Real problem overclocking rx480
Jorgey17
22 (0.01/day)
Miami
I use NOD32. Its great. That shouldn't be it. What do you have you memory clocked at? Clock it down from/under 2000 to eliminate that.
I have the memory as it comes with the gpu 2000
340 (0.12/day)
Processor 8700k OC @ 5GHz (1.35 V)
Motherboard ASUS Prime Z390-A
Cooling Corsair H100i v2
Memory 16GB DDR4 OC @ 3000MHz
Video Card(s) EVGA RTX 2070 XC Ultra
Storage 4 x 250GB PNY SSD & WD BLACK 1TB HDD
Display(s) Samsung UHD 4K / BenQ RL2455HM
Case NZXT H500i
Power Supply Corsair 750W
Windows defender is just fine. Another good alternative is AVAST. and its free. Turn on defender and see if windows will let you run that program.
Jorgey17
22 (0.01/day)
Miami
I dont have nod32 i have windows defender and my friend told me that is possible to windows defender is blocking the overclock
I can run the program but it crashes after 7 seconds around 7 secs just when i overclock without overclock its run well
340 (0.12/day)
Case NZXT H500i
Windows defender cannot block the overclock. Enable it to make Windows happy.
78 (0.02/day)
Michigan
Processor AMD 5900X
Motherboard AsRock B550 Phantom Gaming-ITX/ax
Cooling Swiftech Apogee Drive 2
Memory GSkill Trident Z F4-4266C17D-32GTZRB
Video Card(s) Nvidia 3800FE (Byski WB)
Storage WD Black SN750 NVME
Display(s) LG 34UC88
Case NCASE M1 (1st edition)
Power Supply Corsair SM600
Mouse Mionix NAOS 7000
Keyboard Corsair K70 Lux
Have you tried uninstalling Afterburner, Trixx, etc and just tried OC'ing through Wattman? I think you need to give that a shot. If you can't even OC through Wattman, maybe it's either a driver problem or the card itself?
40,435 (6.59/day)
@cdawall, you own some 480s what do you think bro?
cdawall
where the hell are my stars
27,680 (4.27/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
Jorgey17
22 (0.01/day)
Miami
Not a clue, but I have clocked some with nod32 enabled without issue
I going to try when i get home with the windows defender on ... if no results i will try with other program to overclock i will let you know guys thanks for the help
Ok so i tried again with a fresh install in msi afterburn and with windows defender on .. and in 1359 mhz the benchmark (32 bits) the benchmark put a black screen and put my overclock back to 1328 ... any suggestions ???
40,435 (6.59/day)
Adjust your voltages up.
340 (0.12/day)
Case NZXT H500i
are the VRMs being cooled?
AsRock
TPU addict
18,871 (3.07/day)
UK\USA
Cooling D15
Audio Device(s) Yamaha RX-V677 \ Yamaha CX-830+Yamaha MX-630 Infinity RS4000\Paradigm P Studio 20, Blue Yeti
Its a custom loop power supply not even 6 month old
All so meaning what brand of PSU do you have and whats the wattage and more importantly ampage ?.
Everything is cooled ... even this moment
What video card do you have can you link the one you have ?.
Jorgey17
22 (0.01/day)
Miami
Hey i have corsair CX850M and i have i seageta barracuda 1tb ..1ssd 400 gb ..corsair watercooler for fx 8370 ..h100iv2
4 rams ddr3 8 each one ..the pump from de loop and fans .strips neons ligths and 3 more fans front back and down and finally the gpu .. im overclocked fx 8370 at 4.7 ghz running at 1.53 volts
Here
414 (0.09/day)
brčko dc/bosnia and herzegovina
System Name windows 10 pro 64bit
Processor i5 6600k 4.4ghz 1.25v
Motherboard asus maximus viii gene
Cooling BeQuiet Dark Rock pro
Memory 2x8(16)GB 2860mhz
Video Card(s) gtx 1070 EVGA
Storage ssd x2 128gb raid0/ ssd480gb
Display(s) AOC 1440p 75hz
Case Aerocool DS Cube
Audio Device(s) asus motherboard intergrated
Power Supply be Quiet pure power L8 600w
Mouse Corsair Ironclaw wireles
Keyboard Logitec G213
Software my favorite World of Tanks :) is that a software?? :)
you never told us what voltages are you using??Those card are not OC friendly..,they do not go much.. ,and even for little OC you need to increase the voltages
But 50mhz OC realy should be easy to do!!
1,618 (0.29/day)
i'm pretty sure i remember someone showing with readings that the voltage was NOT being applied on their 480 or 470 from software, & therefore the overclock was still on stock voltages
is there any proof that your voltage goes up (or down)? if you have a power meter, or if the temperature changes when voltage changes
Jorgey17
22 (0.01/day)
Miami
I check it on the afterburner and the top voltage goes to 1.45
This is the stable i can get if i push the voltage it crash
cdawall
27,680 (4.27/day)
Houston
Processor 2990WX
Software W10P
So I have tried not to say this but more than likely the issue is the motherboard having the PCI-e slot overdrawn. Which brand and model 480 are you using?
Jorgey17
22 (0.01/day)
Miami
Here
2,707 (0.80/day)
On The Highway To Hell \m/
So...it's basically the XFX reference version.
http://www.xfxforce.com/en-us/products/amd-radeon-rx-400-series/rx480xxx-rx-480m8bfa6
And you're wondering why you can't OC it for shit? Here...read this.
https://www.techpowerup.com/reviews/AMD/RX_480/27.html
BTW, you already have OCed it 40MHz beyond stock. 4x the 10MHz you claimed was causing an issue. If you mean 10MHz more than 1328MHz...good luck. As in you'll be lucky with a reference version to achieve that. Water cooled or not. The limitation is likely the weak VRM.
1,080 (0.16/day)
Look behind you!!
System Name NEW
Processor Intel 4770 non-K
Motherboard Gigabyte H81M-DS2V
Cooling CM Hyper 212 plus
Memory 16gb Muskin
Video Card(s) XFX 380X 4gb
Storage Sandisk 120gb plus WD blue 1tb
Display(s) AOC 23.5 LED bl
Case XIGMATEK
Audio Device(s) motherboard
Power Supply Cooler Master 500
The wonderful world of XFX. I wouldn't expect to much out of it OC wise.
Could try reseating your water block maybe.
8,929 (3.36/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
I thought reference models have a 6 phase VRM , shouldn't that be plenty ?
To OP : You might want to take into account the silicone lottery mate , I have heard of plenty 480's that don't overclock for shit even with custom PCB's and very good cooling , apparently there is a ton of variance in them. So maybe time to give up ? Of course unless there might be a problem with the rig. But just so you know , top overclocks are at the ~1400-1450 mhz mark and unless you really want a benchmark score increase , I would not bother with it any further , you ain't gonna see huge improvements in FPS.
555 (0.09/day)
Indiana
System Name Evil Dragon
Processor AMD FX-8320 Vishera @4.7ghz
Motherboard Asus 970 pro gaming Aura
Cooling Corsair Hydro Series H100i V2(fully Lapped). 4 40mm NB/VRM fans. 6 Thermaltake Riing 12 Series fans
Memory 2X8gig GeIL EVO Veloce Series DDR3 1600 @9.9.9.26
Video Card(s) Powercolor Red Devil RX 480 (1400/2100)
Storage PNY XLR8 480gig SSD. Patriot Pyro SE 60gig SSD.
Display(s) ASUS VP228H LED
Case Thermaltake Core V31
Audio Device(s) Onboard Realtek ALC1150 W/Creative Sound Blaster Cinema 2
Power Supply EVGA 850 BQ 110
Keyboard Roccat Isku FX
As someone who has owned 2 MSI Gaming 970 mobo's, I can tell you you are pushing that board to its very limits. It has cheaper 6 phase VRM's that don't handle a lot of power. I can post a pic of a burned VRM on one of mine to illustrate that fact.
That 480 being a 6 pin connector is drawing part of its power through the pci-e slot, putting more stress on the VRM.
480's aren't strong overclockers. It's just a fact. Having stable, clean power is a must to get any real clocks. And even then, you may not win the silicone lottery.
Jorgey17
22 (0.01/day)
Miami
Thanks for all the help i just give up the far i can go is 1370 mhz and doing magic ....thanks again guys
40,435 (6.59/day)
Here
Detune that CPU vcore to 1.48
