Razer Blade 15 Advanced Model ( 2019 ) High Temps
theoriginal
3 (0.10/day)
Hello. I had the chance to buy a razer blade recently. I have been using the computer for 2 weeks. There was no problem except warming up.
During the game (I tried CS: GO, Fall Guys, GTA-5, while playing LoL);
  • GPU (RTX 2070 Max-Q), changes between 70-80 C. (Approx 70 for LoL, and 80 for GTA.)
  • CPU (i7-9750H), changes between 80-90 C.
As I read from some forums, i am not worried that it gets hot while playing games, it doesnt bother me. Generally, they talk about heating problems in most of the gaming laptops. In a few razer blade test videos I watched, the temperatures were more or less like mine.
My main concern is that the computer gets too hot when I'm not playing games. I didn't buy this computer with the main purpose of gaming. I needed a laptop for long-term use. I saw that the razer blade was highly praised and the processor graphics card, etc. was good enough for me.
Today I turned on my computer, which was completely cold. I just watched Netflix for about 50 minutes. During this time I used the computer on battery. I will add photos of the degrees below. The computer goes back and forth between 55-60 degrees. I can never put the computer on my knees or anything. The case is made of titanium (I am not sure, it could also be aluminum), so I am feeling the heat even more. I am writing here because I do not know if it is normal for this razer blade to get so hot when using it on idle.
Bataryada kullanırken sıcaklık.png throttlestop ayarlar.png cpu undervolt.png tpl.png
In the first photo, when using on idle, there are temperatures, how much of the processor is used and speed values in mhz.
The other 3 photos belong to the ThrottleStop application where I did the undervolt process. I use this profile while only on battery.
I tried many things, but somehow I could not lower the computer to 40-45 degrees. Is it normal to get this hot while using on idle? I also couldn't understand what caused it to get so hot. Only 5-10% of the CPU is used and thanks to throttlestop the CPU does not go above 1.5 GHz, but for some reason the laptop does not go below 55 degrees. I would be very happy if you could help me work this out.
I leave the specs of the computer below.
Razer Blade 15 Advanced Model (Mid-2019)
CPU: Intel i7-9750H
GPU: RTX 2070 Max-Q
Ram: 16 GB
Display: 240 Hz, 1080p
3,190 (0.56/day)
Ikenai borderline!
Read the third line of my signature.
Then read https://www.laptopmag.com/uk/reviews/razer-blade-15-base-model
The bottom of the laptop reached 102 degrees Fahrenheit and the center of the keyboard hit 98 degrees after we watched a 15-minute video in full-screen mode.
This is perfectly normal and there is nothing you can do about it, except to try undervolting the GPU as well.
unclewebb
RealTemp Author
2,276 (0.50/day)
With nothing open other than ThrottleStop, what does ThrottleStop report for C0% when idle? An average load of 5% to 10% when idle is a huge load. Open the Task Manager, go to the Details tab and find out what is running on your computer. Here is a number to shoot for when idle.
You should also be seeing all 6 cores spending 99% of their time in the core C7 state.
By whom? Many laptop review sites are extremely biased. They do their best to talk around any issues out of fear of losing access to new laptops to test. If cool and quiet is important to you, a gaming laptop with a 6 core 9750H and 2070 GPU is usually not the best choice. Get rid of the useless background tasks and it might not be so bad.
9,809 (4.47/day)
Sunshine Coast
System Name Black Box
Processor Intel i5-9600KF
Motherboard NZXT N7 Z370 Black
Cooling Cooler Master 240 RGB AIO / Stock
Memory Thermaltake Toughram 16GB 4400MHz DDR4 or Gigabyte 16GB 3600MHz DDR4 or Adata 8GB 2133Mhz DDR4
Video Card(s) Asus Dual 1060 6GB
Audio Device(s) No need.
Power Supply FSP Aurum 650W
Mouse Yes
Keyboard Of course
Software W10 Pro 64 bit
Today I turned on my computer, which was completely cold. I just watched Netflix for about 50 minutes. ....... I do not know if it is normal for this razer blade to get so hot when using it on idle.
Watching Netflix is not "at Idle".
Then you state "using it at idle" which is a contradiction in itself.
theoriginal
3 (0.10/day)
C0% does not get below 10% and it changes between 10% - 30% right when I am writing this ( i have nothing else opened other than chrome and throttlestop ).
Here is two photos of my Task Manager's details tab. I do not really know what I should look for so I am putting it down here.
And this one is a picture of ThrottleStop when I am just writing these.
I will be grateful if you can help me with which tasks I should end on task manager.
Thank you.
644 (0.63/day)
System Name Silent
Processor i7 8700k delidded and OC'd to 5.2 daily 5.3 benchmarking/R9 3900x
Motherboard Asrock Z370 Extreme 4/MSI MEG ACE x570
Cooling Noctua D15/Noctua U12A
Memory 16GB G-Skill Trident Z RGB 3200 14CAS/32GB Team Dark Pro 3200/14
Video Card(s) 1080ti w/morpheus cooler w/Noctua 140mm fans/Quadro RTX 4000
Storage Optane 905p 480GB, 2 x 1TB 970 Pro Raid 0/Optane 905p 480GB
Display(s) 240hz 1080p/4x1440p 60hz
Case Coolermaster Cosmos C700M
Power Supply Seasonic Prime Titanium 600w Fanless
Benchmark Scores Cinebench 1725
Repaste with liquid metal to drop temps by 25c.
unclewebb
RealTemp Author
2,276 (0.50/day)
When I type really, really fast on my keyboard, the C0% goes up by maybe +0.5%, at the most. There are some poorly written keyboard and mouse track pad drivers that can suck up a lot of CPU resources. Try running the Resource Monitor and organize the running tasks by average CPU usage. Keep an eye on that while typing into a Notebook document. Some software might be working hard as it sends your keystrokes around the world to someone else.
Greenshot, SteelSeriesEngine3, your Razer software or maybe your antivirus program is working hard to keep your computer safe. It is difficult to come in after the fact and start picking through what has been installed on your computer. All I know is that after a clean install of Windows 10, a CPU needs to spend very little time in the C0 state to process all of the background tasks including ThrottleStop. You have more than 1 core constantly working just processing background sludge. This alone can kill battery run time. After installing anything on a computer, you need to keep a close eye on how it effects your idle C0%. Some software is doing way too much background processing when it really does not need to be.
Using the Windows Power Saver profile or forcing your CPU to run slow by setting Speed Shift EPP to 255 might not be doing you any favors. A slow CPU is an inefficient CPU. I would use the Windows Balanced power plan and I would not check the Speed Shift EPP box. Let Windows 10 manage the EPP value. When Speed Shift EPP is not checked in ThrottleStop, open the FIVR window and watch the monitoring table to see what Speed Shift EPP value your CPU is using. Move the Windows power slider back and forth and see how this changes.
644 (0.63/day)
System Name Silent
All of the above are wrong. On my blade, same model, simply put CPU+GPU in synapse to custom high performance, repaste, and enjoy temps never going above 75c while CPU boosts to 4.1 all core and GPU boosts to 1715mhz.
With a -150mv undervolt on CPU/cache.
theoriginal
3 (0.10/day)
I dont really know what happened but my PC is running cooler for the last 2 days. I continued to watch videos on battery just to check the temps and I never see them going more than 50 C. It is generally around 45 C. So I am happy with the results.
Thank you for spending your time trying to help me here. I appreciate that.
