Recently bought a 4k monitor, wondering which parts should I upgrade next in my PC
Innerverse
4 (0.04/day)
Hello! First post here.
So I recently bought the BenQ PD2700U 27 inches 4k IPS monitor and since I've been on one 1080p monitor for the last decade, I thought maybe it's time to upgrade something else in my rig soon since 4k is much more demanding (I believe?). I use my PC for various reasons, i'm a graphic designer and video editor (but I never edited in 4k before, don't think i'll be using 4k footage anytime soon but it will be a thing in the long run) and i'm also a gamer, I was able to run pretty much any games in high settings at 1080p and 60fps, obviously I don't think i'll be able to run 4k yet but perhaps. I didnt try yet. My main focus for the near future isn't to run 4k gaming at 60 fps, I just want to make sure the PC run smooths for my multimedia work when im using both my monitors (photoshop, premiere pro). So far everything run smooths, but I can definitely tell it's not as fast as it was before adding the 4k screen and I didn't do any heavy multimedia work since receiving my screen.
Here is my current set-up:
Monitors: 27'' 4k + 24'' 1080p (both at 60 hz)
Motherboard: Asus P9X79 Deluxe
CPU: i7 3930k (hexcores @ 3.2 GHz)
GPU: GTX 1060 6gb
RAM: 16 gb DDR3 (2x 8gb @ 1600 MHz)
Storage: 240 gb SSD + 2 tb HDD
System: Windows 10
So basically my question:
Is my set up okay for a while still? If I had the budget to upgrade one part first, what should it be? Or is it better to wait longer, save up more money to upgrade more parts together at the same time later down the road.
PS: I never did any overclocking, should I ?
Thank you for your time!
FordGT90Concept
"I go fast!1!11!1!"
25,843 (6.16/day)
IA, USA
System Name BY-2015
Processor Intel Core i7-6700K (4 x 4.00 GHz) w/ HT and Turbo on
Motherboard MSI Z170A GAMING M7
Cooling Scythe Kotetsu
Memory 2 x Kingston HyperX DDR4-2133 8 GiB
Video Card(s) Sapphire Radeon RX 5500 XT Pulse 8 GiB
Storage Crucial MX300 275 GB, Seagate Exos X12 TB 7200 RPM
Display(s) Samsung SyncMaster T240 24" LCD (1920x1200 HDMI) + Samsung SyncMaster 906BW 19" LCD (1440x900 VGA)
Case Coolermaster HAF 932 w/ USB 3.0 5.25" bay
Mouse SteelSeries Sensei RAW
Keyboard Tesoro Excalibur
Graphics card for sure but if you're happy with how the 1060 is running then no sense in changing it.
I'm waiting for Arcturus & Ampere for 4K because both should be on 7nm, Arcturus should be competitive with Ampere, and the two combined should result in more performance per dollar while having enough transistors to reasonable render at 4K.
5700 XT struggles at 4K and RTX 2080/2080 Ti is a blatant rip off.
4,151 (1.78/day)
Kiev, Ukraine
System Name WS#1337
Processor Ryzen 5 1600X
Motherboard Gigabyte x470 AORUS Ultra Gamin
Cooling Xigmatek Scylla 240 AIO
Memory 2x8GB Team T-Force Vulkan DDR4-3000
Video Card(s) MSI RTX 2060 Super Armor OC
Storage Adata SX8200 Pro 1TB
Case Chieftec AL-01B-OP
Audio Device(s) ALC1220
Mouse Logitech G603
Keyboard Zalman K500 modded (Gateron brown)
Software Windows 10, Ubuntu 18.04 LTS
I'd start saving for the whole system upgrade. If it works for now, just keep what you have and plan for the future. I did the same when I bought my 4K Samsung: kept my Skylake rig w/ GTX1060 for as long as I could, and then upgraded to 1st gen ryzen when the prices were so low that I couldn't resist the upgrade itch.
You are in a better position, cause you have some time to fill up the piggy bank for upcoming GPUs, and wait for a possible price drop on current-gen CPUs/boards.
125 (0.06/day)
Given the X79, track down a Xeon E5-1680V2 IVB-EP 8c/16t. It's unlocked, so low 4ghz is a cinch. Add another 2x8gb DIMMs for quad channel. Stick with the 1060 & 1080p60 gaming until current gen Navi/Turing prices drop when Navi2/Ampere are released & evaluate your gpu options then. Otherwise, Ryzen2/mb/RAM combos are great value.
What do you think Arcturus is?
Innerverse
4 (0.04/day)
Thank you guys for the answers, great insight!
So far the thinking is to keep gaming at 1080p 60fps, which is totally fine for me to be honest. Most games I play are competitive anyways, and I will most likely keep my 24'' for it since 27'' is a bit too big for competitive games in my opinion (I don't want to have to move my eyes too much to see what's on the screen).
I guess my current rig is okay for my multimedia work aswell. I will still be glad if others want to add their thoughts on the topic!
Innerverse
4 (0.04/day)
Ok so I didn't want to create another thread just for this simple question.
I was using 2x8 GB DDR3 1600hz sticks for a total of 16 gb, then my roomate upgraded his rig and had his 2x8 GB DDR3 1600hz sticks to give away (same speed as mine but another brand). I did some research and found out that they could fit on my motherboard and my other sticks since they have same amount of memory and speed so I installed them, so im now having 4 sticks on my motherboard for a total fo 32 gb. Thing is, I now see on my task manager performance tab that my speed is 1333 MHz (instead of the 1600 MHz I had previously on 16 gb). Is this normal? The 4 sticks are 1600 MHz and my motherboard is the Asus P9X79 Deluxe, supporting 8 sticks total. If that's normal, is it still a good trade to go from 16 GB 1600 MHz to 32 GB 1333 MHz? Thank you (rest of my rig specs are in the initial post)
845 (0.17/day)
Processor i7 7700k @ 5ghz 1.36v
Motherboard Asus Z170-e
Cooling Noctua NH-D-15
Memory HyperX Fury 64GB (4 x 16GB) DDR4 2400MHz
Video Card(s) Quatro P4000
Storage 1tb Samsung 970 EVO,500gb,750gb
Display(s) Asus 23in 1920X1080
Case CoolerMaster HAF 932
Audio Device(s) X-Fi
Power Supply Corsair tx650w
Keyboard Dell
Software 10 Home 64bit
Go to the bios and change the speed of the ram and everything will be like it should.
FreedomEclipse
~Technological Technocrat~
20,345 (4.29/day)
London,UK
System Name Codename: Icarus Mk.V
Processor Intel 8600k@4.8Ghz
Memory 16 Corsair Vengeance White LED DDR4 3200Mhz {2x8GB}
Video Card(s) Gigabyte 1080Ti Gaming OC|Accelero Xtreme IV
Storage Samsung 970Evo 512GB SSD (Boot)|WD Blue 1TB SSD|2x 3TB Toshiba DT01ACA300
Display(s) Asus PB278Q 27"
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900/G502
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Without knowing what make and model your friends sticks of ram were - its hard to say. Usually its better to go with matched sets. as mismatched ram could cause all sorts of problems with a PC - Ive been there with a P9X79Pro and 3930k and with other builds.
Whats happening is that your original ram has defaulted to matching the speed of the slowest set or ram or sticks for safety/stability purposes. You can set the ram to run at a faster speed but without knowing the make/model of your friends ram, I cant tell you if this would cause instabilities. I also recommend you stay away from XMP settings otherwise that might mess your system up even more.
Quad channel doesnt make a whole lot of difference in gaming.... Not unless youre loaded down with dual GPUs then that extra bandwidth that quad channel brings helps it hold up pretty good against DDR4 ram. Quad channel is still the way to go but not a requirement unless youre the hardcore of gamers and want to squeeze out every last drop of performance.
Find the timings for your friends set of ram as im guessing its the slowest set and manually set the speed and ram timings in the bios to prevent issues that happen with mismatched rams.
As for your setup. you can upgrade your GPu to a 1080Ti but complete setup as a whole could really do with an overhaul.
New cards on the way from AMD and Nvidia very soon anyway so you've got some time to decide what path you want to take.
1,118 (5.15/day)
System Name just ordinary potato system, but dont understimate potato..
Processor ryzen raven ridge 2200g, ryzen 2600 upgrade:)
Motherboard msi b350 pc mate, biostars a320, asrock ab350m micro
Cooling x2 cheap china handmade, i got plenty aigo/fantech rgb fans now heh
Memory klevv dual channel 8gb 3000mhz, trident 16gb 3600mhz, random ddr2 stick
Video Card(s) back to square, using vega 56 now:D
Storage wd green ssd 240gb, 3tb seagate expnasion, random laptop hdd x4, 1tb 3.5
Display(s) acer vgo 22inch fullhd 75hz
Case cheap segotep/dazumba mid atx, alcatroz mini atx
Audio Device(s) genius retro wood style, harman kardon stick iii
Power Supply be quite system power9, powerlogic standar, voltron 300fx, thermaltake smart 1200w
Mouse rexus, genius ps/2, powerlogic ps/2 ball tracking
Keyboard rexus, random china product x3
Software talking abt best software, autodesk/unity3d/notepad yes notepad!!
Benchmark Scores theres nothing to brag abt potato, but it can run decent 30fps fullhd with good setting:)
stick with your curent card, theres no point upgrade right now, becouse you will need an expensive 2080ti to get stable 60hz 4k, also cpu/motherboard/ram upgrade needed for 4k gaming i guess
but if you want to enjoy temporary 4k experience juts grab a nice 1080ti and do 4k setup normal/high preset, dont do ultra :D
5,018 (1.14/day)
Australia
Processor AMD R7 2700X | Ryzen 1600X | i7 970
Cooling AMD Wraith cooler| Stock Cooler, Copper Core)| Big shairkan B
Video Card(s) ASUS GTX 970 OC in Sli | Inno3d GTX 1050 TI | MSI RX 580 8GB
Storage 250GB Plextor SSD Por 5 /1TB WD Black | 500GB SSD WD, 2x1TB, 1x750 | WD 320/Seagate 320
Power Supply Silverstone 750 | Silverstone Mini 450W | Corsair CX-750
Software Windows 7 Pro 64 | Windows 7 Pro 64 | Windows 7 Pro 64/Windows 10 Home
If you are intending to play any games at 4k then your going to need a 2080 Ti, CPU doesnt mean anything when it comes to that res.
1,002 (0.75/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
GPU. The best option is used GTX 1080 or GTX 1080 Ti. Just don't expect to play everything with max details at 60+ FPS. Lower the details to medium or high and you'll be fine or simply lower the to 2560x1440.
You made a mistake by buying a 4K monitor, but now it is what it is. I would advise anyone against buying a 4K monitor because current hardware is still not suited to it as good as it is for 1080p and 1440p monitors. Sure, you can always burn a lot and I mean a lot of money to build a proper 4K system but even such ridiculously expensive system will be surpassed by the upper-middle class PC's for like 5 years.
2,110 (1.96/day)
Processor AMD Ryzen 5 1600X
Motherboard Biostar X370GTN
Cooling Custom CPU+GPU water loop
Memory 16GB G.Skill TridentZ DDR4-3200 C16
Video Card(s) AMD R9 Fury X
Storage 500GB 960 Evo (OS ++), 500GB 850 Evo (Games)
Display(s) Dell U2711
Case NZXT H200i
Keyboard Lenovo Compact Keyboard with Trackpoint
First order of business: check the timings for each RAM kit. They should be listed in the BIOS somewhere. Chances are one is slower/higher timings than the other. If you then try to apply an XMP profile from the faster memory this will likely not be stable, so any profiles applied should be from the slower kit. Even this might not be stable though, and you might need manual tuning to make both run at the same clock speed. Still, I ran mismatched DDR2 in my previous rig for 8 years by simply using the (slightly) slower kit to set timings.
As for any upgrades I agree on holding off - while the GPU is by far your biggest bottleneck for 4k gaming, competitive gaming at 4k doesn't make much sense anyhow. Keep doing what you've been doing until you can afford a full system upgrade, and hold off until the next generation of GPUs shows up (Arcturus/RDNA2 and Ampere). Even then I would consider getting a secondary high refresh rate monitor at a lower resolution rather than gaming at 4k - if speed and responsiveness matters at all to you a move to 1080p or 1440p 120/144/240Hz will make far more of a difference to your gaming experience than the extra resolution of 4k.
Innerverse
4 (0.04/day)
Thanks for the input, but like I said in the OP, my main goal is NOT for 4k gaming. I am working in multimedia and bought this monitor especially for multimedia work (it's a monitor made for that, it's not even a good gaming monitor). What I want to do right now is being able to run duo monitors while running adobe suite softwares smoothly, gaming is a bonus, I will keep using my 24'' monitor for that for probably a long time still.
Thanks everyone else aswell, all those replies helped me. Seems like my current system is good enough to support my needs at the moment, I will wait for a full upgrade in the future. As for the 2 additional ram sticks, I decided to remove them, I don't think the extra RAM will be that helpful anyway and I felt like there was some compatibility issues.
6,002 (6.14/day)
Poland
System Name skurwiel szatan
Processor i7 5775c @4.3GHz/1.385v/EDRAM @2GHz
Motherboard Z97X Gaming 5
Cooling Noctua D15S
Memory Crucial Ballistix Tactical LP 1600 CL8 @2133 9-9-9-27 1T
Video Card(s) RTX 2070 Super Gaming X Trio (waiting for RX 5950XT)
Storage SU900 128 (OS)/850 PRO 256+256+ 512,860 EVO 500,XPG SX950U 480,M9Pe(Y) 512 (games)/4TB HDDs (3+1)
Display(s) Acer XB241YU+Dell S2716DG dual monitor setup
Case Full tower
Audio Device(s) W830BT headphones
Benchmark Scores A LOT
I don't know what "multimeda" 3930k+1060 can't run that 3950x and Titan RTX can.
specifically
