsods.
I've driver sweeped and reinstalled the latest AMD drivers, however the error doesnt happen often enough or during a specific phenomenon for me to manipulate a bsod.
Does anyone have any suggestions on how to find out if it's a hardware or driver problem, or if the BSOD is not gfx related even if I might think so,
thanks again for any help.
